* | libdl: Remove _t from all structures as this is reserved for the standards | Chris Johns | 2018-04-12 | 1 | -29/+29 |
* | libdl: Include <rtems/rtl/rtl-*.h> | Sebastian Huber | 2017-12-13 | 1 | -2/+2 |
| | | | | | | Prepare for header file move to common include directory. Update #3254. | ||||
* | Include missing <string.h> | Sebastian Huber | 2017-08-25 | 1 | -0/+1 |
| | | | | Update #2133. | ||||
* | Replace www.rtems.com with www.rtems.org | Sebastian Huber | 2015-03-20 | 1 | -1/+1 |
* | libdl: Add a local symbol table to the object module. | Chris Johns | 2014-11-04 | 1 | -4/+26 |
| | | | | | | Adding a local symbol lets the relocator find local symbols referenced in relocation records. The local symbol table is erased once the object module has been loaded. | ||||
* | cpukit: Add libdl with the Runtime Loader (RTL) code. | Chris Johns | 2014-10-31 | 1 | -0/+245 |
This is a merge of the RTL project. |
