Make sure that a user-provided stack size is the minimum size allocated
for the stack.
Make sure we meet the stack alignment requirement also for CPU ports
with CPU_STACK_ALIGNMENT > CPU_HEAP_ALIGNMENT.
Use common phrases for the file brief descriptions.
Update #3706.
Adjust group identifier and names to be in line with a common pattern.
Use common phrases for the group brief descriptions.
Update #3706.
This adds a CPU port for AArch64(ARMv8) with support for exceptions and
interrupts.
On most architectures, the size of the thread-local storage TCB must be
8 bytes. Fix the definition for 64-bit targets.
Use the stack area to allocate the TLS area.
Update #3835.
Update #3706.
Update #3706
line option.
may suppress warnings.
erc32, imx, qoriq, etc.
* cpukit/include
* cpukit/libnetworking
* bsps/include
* bsps/@RTEMS_CPU@/include
order.
Update #3254.
