path: root/cpukit/include/dev/serial/sc16is752.h (unfollow)
2023-05-20Update company nameSebastian Huber1-1/+1
The embedded brains GmbH & Co. KG is the legal successor of embedded brains GmbH.
2022-03-25cpukit/include/dev: Change license to BSD-2Joel Sherrill1-3/+22
Updates #3053.
2022-03-10cpukit/: Scripted embedded brains header file clean upJoel Sherrill1-6/+0
Updates #4625.
2020-08-05dev/sc16is752: Fix declarationSebastian Huber1-1/+1
2019-06-14dev/sc16is752: Add set/get EFCR IO controlsSebastian Huber1-0/+10
2019-06-14dev/sc16is752: Add RS485 mode variantsSebastian Huber1-1/+12
2018-02-12dev/sc16is752: Add GPIO access via ioctl.Christian Mauderer1-0/+45
2018-01-25Remove make preinstallChris Johns1-0/+0
2016-12-16dev: Add NXP SC16IS752 serial device driverAlexander Krutwig1-0/+262
Update #2841.
