path: root/cpukit/include/rtems/diskdevs.h (follow)
* libblock: Add RTEMS_DEPRECATEDSebastian Huber2018-08-071-114/+30
| | | | Close #3358.
* Remove make preinstallChris Johns2018-01-251-0/+511
