path: root/cpukit/libdl/rtl-string.h (follow)
* libdl: Add symbol searching and loading from archives.Chris Johns2019-02-091-2/+0
| | | | | | | | | | | | | | - Load archive symbol tables to support searching of archives for symbols. - Search archive symbols and load the object file that contains the symbol. - Search the global and archives until all remaining unresolved symbols are not found. Group the loaded object files in the pending queue. - Run the object file and loaded dependents as a group before adding to the main object list. - Remove orphaned object files after references are removed. Updates #3686
* libdl: Include <rtems/rtl/rtl-*.h>Sebastian Huber2017-12-131-1/+1
| | | | | | Prepare for header file move to common include directory. Update #3254.
* cpukit: Add libdl with the Runtime Loader (RTL) code.Chris Johns2014-10-311-0/+37
This is a merge of the RTL project.
