* include/rtems/bspIo.h, include/rtems/concat.h,
include/rtems/endian.h, include/rtems/fs.h, include/rtems/irq.h,
include/rtems/pci.h, include/rtems/userenv.h,
libblock/include/rtems/flashdisk.h,
libblock/include/rtems/nvdisk-sram.h,
libblock/include/rtems/nvdisk.h, libcsupport/include/clockdrv.h,
libcsupport/include/console.h, libcsupport/include/iosupp.h,
libcsupport/include/spurious.h,
libcsupport/include/motorola/mc68230.h,
libcsupport/include/rtems/assoc.h, libcsupport/include/rtems/error.h,
libcsupport/include/rtems/framebuffer.h,
libcsupport/include/rtems/gxx_wrappers.h,
libcsupport/include/rtems/libcsupport.h,
libcsupport/include/rtems/libio_.h,
libcsupport/include/rtems/malloc.h,
libcsupport/include/rtems/termiostypes.h,
libcsupport/include/sys/statvfs.h, libcsupport/include/sys/termios.h,
libcsupport/include/sys/utsname.h, libcsupport/include/zilog/z8036.h,
libcsupport/include/zilog/z8530.h, libcsupport/include/zilog/z8536.h,
libfs/src/imfs/imfs.h, libfs/src/pipe/pipe.h,
libmisc/capture/capture-cli.h, libmisc/capture/capture.h,
libmisc/cpuuse/cpuuse.h, libmisc/devnull/devnull.h,
libmisc/devnull/devzero.h, libmisc/dumpbuf/dumpbuf.h,
libmisc/fb/fb.h, libmisc/fb/mw_uid.h, libmisc/mouse/mouse_parser.h,
libmisc/shell/shellconfig.h, libmisc/stringto/stringto.h,
libmisc/untar/untar.h, libnetworking/memory.h, posix/include/aio.h,
posix/include/mqueue.h, posix/include/semaphore.h,
posix/include/rtems/posix/aio_misc.h,
posix/include/rtems/posix/barrier.h,
posix/include/rtems/posix/cond.h, posix/include/rtems/posix/config.h,
posix/include/rtems/posix/key.h, posix/include/rtems/posix/mqueue.h,
posix/include/rtems/posix/mutex.h,
posix/include/rtems/posix/posixapi.h,
posix/include/rtems/posix/ptimer.h,
posix/include/rtems/posix/rwlock.h,
posix/include/rtems/posix/sigset.h,
posix/include/rtems/posix/spinlock.h,
posix/inline/rtems/posix/barrier.inl,
posix/inline/rtems/posix/rwlock.inl,
posix/inline/rtems/posix/spinlock.inl,
posix/inline/rtems/posix/timer.inl, rtems/mainpage.h,
rtems/include/rtems/rtems/barrier.h,
rtems/include/rtems/rtems/object.h,
rtems/include/rtems/rtems/timer.h,
rtems/inline/rtems/rtems/barrier.inl,
rtems/inline/rtems/rtems/timer.inl,
rtems/src/semtranslatereturncode.c, sapi/include/rtems/config.h,
sapi/include/rtems/fatal.h, sapi/include/rtems/mptables.h,
score/inline/rtems/score/object.inl,
score/inline/rtems/score/priority.inl: Add @file Doxygen directives
and descriptions to files which originated with RTEMS. This improves
the file list page generated by Doxygen.
* libmisc/devnull/devzero.c, libmisc/devnull/devzero.h: New files.
* libmisc/Makefile.am, Makefile.am, preinstall.am: Reflect changes
above.
* libmisc/devnull/devnull.h, libmisc/stackchk/stackchk.h:
Fix header guard. Add missing includes.
* libmisc/capture/capture-cli.c, libmisc/capture/capture.c,
libmisc/capture/capture.h, libmisc/cpuuse/cpuuse.c,
libmisc/devnull/devnull.c, libmisc/fsmount/fsmount.h,
libmisc/monitor/mon-config.c, libmisc/monitor/mon-dname.c,
libmisc/monitor/mon-driver.c, libmisc/monitor/mon-extension.c,
libmisc/monitor/mon-itask.c, libmisc/monitor/mon-monitor.c,
libmisc/monitor/mon-mpci.c, libmisc/monitor/mon-object.c,
libmisc/monitor/mon-prmisc.c, libmisc/monitor/mon-queue.c,
libmisc/monitor/mon-server.c, libmisc/monitor/mon-symbols.c,
libmisc/monitor/monitor.h, libmisc/monitor/symbols.h,
libmisc/mw-fb/mw_uid.c, libmisc/rtmonuse/rtmonuse.c,
libmisc/serdbg/serdbg.h, libmisc/serdbg/serdbgio.c,
libmisc/serdbg/termios_printk.c, libmisc/serdbg/termios_printk.h,
libmisc/shell/shell.c, libmisc/shell/shell.h, libmisc/stackchk/check.c,
libmisc/stackchk/internal.h: Convert to using c99 fixed size types.
* capture/Makefile.am: Remove.
* cpuuse/Makefile.am: Remove.
* devnull/Makefile.am: Remove.
* dummy/Makefile.am: Remove.
* dumpbuf/Makefile.am: Remove.
* fsmount/Makefile.am: Remove.
* monitor/Makefile.am: Remove.
* mw-fb/Makefile.am: Remove.
* rtmonuse/Makefile.am: Remove.
* serdbg/Makefile.am: Remove.
* shell/Makefile.am: Remove.
* stackchk/Makefile.am: Remove.
* untar/Makefile.am: Remove.
* Makefile.am: Merge-in the Makefile.ams above.
* capture/config.h: Remove.
* capture/Makefile.am: Remove config.h.
AM_CPPFLAGS += -I$(top_builddir).
* cpuuse/config.h: Remove.
* cpuuse/Makefile.am: Remove config.h.
* devnull/config.h: Remove.
* devnull/Makefile.am: Remove config.h.
* dummy/config.h: Remove.
* dummy/Makefile.am: Remove config.h.
* dumpbuf/config.h: Remove.
* dumpbuf/Makefile.am: Remove config.h.
* monitor/config.h: Remove.
* monitor/Makefile.am: Remove config.h.
* mw-fb/config.h: Remove.
* mw-fb/Makefile.am: Remove config.h.
* rtmonuse/config.h: Remove.
* rtmonuse/Makefile.am: Remove config.h.
* serdbg/config.h: Remove.
* serdbg/Makefile.am: Remove config.h.
* shell/config.h: Remove.
* shell/Makefile.am: Remove config.h.
* stackchk/config.h: Remove.
* stackchk/Makefile.am: Remove config.h.
* untar/config.h: Remove.
* untar/Makefile.am: Remove config.h.
* cpuuse/cpuuse.c, cpuuse/cpuuse.h, devnull/devnull.c,
devnull/devnull.h, dummy/dummy.c, dumpbuf/dumpbuf.c,
dumpbuf/dumpbuf.h, fsmount/fsmount.c, fsmount/fsmount.h,
serdbg/serdbgio.c, serdbg/termios_printk.c, stackchk/check.c,
stackchk/internal.h, stackchk/stackchk.h, untar/untar.c,
untar/untar.h: URL for license changed.
* configure.ac: Remove (Merged into ../configure.ac).
* Makefile.am:
* capture/config.h: New.
* capture/Makefile.am: Add config.h.
* cpuuse/config.h: New.
* cpuuse/Makefile.am: Add config.h.
* devnull/config.h: New.
* devnull/Makefile.am: Add config.h.
* dummy/config.h: New.
* dummy/Makefile.am: Add config.h.
* dumpbuf/config.h: New.
* dumpbuf/Makefile.am: Add config.h.
* monitor/config.h: New.
* monitor/Makefile.am: Add config.h.
* mw-fb/config.h: New.
* mw-fb/Makefile.am: Add config.h.
* rtmonuse/config.h: New.
* rtmonuse/Makefile.am: Add config.h.
* serdbg/config.h: New.
* serdbg/Makefile.am: Add config.h.
* shell/config.h: New.
* shell/Makefile.am: Add config.h.
* stackchk/config.h: New.
* stackchk/Makefile.am: Add config.h.
* untar/config.h: New.
* untar/Makefile.am: Add config.h.
* wrapup/Makefile.am:
* capture/capture-cli.c: Add config-header support.
* capture/capture.c: Add config-header support.
* cpuuse/cpuuse.c: Add config-header support.
* devnull/devnull.c: Add config-header support.
* dummy/dummy.c: Add config-header support.
* dumpbuf/dumpbuf.c: Add config-header support.
* monitor/mon-command.c: Add config-header support.
* monitor/mon-config.c: Add config-header support.
* monitor/mon-dname.c: Add config-header support.
* monitor/mon-driver.c: Add config-header support.
* monitor/mon-extension.c: Add config-header support.
* monitor/mon-itask.c: Add config-header support.
* monitor/mon-manager.c: Add config-header support.
* monitor/mon-monitor.c: Add config-header support.
* monitor/mon-mpci.c: Add config-header support.
* monitor/mon-object.c: Add config-header support.
* monitor/mon-prmisc.c: Add config-header support.
* monitor/mon-queue.c: Add config-header support.
* monitor/mon-server.c: Add config-header support.
* monitor/mon-symbols.c: Add config-header support.
* monitor/mon-task.c: Add config-header support.
* mw-fb/mw_fb.c: Add config-header support.
* mw-fb/mw_uid.c: Add config-header support.
* rtmonuse/rtmonuse.c: Add config-header support.
* serdbg/serdbg.c: Add config-header support.
* serdbg/serdbgio.c: Add config-header support.
* serdbg/termios_printk.c: Add config-header support.
* shell/cmds.c: Add config-header support.
* stackchk/check.c: Add config-header support.
* untar/untar.c: Add config-header support.
* configure.ac: Add check for weak function attribute.
Remove AM_CONDITIONAL([RTEMS_LIBSHELL].
Add AM_CONDITIONAL(LIBSHELL), AM_CONDITIONAL(LIBSERDBG).
* capture/Makefile.am: Use *.a instead of *-tmp.a.
* cpuuse/Makefile.am: Use *.a instead of *-tmp.a.
* devnull/Makefile.am: Use *.a instead of *-tmp.a.
* dummy/Makefile.am: Use *.a instead of *-tmp.a.
* dumpbuf/Makefile.am: Use *.a instead of *-tmp.a.
* monitor/Makefile.am: Use *.a instead of *-tmp.a.
* mw-fb/Makefile.am: Use *.a instead of *-tmp.a.
* rtmonuse/Makefile.am: Use *.a instead of *-tmp.a.
* serdbg/Makefile.am: Use *.a instead of *-tmp.a.
Build iff LIBSERDBG is true.
* shell/Makefile.am: Use *.a instead of *-tmp.a.
Build iff LIBSHELL is true.
* stackchk/Makefile.am: Use *.a instead of *-tmp.a.
* untar/Makefile.am: Use *.a instead of *-tmp.a.
* configure.ac: Require autoconf-2.57+automake-1.7.2.
* capture/Makefile.am: Eliminate C_O_FILES.
* cpuuse/Makefile.am: Ditto.
* devnull/Makefile.am: Ditto.
* dummy/Makefile.am: Ditto.
* dumpbuf/Makefile.am: Ditto.
* monitor/Makefile.am: Ditto.
* rtmonuse/Makefile.am: Ditto.
* serdbg/Makefile.am: Ditto.
* shell/Makefile.am: Ditto.
* stackchk/Makefile.am: Ditto.
* untar/Makefile.am: Ditto.
* mw-fb/Makefile.am: Eliminate C_O_FILES.
Eliminate SRCS.
Moving libmisc from rtems/c/src to rtems/cpukit.
* Makefile.am: Reflect new path.
* configure.ac: Reflect new path.
Use RTEMS_ENV_RTEMSCPU instead of RTEMS_ENV_RTEMSBSP.
Remove RTEMS_PROJECT_ROOT.
* capture/Makefile.am: Reflect new path.
Remove OBJS from all-local.
* mw-fb/Makefile.am: Ditto.
* wrapup/Makefile.am: Reflect new path.
* capture/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* cpuuse/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* devnull/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* dummy/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* dumpbuf/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* monitor/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* mw-fb/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* rtmonuse/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* serdbg/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* shell/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* stackchk/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* untar/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* capture/Makefile.am: Use .$(OBJEXT) instead of .o.
* cpuuse/Makefile.am: Use .$(OBJEXT) instead of .o.
* devnull/Makefile.am: Use .$(OBJEXT) instead of .o.
* dummy/Makefile.am: Use .$(OBJEXT) instead of .o.
* dumpbuf/Makefile.am: Use .$(OBJEXT) instead of .o.
* monitor/Makefile.am: Use .$(OBJEXT) instead of .o.
* mw-fb/Makefile.am: Use .$(OBJEXT) instead of .o.
* rtmonuse/Makefile.am: Use .$(OBJEXT) instead of .o.
* serdbg/Makefile.am: Use .$(OBJEXT) instead of .o.
* shell/Makefile.am: Use .$(OBJEXT) instead of .o.
* stackchk/Makefile.am: Use .$(OBJEXT) instead of .o.
* untar/Makefile.am: Use .$(OBJEXT) instead of .o.
* devnull/Makefile.am: Remove AUTOMAKE_OPTIONS.
* dummy/Makefile.am: Remove AUTOMAKE_OPTIONS.
* dumpbuf/Makefile.am: Remove AUTOMAKE_OPTIONS.
* mw-fb/Makefile.am: Remove AUTOMAKE_OPTIONS.
* rootfs/Makefile.am: Remove AUTOMAKE_OPTIONS.
* shell/Makefile.am: Remove AUTOMAKE_OPTIONS.
* untar/Makefile.am: Remove AUTOMAKE_OPTIONS.
* untar/Makefile.am: Use 'PREINSTALL_FILES ='.
* monitor/Makefile.am: Use 'PREINSTALL_FILES ='.
* shell/Makefile.am: Use 'PREINSTALL_FILES ='.
* devnull/Makefile.am: Use 'PREINSTALL_FILES ='.
* dumpbuf/Makefile.am: Use 'PREINSTALL_FILES ='.
* mw-fb/Makefile.am: Use 'PREINSTALL_FILES ='.
* stackchk/Makefile.am: Use 'PREINSTALL_FILES ='.
* rtmonuse/Makefile.am: Use 'PREINSTALL_FILES ='.
* cpuuse/Makefile.am: Use 'PREINSTALL_FILES ='.
* rootfs/Makefile.am: Use 'PREINSTALL_FILES ='.
* devnull/devnull.c: Eliminate warning.
* devnull/devnull.c (null_initialize): Added check to
ensure that the driver is only initialized once. Otherwise,
it will abort when the device /dev/null is present.
(null_write): Do not dereference a NULL pointer.
* untar/Makefile.am, monitor/Makefile.am, dummy/Makefile.am,
devnull/Makefile.am, dumpbuf/Makefile.am, mw-fb/Makefile.am,
stackchk/Makefile.am, rtmonuse/Makefile.am, cpuuse/Makefile.am:
* devnull: New addition. Moved from libcpu/sh.
* devnull/devnull.c, devnull/devnull.h, devnull/.cvsignore,
devnull/Makefile.am: New files.
* Makefile.am, configure.in, wrapup/Makefile.am: Modified to reflect
addition of above.
