path: root/cpukit/include/rtems/shell.h (follow)
* libmisc/shell: Fix the handling of joel scripts in telnetChris Johns2020-04-151-1/+6
| | | | | | | | | | | | - Fix the passing of std[in/out] to child threads - Fix deleting of managed memory in the key destructor - Only set the key in the main loop thread - Only allocate a shell env outside of the main loop - Fix memory leak if the task start fails - Remove error level from shell env, it cannot be returned this way. Add exit_code but the API is broken so it cannot be returned. Closes #3859
* Remove explicit file names from @fileSebastian Huber2019-02-281-1/+1
| | | | | | This makes the @file documentation independent of the actual file name. Update #3707.
* Remove make preinstallChris Johns2018-01-251-0/+385
