- Do not error if a RAP section is not found.
- Free a symbol table via the RTL allocator interface.
- Add the symbols to the global symbol table.
Update #2769
Update #2843.
Update #2843.
Update #2843.
line option.
may suppress warnings.
erc32, imx, qoriq, etc.
* cpukit/include
* cpukit/libnetworking
* bsps/include
* bsps/@RTEMS_CPU@/include
order.
Update #3254.
Prepare for header file move to common include directory.
Update #3254.
Update #3155.
Update #3155.
Update #2133.
some architectures
Provide extentions to <inttpes.h> PRIxxx constants for more POSIX types.
Start with existing definitions found in RTEMS Project owned code
in cpukit/.
updates #2983.
The ARM C++ exception ABI uses an address ordered index table to
locate the correct frame data and this requires the EXIDX sections are
loaded in the order the order the matching text is loaded.
The EXIDX sections set the SHF_LINK_ORDER flag and link field. This patch
adds support to load those flagged sections in the linked-to section
order.
Updates #2955.
Closes #2959
This has been tested on SPARC, i386, PowerPC and ARM.
Closes #2767.
updates #2802.
Use of rtems_cache_get_maximal_line_size() is more descriptive
choice. The min/max data/instruction cache line size is not critical
there, value is used for optimization only to use single operation
for directly following sections.
Closes #2767
This patch fixes a number of bugs in the cache when requests are
made to read close to the end of the file and the data is copied
from the top of the cache buffer to the bottom of the buffer. This
was compounded by attempting to read past the end of the file.
Closes #2754.
Memory content changes caused by relocation has to be
propagated to memory/cache level which is used/snooped
during instruction cache fill.
Closes #2438
Synchronize each cluster of sections of the same type separately
to support even cases where text and data are allocated from different
areas (for example due allocation from different MPU protection regions).
rtems_cache_instruction_sync_after_code_change is called even to data
sections. Propagation of data only changes should not require cache
maintenance operation on sane SMP mutithread capable systems if barrier
instruction is added but be on safe side even for case where self
modifying code uses data sections initial values etc.
The RTEMS print user need to know nothing about a particular printer
implementation. In particular get rid of the <stdio.h> include which
would be visible via <rtems.h>.
updates #2446.
This patch addresses the following warnings:
+ The variable "target" was unused.
+ The parentheses in the expression around line 72 were ambiguous.
See refs #2192.
See refs #2191.
On a 16-bit target the section value could result in a sign-extension
overflow.
See ref #2191.
The fix is ref #2191.
The address returned from the allocator call was not checked when zeroing
the memory.
This should have been added.
Adding a local symbol lets the relocator find local symbols referenced
in relocation records. The local symbol table is erased once the object
module has been loaded.
This is a merge of the RTL project.
