path: root/cpukit/include/rtems/score/io.h (follow)
* score: Add _IO_Base64url()Sebastian Huber2021-02-251-7/+44
| | | | Update #4267.
* score: Canonicalize Doxygen @file commentsSebastian Huber2020-12-021-0/+9
| | | | | | Use common phrases for the file brief descriptions. Update #3706.
* score: Canonicalize Doxygen groupsSebastian Huber2020-12-021-0/+12
| | | | | | | Adjust group identifier and names to be in line with a common pattern. Use common phrases for the group brief descriptions. Update #3706.
* score: Add _IO_Base64()Sebastian Huber2020-03-161-1/+26
| | | | Update #3904.
* Remove make preinstallChris Johns2018-01-251-0/+46
