path: root/cpukit/include/rtems/score/priorityimpl.h (follow)
* score: Add comments and asserts for clarificationSebastian Huber2021-02-011-0/+7
| | | | This fix relates to a Coverity issue (NULL_RETURNS).
* score: Canonicalize Doxygen @file commentsSebastian Huber2020-12-021-1/+2
| | | | | | Use common phrases for the file brief descriptions. Update #3706.
* doxygen: score: adjust doc in priorityimpl.h to doxygen guidelinesAndreas Dachsberger2019-05-131-0/+289
| | | | Update #3706.
* Remove make preinstallChris Johns2018-01-251-0/+435
