path: root/cpukit/include/linux (follow)
* linux: Add rbtree_postorder_for_each_entry_safe()Sebastian Huber2018-07-161-0/+16
| | | | Update #3465.
* linux: Simplify <linux/rbtree.h>Sebastian Huber2018-07-161-45/+37
| | | | | | | Remove the placeholder struct rb_node and use RBTree_Node directly via some C pre-processor defines to adjust the member names. Update #3465.
* linux: Install <linux/rbtree.h>Sebastian Huber2018-07-161-0/+133
| | | | | | This makes it possible to test this API. Update #3465.
* Remove make preinstallChris Johns2018-01-253-0/+680
