Update #4572.
Resolution is the right term for the documented property.
Update #4527.
Update #4338.
Mention the type of the pointer in the parameter description. Use the
more general term "object" instead of "variable".
Update #3993.
Change license to BSD-2-Clause according to file histories and
documentation re-licensing agreement.
Update #3899.
Update #3993.
Update #3706.
Update #3706.
This makes the @file documentation independent of the actual file name.
Update #3707.
Separate the definitions related to watchdog ticks from the watchdog
structures.
Update #3598.
Use a real function for rtems_clock_get_uptime_seconds().
Update #3598.
Update #3598.
line option.
may suppress warnings.
erc32, imx, qoriq, etc.
* cpukit/include
* cpukit/libnetworking
* bsps/include
* bsps/@RTEMS_CPU@/include
order.
Update #3254.
