This function is used to perform a full check of the device tree. Allow
it to be excluded if all assumptions are enabled.
Signed-off-by: Simon Glass <sjg@chromium.org>
Reviewed-by: David Gibson <david@gibson.dropbear.id.au>
Message-Id: <20200220214557.176528-9-sjg@chromium.org>
Signed-off-by: David Gibson <david@gibson.dropbear.id.au>
Add a way to remove this check and the reordering code, which is
unnecessary if the dtb is known to be correctly ordered.
Message-Id: <20200220214557.176528-8-sjg@chromium.org>
Allow enabling FDT_ASSUME_LATEST to disable version checks.
Message-Id: <20200220214557.176528-7-sjg@chromium.org>
Allow enabling FDT_ASSUME_NO_ROLLBACK to disable rolling back after a
failed operation.
Message-Id: <20200220214557.176528-6-sjg@chromium.org>
Allow enabling ASSUME_VALID_INPUT to disable sanity checks on the device
tree and the parameters to libfdt. This assumption covers that cases where
the problem could be with either.
Message-Id: <20200220214557.176528-5-sjg@chromium.org>
Support ASSUME_VALID_DTB to disable some sanity checks
If we assume that the DTB itself is valid then we can skip some checks and
save code space. Add various conditions to handle this.
Message-Id: <20200220214557.176528-4-sjg@chromium.org>
Add a new ASSUME_MASK option, which allows for some control over the
checks used in libfdt. With all assumptions enabled, libfdt assumes that
the input data and parameters are all correct and that internal errors
cannot happen.
By default no assumptions are made and all checks are enabled.
Message-Id: <20200220214557.176528-3-sjg@chromium.org>
There does not seem to be a strong reason to inline this function. Also
we are about to add some extra code to it which will increase its size.
Move it into fdt.c and use a simple declaration in libfdt.h
Message-Id: <20200220214557.176528-2-sjg@chromium.org>
This function returns an int32_t, however the prototype in
libfdt_internal.h shows it returning an int. We haven't caught this before
because they're the same type on nearly all platforms this gets built on.
Apparently it's not the case on FreeRTOS, so someone hit this mismatch
building for that platform.
Reported-by: dharani kumar <dharanikumarsrvn@gmail.com>
c12b2b0c20eb "libfdt: fdt_address_cells() and fdt_size_cells()" introduced
a bug as it consolidated code between the helpers for getting
#address-cells and #size-cells. Specifically #size-cells is allowed to
be 0, and is frequently found so in practice for /cpus. IEEE1275 only
requires implementations to handle 1..4 for #address-cells, although one
could make a case for #address-cells == #size-cells == 0 being used to
represent a bridge with a single port.
While we're there, it's not totally obvious that the existing implicit
cast of a u32 to int will give the correct results according to strict C,
although it does work in practice. Straighten that up to cast only after
we've made our range checks.
Reported-by: yonghuhaige via https://github.com/dgibson/dtc/issues/28
In libfdt we often sanity test fdt_totalsize(fdt) fairly early, then
trust it (but *only* that header field) for the remainder of our work.
However, Coverity gets confused by this - it sees the byteswap in
fdt32_ld() and assumes that means it is coming from an untrusted source
everytime, resulting in many tainted data warnings.
Most of these end up with logic in fdt_get_string() as the unsafe
destination for this tainted data, so let's tweak the logic there to make
it clearer to Coverity that this is ok.
We add a sanity test on fdt_totalsize() to fdt_probe_ro_(). Because the
interface allows bare ints to be used for offsets, we already have the
assumption that totalsize must be 31-bits or less (2GiB would be a
ludicrously large fdt). This makes this more explicit.
We also make fdt_probe_ro() return the size for convenience, and change the
logic in fdt_get_string() to keep it in a local so that Coverity can see
that it has already been bounds-checked.
Replace instances of dual GPLv2 or BSD license boilerplate with SPDX tags.
Signed-off-by: Rob Herring <robh@kernel.org>
Message-Id: <20190620211944.9378-3-robh@kernel.org>
Searching for duplicate names scales O(n^2) with the number of names
added to a fdt, which can cause a noticable slowdown with larger device
trees and very slow CPU cores.
Add FDT_CREATE_FLAG_NO_NAME_DEDUP that allow the caller to trade fdt size
for speed in the creation process.
Signed-off-by: Nicholas Piggin <npiggin@gmail.com>
Message-Id: <20190509094122.834-4-npiggin@gmail.com>
There is a need to be able to specify some options when building an FDT
with the SW interface. This can be accomplished with minimal changes by
storing intermediate data in the fdt header itself, in fields that are
not otherwise needed during the creation process and can be set by
fdt_finish().
The fdt.magic field is already used exactly this way, as a state to
check with callers that the FDT has been created but not yet finished.
fdt.version and fdt.last_comp_version are used to make room for more
intermediate state. These are adjacent and unused during the building
process. last_comp_version is not yet used for intermediate state, but
it is zeroed and treated as used, so as to allow future growth easily.
A new interface, fdt_create_with_flags() is added, which takes 32-bit
flag value to control creation.
Message-Id: <20190509094122.834-3-npiggin@gmail.com>
If fdt_add_property or fdt_property_placeholder fail after allocating
a string for the name, they return without freeing that string. This
does not change the structure of the tree, but in very specific cases
it could lead to undesirable space consumption.
Fix this by rolling back the string allocation in this situation.
Message-Id: <20190509094122.834-2-npiggin@gmail.com>
It's now a trivial wrapper around fdt_find_max_phandle() so we might as
well inline it. We also remove it from the versioning linker script.
Theoretically, that's a breaking ABI change except that we haven't yet
released a version with it exposed in the shared object, so we can get
away with it.
The new fdt_generate_phandle() function can be used to generate a new,
unused phandle given a specific device tree blob. The implementation is
somewhat naive in that it simply walks the entire device tree to find
the highest phandle value and then returns a phandle value one higher
than that. A more clever implementation might try to find holes in the
current set of phandle values and fill them. But this implementation is
relatively simple and works reliably.
Also add a test that validates that phandles generated by this new API
are indeed unique.
Signed-off-by: Thierry Reding <treding@nvidia.com>
Message-Id: <20190326153302.17109-3-thierry.reding@gmail.com>
The fdt_get_max_phandle() function has some shortcomings. On one hand
it returns just a uint32_t which means to check for the "negative"
error code a caller has to explicitly check against the error code
(uint32_t)-1. In addition, the -1 is the only error code that can be
returned, so a caller cannot tell the difference between the various
failures.
Fix this by adding a new fdt_find_max_phandle() function that returns an
error code on failure and 0 on success, just like other APIs, and stores
the maximum phandle value in an output argument on success.
This also refactors fdt_get_max_phandle() to use the new function. Add a
note pointing out that the new fdt_find_max_phandle() function should be
preferred over fdt_get_max_phandle().
Message-Id: <20190326153302.17109-1-thierry.reding@gmail.com>
[dwg: Reword for some inaccuracies in the commit message]
This function will append an address range property using parent node's
"#address-cells" and "#size-cells" properties.
It will be used in implementing kdump with kexec_file_load system call
at linux kernel for arm64 once it is merged into kernel tree.
Signed-off-by: AKASHI Takahiro <takahiro.akashi@linaro.org>
Message-Id: <20190327061552.17170-2-takahiro.akashi@linaro.org>
[dwg: Correct a SEGV error in the testcase]
This reverts commit 54ea41c22415cb0e283d22faf71202051c89400c.
are indeed unique.
Message-Id: <20190320151003.28941-1-thierry.reding@gmail.com>
According to the device tree specification, the default value for
#size-cells is 1, but fdt_size_cells() was returning 2 if this property
was not present.
This patch also makes fdt_address_cells() and fdt_size_cells() conform
to the behaviour documented in libfdt.h. The defaults are only returned
if fdt_getprop() returns -FDT_ERR_NOTFOUND, otherwise the actual error
is returned.
Signed-off-by: John Clarke <johnc@kirriwa.net>
Add internal fdt_cells() to avoid copy and paste. Test error cases and
default values. Fix typo in fdt_size_cells() documentation comment.
Signed-off-by: Sebastian Huber <sebastian.huber@embedded-brains.de>
Close #3471.
At present fdt_create() will succeed if there is exactly enough space to
put in the fdt header. However, it sets the off_mem_rsvmap field, a few
bytes past that in order to align the memory reservation block.
Having block pointers pointing past the end of the fdt is pretty ugly, even
if it is just a transient state. Worse, if fdt_resize() is called at
exactly the wrong time, it can end up accessing data past the blob's
allocated space because of this.
So, correct fdt_create() to ensure that there is sufficient space for the
alignment padding as well as the plain header. For paranoia, also add a
check in fdt_resize() to make sure we don't copy data from outside the
blob's bounds.
At present this function appears to copy only the data before the struct
region and the data in the string region. It does not seem to copy the
struct region itself.
From the arguments of this function it seems that it should support fdt
and buf being different. This patch attempts to fix this problem.
This adds some helpers to load (32 or 64 bit) words from an fdt blob, even
if they're unaligned and we're on a platform that doesn't like plain
unaligned loads and stores. We then use the helpers in a number of places.
There are two purposes for this:
1) This makes libfdt more robust against a blob loaded at an unaligned
address. It's usually good practice to load a blob at a 64-bit
alignment, but it's nice to work even then.
2) Users can use these helpers to load integer values from within property
values. These can often be unaligned, even if the blob as a whole is
aligned, since some property encodings have integers and strings mixed
together without any alignment gaps.
This new function implements a complete and thorough check of an fdt blob's
structure. Given a buffer containing an fdt, it should return 0 only if
the fdt within is structurally sound in all regards. It doesn't check
anything about the blob's contents (i.e. the actual values of the nodes and
properties), of course.
Tested-by: Alexey Kardashevskiy <aik@ozlabs.ru>
Reviewed-by: Alexey Kardashevskiy <aik@ozlabs.ru>
Reviewed-by: Simon Glass <sjg@chromium.org>
We have a couple of places within libfdt and its tests where we need to
find the size of the header, based on the version. Add a helper function
for it.
fdt_num_mem_rsv() and fdt_get_mem_rsv() currently don't sanity check their
parameters, or the memory reserve section offset in the header. That means
that on a corrupted blob they could access outside of the range of memory
that they should.
This improves their safety checking, meaning they shouldn't access outside
the blob's bounds, even if its contents are badly corrupted.
fdt_getprop_by_offset() doesn't check for errors from fdt_string() - after
all, until very recently it couldn't fail. Now it can, so we need to
propagate errors up to the caller.
fdt_string() is used to retrieve strings from a DT blob's strings section.
It's rarely used directly, but is widely used internally.
However, it doesn't do any bounds checking, which means in the case of a
corrupted blob it could access bad memory, which libfdt is supposed to
avoid.
This write a safe alternative to fdt_string, fdt_get_string(). It checks
both that the given offset is within the string section and that the string
it points to is properly \0 terminated within the section. It also returns
the string's length as a convenience (since it needs to determine to do the
checks anyway).
fdt_string() is rewritten in terms of fdt_get_string() for compatibility.
Most of the diff here is actually testing infrastructure.
Currently fdt_check_header() performs only some rudimentary checks, which
is not really what the name suggests. This strengthens fdt_check_header()
to check as much about the blob as is possible from the header alone: as
well as checking the magic number and version, it checks that the total
size is sane, and that all the sub-blocks within the blob lie within the
total size.
* This broadens the meaning of FDT_ERR_TRUNCATED to cover all sorts of
improperly terminated blocks as well as just a structure block without
FDT_END.
* This makes fdt_check_header() only succeed on "complete" blobs, not
in-progress sequential write blobs. The only reason this didn't fail
before was that this function used to be called by many RO functions
which are supposed to also work on incomplete SW blobs.
When creating a tree with the sequential write functions, certain things
have to be done in a certain order. You must create the memory reserve map
and only then can you create the actual tree structure.
The -FDT_ERR_BADSTATE return code is for if you try to do things out of
order. However, we weren't checking that very thoroughly, so it was
possible to generate a corrupted blob if, for example, you started calling
fdt_begin_node() etc. before calling fdt_finish_reservemap().
This makes the state checking more thorough disallow that.
Many of the libfdt entry points call some sort of sanity check function
before doing anything else. These need to do slightly different things for
the various classes of functions.
The read-only version is shared with the exported fdt_check_header(), which
limits us a bit in how we can improve it. For that reason split the two
functions apart (though the exported one just calls the ro one for now).
We also rename the functions for more consistency - they're all named
fdt_XX_probe_() where the XX indicates which class of functions they're
for. "probe" is a better "term" than the previous check, since they really
only do minimal validation.
This can be useful in particular in the kernel when booting on systems
with FDT-emitting firmware that is out of date. Releases of kexec-tools
on ppc64 prior to the end of 2014 are notable examples of such.
Signed-off-by: Nathan Whitehorn <nwhitehorn@freebsd.org>
[dwg: Some whitespace cleanups]
In a lot of places libfdt uses a leading _ character to mark an identifier
as "internal" (not part of the published libfdt API). This is a bad idea,
because identifiers with a leading _ are generally reserved by the C
library or system. It's particularly dangerous for libfdt, because it's
designed to be able to be integrated into lots of different environments.
In some cases the leading _ has no purpose, so we simply drop it. In most
cases we move it to the end, as our new convention for marking internal
identifiers.
In some cases you need to add a property but the contents of it
are not known at creation time, merely the extend of it.
This method allows you to create a property of a given size (filled
with garbage) while a pointer to the property data will be provided.
Signed-off-by: Pantelis Antoniou <pantelis.antoniou@konsulko.com>
[dwg: Corrected commit message]
These were noticed when synching with U-Boot's downstream tree.
The existing function to add a new property to a tree being built requires
that the entire contents of the new property be passed in. For some
applications it is more convenient to be able to add the property contents
later, perhaps by reading from a file. This avoids double-buffering of the
contents.
Add a new function to support this and adjust the existing fdt_property() to
use it.
The standard way of setting an empty property using libfdt is:
fdt_setprop(fdt, nodeoffset, propname, NULL, 0);
However, the implementation of this includes an unconditional:
memcpy(prop->data, NULL, 0);
Which although it will be a no-op (which is what we want) on many platforms
is technically undefined behaviour. Correct this, so that when passing
a 0 length, passing a NULL pointer as the value to fdt_setprop() is
definitely safe. This should quiet static checkers which complain about
this.
Some error values were missing from the table which meant that they could
not be translated by fdt_strerror().
Signed-off-by: Benjamin Fair <b-fair@ti.com>
If fdt_getprop() fails, negative error code should be returned.
Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
There's one FDT_ERR_BADOVERLAY too many in the fdt error table.
Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
The BADPHANDLE error was missing a string, leading to an <unknown error>
string being returned if you were to call fdt_strerror.
