path: root/cpukit/include/drvmgr (follow)
* drvmgr: Improve LP64 compatibilitySebastian Huber2018-12-271-2/+2
* leon, spwtdp: Initial driver commitJavier Jalle2018-10-091-0/+4
* drvmgr: Remove bsp_driver_level_hook()Sebastian Huber2018-04-201-6/+0
| | | | | | Use RTEMS_SYSINIT_ITEM() instead. Update #2408.
* Remove make preinstallChris Johns2018-01-254-0/+1485
