The readv() and writev() support was implemented in terms of multiple
calls to the read and write handlers. This imposes a problem on device
files which use an IO vector as single request entity. For example a
low-level network device (e.g. BPF(4)) may use an IO vector to create
one frame from multiple protocol layers each with its own IO vector
entry.
This handler is necessary to implement the KQUEUE(2) system calls.
Add <sys/event.h> from FreeBSD 8.4.
This handler is necessary to implement the SELECT(2) and POLL(2) system
calls.
Add <sys/poll.h> from FreeBSD 8.4.
Add optional conversion methods for multibyte strings. With these
conversions which make use of iconv and utf8proc it becomes possible to
use strings from any language (Czech, Chinese, Arabian, Hebrew, Corean,
...) for file names and directory names.
NOTE: Iconv support must be activated during the build of the tool chain
for these conversion methods (options --enable-newlib-iconv
--enable-newlib-iconv-encodings=[ENCODINGS_YOU_WANT]). Alternatively
you can provide your own conversion methods.
User interface and backwards compatibility for UTF-8 support in the FAT
file system. Purpose of UTF-8 support is to permit file names and
directory names with characters from all kinds of languages (Czech,
Chinese, Arabian, Hebrew, Korean, ...). This commit does not yet
support multibyte characters. It only contains the user interface and
the backwards compatibility.
The device IO file system support in IMFS, devFS, and RFS uses now a
shared implementation.
According to POSIX the lseek() function shall not, by itself, extend the
size of a file.
Remove the size field of rtems_libio_t. A file has only one size but
may have multiple open file descriptors. Thus a file size field in the
file descriptor may lead to inconsistencies.
New default handlers rtems_filesystem_default_lseek_file() and
rtems_filesystem_default_lseek_directory().
for details.
Generic nodes are an alternative to standard drivers in RTEMS. The
handlers of a generic node are called with less overhead compared to the
standard driver operations. The usage of file system node handlers
enable more features like support for fsync() and fdatasync(). The
generic nodes use the reference counting of the IMFS. This provides
automatic node destruction when the last reference vanishes.
Extend type IMFS_types_union by new type IMFS_generic_t.
Extend enum IMFS_jnode_types_t by IMFS_GENERIC.
Add functions
o IMFS_make_generic_node(),
o IMFS_is_imfs_instance(),
o IMFS_generic_get_context_by_node(),
o IMFS_generic_get_context_by_location(), and
o IMFS_generic_get_context_by_iop().
New test fstests/fsimfsgeneric01.
New defaults rtems_filesystem_default_fsync_or_fdatasync() and
rtems_filesystem_default_fsync_or_fdatasync_success() for fsync_h and
fdatasync_h. The rtems_filesystem_default_fsync_or_fdatasync() sets now
errno to EINVAL according to POSIX.
New function rtems_filesystem_default_lseek_success().
o A new data structure rtems_filesystem_global_location_t was
introduced to be used for
o the mount point location in the mount table entry,
o the file system root location in the mount table entry,
o the root directory location in the user environment, and
o the current directory location in the user environment.
During the path evaluation global start locations are obtained to
ensure that the current file system instance will be not unmounted in
the meantime.
o The user environment uses now reference counting and is protected
from concurrent access.
o The path evaluation process was completely rewritten and simplified.
The IMFS, RFS, NFS, and DOSFS use now a generic path evaluation
method. Recursive calls in the path evaluation have been replaced
with iteration to avoid stack overflows. Only the evaluation of
symbolic links is recursive. No dynamic memory allocations and
intermediate buffers are used in the high level path evaluation. No
global locks are held during the file system instance specific path
evaluation process.
o Recursive symbolic link evaluation is now limited by
RTEMS_FILESYSTEM_SYMLOOP_MAX. Applications can retrieve this value
via sysconf().
o The device file system (devFS) uses now no global variables and
allocation from the workspace. Node names are allocated from the
heap.
o The upper layer lseek() performs now some parameter checks.
o The upper layer ftruncate() performs now some parameter checks.
o unmask() is now restricted to the RWX flags and protected from
concurrent access.
o The fchmod_h and rmnod_h file system node handlers are now a file
system operation.
o The unlink_h operation has been removed. All nodes are now destroyed
with the rmnod_h operation.
o New lock_h, unlock_h, clonenod_h, and are_nodes_equal_h file system
operations.
o The path evaluation and file system operations are now protected by
per file system instance lock and unlock operations.
o Fix and test file descriptor duplicate in fcntl().
o New test fstests/fsnofs01.
There existed no calling function for this handler.
* libfs/Makefile.am: Unconditionally descend into src/nfsclient.
Include subdirs.am.
* libfs/src/imfs/imfs_fcntl.c: Removed file.
* libfs/Makefile.am: Reflect change from above.
* libfs/src/defaults/default_fcntl.c: Return 0 instead of -1 and errno.
* libfs/src/imfs/imfs.h, libfs/src/imfs/imfs_fifo.c,
libfs/src/imfs/imfs_handlers_directory.c,
libfs/src/imfs/imfs_handlers_memfile.c, libfs/src/nfsclient/src/nfs.c,
libfs/src/rfs/rtems-rfs-rtems-dir.c,
libfs/src/rfs/rtems-rfs-rtems-file.c, libfs/src/rfs/rtems-rfs-rtems.c,
libfs/src/rfs/rtems-rfs-rtems.h: Use default file system handlers.
* libcsupport/include/rtems/libio.h: Changed
rtems_filesystem_node_types_t to an enum. Declare
rtems_filesystem_handlers_default,
rtems_filesystem_operations_default,
rtems_filesystem_default_evalpath(),
rtems_filesystem_default_evalformake, and
rtems_filesystem_default_node_type().
* libfs/src/dosfs/msdos.h: Fixed msdos_node_type() prototype.
* libfs/src/defaults/default_evalformake.c,
libfs/src/defaults/default_handlers.c,
libfs/src/defaults/default_node_type.c,
libfs/src/defaults/default_ops.c: New files.
* libfs/Makefile.am: Reflect changes above.
* libfs/Makefile.am: Remove reference to imfs_free.c,
wrapup/Makefile.am: Split devfs into its own library.
* libfs/src/imfs/fifoimfs_init.c, libfs/src/imfs/imfs.h,
libfs/src/imfs/imfs_init.c, libfs/src/rfs/rtems-rfs-rtems.c:
Use default freenode implementation.
* libfs/src/imfs/imfs_free.c: Removed.
* libcsupport/include/rtems/libio.h, libfs/Makefile.am: Added
filesystem default mknod method.
* libfs/src/defaults/default_mknod.c: New file.
* libcsupport/include/rtems/libio.h, libfs/Makefile.am,
libfs/src/defaults/default_chown.c,
libfs/src/defaults/default_evalpath.c,
libfs/src/defaults/default_freenode.c,
libfs/src/defaults/default_fsmount.c,
libfs/src/defaults/default_link.c,
libfs/src/defaults/default_mount.c,
libfs/src/defaults/default_rename.c,
libfs/src/defaults/default_statvfs.c,
libfs/src/defaults/default_symlink.c,
libfs/src/defaults/default_unlink.c,
libfs/src/defaults/default_utime.c, libfs/src/devfs/devfs_init.c,
libfs/src/dosfs/msdos_init.c, libfs/src/imfs/imfs_init.c,
libfs/src/nfsclient/src/nfs.c, libfs/src/rfs/rtems-rfs-rtems.c,
wrapup/Makefile.am: Fixed typo in default names. Added default
methods into filesystem tables.
* libfs/src/defaults/default_close.c,
libfs/src/defaults/default_evaluate_link.c,
libfs/src/defaults/default_fpathconf.c,
libfs/src/defaults/default_fsunmount.c,
libfs/src/defaults/default_open.c,
libfs/src/defaults/default_unmount.c: New files.
* libcsupport/include/rtems/libio.h, libfs/Makefile.am: Added default
filesystem handlers.
* libfs/src/defaults/default_chown.c,
libfs/src/defaults/default_fchmod.c,
libfs/src/defaults/default_fcntl.c,
libfs/src/defaults/default_fdatasync.c,
libfs/src/defaults/default_fstat.c,
libfs/src/defaults/default_fsync.c,
libfs/src/defaults/default_ftruncate.c,
libfs/src/defaults/default_ioctl.c,
libfs/src/defaults/default_lseek.c,
libfs/src/defaults/default_read.c,
libfs/src/defaults/default_readlink.c,
libfs/src/defaults/default_rmnod.c,
libfs/src/defaults/default_write.c: New files.
* libfs/src/imfs/fifoimfs_init.c: New file.
* libfs/Makefile.am: Reflect change above.
* libfs/src/imfs/imfs.h, libfs/src/imfs/imfs_eval.c,
libfs/src/imfs/imfs_init.c, libfs/src/imfs/imfs_initsupp.c,
libfs/src/imfs/miniimfs_init.c, libfs/src/pipe/fifo.c,
libfs/src/pipe/pipe.c, libfs/src/pipe/pipe.h: Pipe support is now
link-time optional.
* sapi/include/confdefs.h: Reflect changes above.
* libcsupport/include/rtems/libio.h, libcsupport/src/_rename_r.c:
Add a rename file op and have rename use it.
* libfs/Makefile.am, libfs/src/dosfs/msdos_rename.c,
libfs/src/imfs/imfs_rename.c: New files to support the rename file
op.
* libfs/src/imfs/imfs.h: Add rename interface.
* libfs/src/imfs/imfs_init.c: Add rename handler.
* libfs/src/imfs/miniimfs_init.c: Fix up ops struct.
* libfs/src/dosfs/msdos.h: Add msdos_rename and remove
msdos_file_link.
* libfs/src/dosfs/msdos_create.c: Remove the link call.
* libfs/src/dosfs/msdos_eval.c: Fix a path parsing bug.
* libfs/src/dosfs/msdos_init.c: Add rename handler and clean up
the struct naming.
* libfs/src/rfs/rtems-rfs-link.c, libfs/src/rfs/rtems-rfs-link.h:
Change the link call to allow linking of directories if told to
and change the unlink to handle unlink directories that are not
empty so rename can be supported.
* libfs/src/rfs/rtems-rfs-rtems-dir.c: Fix the link/unlink calls.
* libfs/src/rfs/rtems-rfs-rtems.c: Add a rename handler. Fix the
link/unlink calls.
* libfs/src/dosfs/msdos_dir.c, libfs/src/dosfs/msdos_format.c,
libfs/src/dosfs/msdos_misc.c, httpd/asp.c,
libfs/src/nfsclient/src/nfs.c: Work around a newlib warning when
using the is*() family of calls.
* libfs/src/rfs/rtems-rfs-bitmaps.c,
libfs/src/rfs/rtems-rfs-bitmaps.h,
libfs/src/rfs/rtems-rfs-bitmaps-ut.c,
libfs/src/rfs/rtems-rfs-block.c, libfs/src/rfs/rtems-rfs-block.h,
libfs/src/rfs/rtems-rfs-block-pos.h,
libfs/src/rfs/rtems-rfs-buffer-bdbuf.c,
libfs/src/rfs/rtems-rfs-buffer.c,
libfs/src/rfs/rtems-rfs-buffer-devio.c,
libfs/src/rfs/rtems-rfs-buffer.h, libfs/src/rfs/rtems-rfs-data.h,
libfs/src/rfs/rtems-rfs-dir.c, libfs/src/rfs/rtems-rfs-dir.h,
libfs/src/rfs/rtems-rfs-dir-hash.c,
libfs/src/rfs/rtems-rfs-dir-hash.h,
libfs/src/rfs/rtems-rfs-file.c, libfs/src/rfs/rtems-rfs-file.h,
libfs/src/rfs/rtems-rfs-file-system.c,
libfs/src/rfs/rtems-rfs-file-system-fwd.h,
libfs/src/rfs/rtems-rfs-file-system.h,
libfs/src/rfs/rtems-rfs-format.c,
libfs/src/rfs/rtems-rfs-format.h, libfs/src/rfs/rtems-rfs-group.c,
libfs/src/rfs/rtems-rfs-group.h, libfs/src/rfs/rtems-rfs.h,
libfs/src/rfs/rtems-rfs-inode.c, libfs/src/rfs/rtems-rfs-inode.h,
libfs/src/rfs/rtems-rfs-link.c, libfs/src/rfs/rtems-rfs-link.h,
libfs/src/rfs/rtems-rfs-mutex.c, libfs/src/rfs/rtems-rfs-mutex.h,
libfs/src/rfs/rtems-rfs-rtems-dev.c,
libfs/src/rfs/rtems-rfs-rtems.h,
libfs/src/rfs/rtems-rfs-rtems-utils.c,
libfs/src/rfs/rtems-rfs-shell.c, libfs/src/rfs/rtems-rfs-shell.h,
libfs/src/rfs/rtems-rfs-trace.c, libfs/src/rfs/rtems-rfs-trace.h:
New.
* Makefile.am, preinstall.am, libfs/Makefile.am,
wrapup/Makefile.am: Updated with the RFS support.
* libfs/README: Updated after 10 years.
* libblock/src/flashdisk.c, libblock/src/nvdisk.c,
libblock/src/ramdisk-driver.c: Updated to the new error reporting
in libblock.
* libmisc/shell/main_ls.c, libmisc/shell/print-ls.c: Fix printing
the size in long mode.
* libnetworking/nfs/bootp_subr.c,
libnetworking/rtems/rtems_bootp.c,
libnetworking/rtems/rtems_bsdnet_internal.h: Return the BOOTP/DHCP
to the forever behaviour of 4.9 with the ability to call BOOTP and
control the process if required.
* libfs/Makefile.am: Unconditionally build src/pipe/fifo.c
src/pipe/pipe.c src/pipe/pipe.h.
* libfs/Makefile.am: Add stub for devide filesystem for unix port.
* libfs/src/devfs/devfs_unixstub.c: New file.
* Makefile.am, preinstall.am, libcsupport/src/mknod.c,
libcsupport/src/open.c, libcsupport/src/pipe.c, libfs/Makefile.am,
libfs/preinstall.am, libfs/src/imfs/imfs.h,
libfs/src/imfs/imfs_creat.c, libfs/src/imfs/imfs_debug.c,
libfs/src/imfs/imfs_eval.c, libfs/src/imfs/imfs_initsupp.c,
libfs/src/imfs/imfs_mknod.c, libfs/src/imfs/imfs_stat.c,
libfs/src/imfs/memfile.c: Initial commit of POSIX pipe support.
* libfs/src/imfs/imfs_fifo.c, libfs/src/pipe/fifo.c,
libfs/src/pipe/pipe.c, libfs/src/pipe/pipe.h: New files.
* libfs/Makefile.am: Do not build nfsclient if no networking.
* Makefile.am, preinstall.am, libcsupport/Makefile.am,
libcsupport/include/rtems/libcsupport.h,
libcsupport/include/rtems/libio.h, libcsupport/src/base_fs.c,
libcsupport/src/libio_init.c, libcsupport/src/newlibc_exit.c,
libcsupport/src/newlibc_init.c, libcsupport/src/sync.c,
libfs/Makefile.am, libfs/src/imfs/deviceio.c,
sapi/include/confdefs.h: Merge GSOC project code to add simple device
only filesystem (devfs), optionally completely drop out filesystem,
and to clean up disabling newlib reentrancy support. This dropped 17K
from the minimum.exe for sparc/sis and arm/rtl22xx_t now has a 15K
code space.
* libcsupport/src/__usrenv.c, libcsupport/src/newlibc_reent.c,
libfs/src/devfs/devclose.c, libfs/src/devfs/devfs.h,
libfs/src/devfs/devfs_eval.c, libfs/src/devfs/devfs_init.c,
libfs/src/devfs/devfs_mknod.c, libfs/src/devfs/devfs_node_type.c,
libfs/src/devfs/devfs_show.c, libfs/src/devfs/devioctl.c,
libfs/src/devfs/devopen.c, libfs/src/devfs/devread.c,
libfs/src/devfs/devstat.c, libfs/src/devfs/devwrite.c,
libfs/src/imfs/deviceerrno.c: New files.
* libcsupport/src/newlibc.c: Removed.
* configure.ac, libfs/Makefile.am: Add nfsclient to cpukit. Although
the use of RPC/XDR could be an issue, the code does build multilib
across all targets. There are a few remaining warnings to deal with.
* libfs/src/nfsclient/.cvsignore, libfs/src/nfsclient/ChangeLog.slac,
libfs/src/nfsclient/LICENSE, libfs/src/nfsclient/Makefile.am,
libfs/src/nfsclient/README, libfs/src/nfsclient/preinstall.am,
libfs/src/nfsclient/rfc1094.txt,
libfs/src/nfsclient/proto/mount_prot.h,
libfs/src/nfsclient/proto/mount_prot.x,
libfs/src/nfsclient/proto/mount_prot_xdr.c,
libfs/src/nfsclient/proto/nfs_prot.h,
libfs/src/nfsclient/proto/nfs_prot.x,
libfs/src/nfsclient/proto/nfs_prot_xdr.c,
libfs/src/nfsclient/src/cexphelp.c,
libfs/src/nfsclient/src/dirutils.c,
libfs/src/nfsclient/src/librtemsNfs.h, libfs/src/nfsclient/src/nfs.c,
libfs/src/nfsclient/src/nfs.modini.c,
libfs/src/nfsclient/src/nfsTest.c, libfs/src/nfsclient/src/rpcio.c,
libfs/src/nfsclient/src/rpcio.h,
libfs/src/nfsclient/src/rpcio.modini.c,
libfs/src/nfsclient/src/sock_mbuf.c,
libfs/src/nfsclient/src/xdr_mbuf.c: New files.
* configure.ac, Makefile.am, libfs/Makefile.am:
Introduce AM_CONDITIONAL(LIBDOSFS).
* configure.ac: Add new header guard to cpuopts.h.
* Makefile.am: Add libfs, libblock, ftpd header install rules.
* libfs/Makefile.am, libblock/Makefile.am, ftpd/Makefile.am: Remove
* libfs/Makefile.am: Build libfs/src/imfs/imfs_load_tar.c.
* itron/Makefile.am, libblock/Makefile.am, libcsupport/Makefile.am,
libfs/Makefile.am, libmisc/Makefile.am, posix/Makefile.am,
rtems/Makefile.am, sapi/Makefile.am:
Remove AM_CPPFLAGS += -I$(top_builddir).
* httpd/Makefile.am, itron/Makefile.am, libblock/Makefile.am,
libcsupport/Makefile.am, libfs/Makefile.am, libmisc/Makefile.am,
libnetworking/Makefile.am, librpc/Makefile.am, posix/Makefile.am,
rtems/Makefile.am, sapi/Makefile.am, score/Makefile.am:
Eliminate CFLAGS_OPTIMIZE_V.
* automake/compile.am, httpd/Makefile.am, itron/Makefile.am,
libblock/Makefile.am, libcsupport/Makefile.am, libfs/Makefile.am,
libmisc/Makefile.am, libnetworking/Makefile.am, librpc/Makefile.am,
posix/Makefile.am, rtems/Makefile.am, sapi/Makefile.am,
score/Makefile.am, wrapup/Makefile.am:
Remove build-variant support.
PR 720/filesystem:
* libfs/src/dosfs/msdos_format.c: New
(From Thomas Doerfler <Thomas.Doerfler@imd-systems.de>).
* libfs/Makefile.am: Reflect changes above:
* libblock/Makefile.am: Remove LIBC_DEFINES (Unsupported).
* libfs/Makefile.am: Remove LIBC_DEFINES (Unsupported).
* Makefile.am: Add backward/*.h headers.
* itron/Makefile.am: Install itron.h to $(includedir)/rtems.
* libcsupport/Makefile.am: Install RTEMS specific headers to
* libfs/Makefile.am: Install imfs.h and dosfs.h to
* Makefile.am: Re-add dirstamps to PREINSTALL_FILES.
Add PREINSTALL_FILES to CLEANFILES.
* Makefile.am: Include compile.am, again.
Reformat/Cleanup.
* Makefile.am: Add libs to CLEANFILES
Set lib*_g_a_SOURCES = lib*_a_SOURCES.
