path: root/cpukit/include/rtems/score/isrlevel.h (follow)
* score: Canonicalize Doxygen @file commentsSebastian Huber2020-12-021-3/+3
| | | | | | Use common phrases for the file brief descriptions. Update #3706.
* doxygen: score: adjust doc in isrlevel.h to doxygen guidelinesAndreas Dachsberger2019-05-131-6/+9
| | | | Update #3706.
* doxygen: Rename Score* groups in RTEMSScore*Sebastian Huber2019-04-041-1/+1
| | | | Update #3706
* doxygen: Reviewed cpukit/include/rtems/scoreAndreas Dachsberger2019-04-021-6/+2
| | | | Update #3706.
* Remove explicit file names from @fileSebastian Huber2019-02-281-1/+1
| | | | | | This makes the @file documentation independent of the actual file name. Update #3707.
* Remove make preinstallChris Johns2018-01-251-0/+153
