path: root/cpukit/include/rtems/score/io.h (follow)
* score: Add _IO_Relax()Sebastian Huber2022-03-241-0/+8
| | | | | | | This function may be used to burn a couple of processor cycles with minimum impact on the system bus. It may be used in busy wait loops. Since it is a global function, it is possible to wrap it in device driver test code.
* cpukit/: Scripted embedded brains header file clean upJoel Sherrill2022-03-101-6/+0
| | | | Updates #4625.
* cpukit/include/rtems/score/[a-r]*.h: Change license to BSD-2Joel Sherrill2022-02-281-3/+22
| | | | Updates #3053.
* score: Add _IO_Base64url()Sebastian Huber2021-02-251-7/+44
| | | | Update #4267.
* score: Canonicalize Doxygen @file commentsSebastian Huber2020-12-021-0/+9
| | | | | | Use common phrases for the file brief descriptions. Update #3706.
* score: Canonicalize Doxygen groupsSebastian Huber2020-12-021-0/+12
| | | | | | | Adjust group identifier and names to be in line with a common pattern. Use common phrases for the group brief descriptions. Update #3706.
* score: Add _IO_Base64()Sebastian Huber2020-03-161-1/+26
| | | | Update #3904.
* Remove make preinstallChris Johns2018-01-251-0/+46
