brains GmbH.
Since fdt_next_tag() in a public API function all input parameters,
including the fdt blob should not be trusted. It is possible to forge
a blob with invalid property length that will cause integer overflow
during offset calculation. To prevent that, validate the property length
read from the blob before doing calculations.
Signed-off-by: Tadeusz Struk <tadeusz.struk@linaro.org>
Message-Id: <20221005232931.3016047-1-tadeusz.struk@linaro.org>
Signed-off-by: David Gibson <david@gibson.dropbear.id.au>
There is no need to check the VALID_DTB repeatedly, and can be combined
into one if statement.
Signed-off-by: Jia Xianhua <jiaxianhua@gmail.com>
When fdt_get_string return null, `namep` is not correctly reset.
From the document of `fdt_getprop_by_offset`, the parameter `namep` will
be always overwritten (that is, it will be overwritten without exception
of error occurance).
As for the caller (like
https://github.com/topjohnwu/Magisk/blob/e097c097feb881f6097b6d1dc346f310bc92f5d6/native/jni/magiskboot/dtb.cpp#L42),
the code may be like:
```cpp
size_t size;
const char *name;
auto *value = fdt_getprop_by_offset(fdt, prop, &name, &size);
and if `value == nullptr`, `size` is also be overwritten correctly but
`name` is not, which is quite inconsistent.
This commit makes sure `name` and `size` behavior consistently (reset to
reasonable value) when error occurs.
Signed-off-by: LoveSy <shana@zju.edu.cn>
UINT32_MAX is an integer of type unsigned int. UINT32_MAX + 1 overflows
unless explicitly computed as unsigned long long. This led to some
invalid addresses being treated as valid.
Cast UINT32_MAX to uint64_t explicitly.
Signed-off-by: Elvira Khabirova <e.khabirova@omp.ru>
The ALIGNMENT error was missing a string, leading to <unknown error>
being returned.
Signed-off-by: Georg Kotheimer <georg.kotheimer@kernkonzept.com>
Coverity gets a bit confused by loading fdt_size_dt_strings() and
using it in a memmove(). In fact this is safe because the callers
have verified this information (via FDT_RW_PROBE() in fdt_pack() or
construction in fdt_open_into()).
Passing in strings_size like we already do struct_size seems to get
Coverity to follow what's going on here.
Only checking the FDT alignment in fdt_ro_probe_() means that
fdt_check_header() can pass, but then subsequent API calls fail on
alignment checks. Let's add an alignment check to fdt_check_header() so
alignment errors are found up front.
Cc: Tom Rini <trini@konsulko.com>
Cc: Frank Rowand <frowand.list@gmail.com>
Signed-off-by: Rob Herring <robh@kernel.org>
Message-Id: <20210406190712.2118098-1-robh@kernel.org>
Apparently the unchecked return value of the first fdt_next_tag() call in
fdt_add_subnode_namelen() is tripping Coverity Scan in some circumstances,
although it appears not to for the scan on our project itself.
This fdt_next_tag() should always return FDT_BEGIN_NODE, since otherwise
the fdt_subnode_offset_namelen() above would have returned BADOFFSET or
BADSTRUCTURE.
Still, add a check to shut Coverity up, gated by a can_assume() to avoid
bloat in small builds.
Reported-by: Ryan Long <ryan.long@oarcorp.com>
in fdt_open_into
Changes in v3:
- Remove noop version sets
- Set version correctly on loaded fdt in fdt_open_into
Fixes: f1879e1a50eb ("Add limited read-only support for older (V2 and V3) device tree to libfdt.")
Signed-off-by: Justin Covell <jujugoboom@gmail.com>
Message-Id: <20201229041749.2187-1-jujugoboom@gmail.com>
There's a small inaccuracy in the comment describing these new helpers.
This corrects it, and reformats while we're there.
Fixes: f98f28ab ("libfdt: Internally perform potentially unaligned loads")
Commits 6dcb8ba4 "libfdt: Add helpers for accessing unaligned words"
introduced changes to support unaligned reads for ARM platforms and
11738cf01f15 "libfdt: Don't use memcpy to handle unaligned reads on ARM"
improved the performance of these helpers.
On further discussion, while there are potential cases where we could be
used on platforms that do not fixup unaligned reads for us, making this
choice the default is very expensive in terms of binary size and access
time. To address this, introduce and use new fdt{32,64}_ld_ functions
that call fdt{32,64}_to_cpu() as was done prior to the above mentioned
commits. Leave the existing load functions as unaligned-safe and
include comments in both cases.
Reviewed-by: Rob Herring <robh@kernel.org>
Signed-off-by: Tom Rini <trini@konsulko.com>
Message-Id: <20201211022736.31657-1-trini@konsulko.com>
Tested-by: John Paul Adrian Glaubitz <glaubitz@physik.fu-berlin.de>
The device tree must be loaded in to memory at an 8-byte aligned
address. Add a check for this condition in fdt_ro_probe_() and a new
error code to return if we are not.
Message-Id: <20201104130605.28874-1-trini@konsulko.com>
With -Wsign-compare, compilers warn about a mismatching signedness
in a comparison in fdt_strerror().
Force FDT_ERRTABSIZE to be signed (it's surely small enough to fit), so
that the types match. Also move the minus sign to errval, as this is
actually what we use in the next line.
Signed-off-by: Andre Przywara <andre.przywara@arm.com>
Message-Id: <20201001164630.4980-7-andre.przywara@arm.com>
With -Wsign-compare, compilers warn about a mismatching signedness in
comparisons in fdt_get_string().
Introduce a new usigned variable, which holds the actual (negated)
stroffset value, so we avoid negating all the other variables and have
proper types everywhere.
Message-Id: <20201001164630.4980-6-andre.przywara@arm.com>
in a comparison in fdt_setprop_inplace_namelen_partial().
fdt_getprop_namelen() will only return negative error values in "proplen"
if the return value is NULL. So we can rely on "proplen" being positive
in our case and can safely cast it to an unsigned type.
Message-Id: <20201001164630.4980-5-andre.przywara@arm.com>
in a comparison in fdt_create_with_flags().
By making hdrsize a signed integer (we are sure it's a very small
number), we avoid all the casts and have matching types.
Message-Id: <20201001164630.4980-4-andre.przywara@arm.com>
in comparisons in fdt_move().
This stems from "bufsize" being passed in as a signed integer, even
though we would expect a buffer size to be positive.
Short of changing the prototype, check that bufsize is not negative, and
cast it to an unsigned type in the comparison.
Message-Id: <20201001164630.4980-3-andre.przywara@arm.com>
in a comparison in fdt_add_string_().
Make all variables unsigned, and express the negative offset trick via
subtractions in the code.
Message-Id: <20201001164630.4980-2-andre.przywara@arm.com>
in a comparison in fdt_node_offset_by_phandle().
Uses a better suited bitwise NOT operator to denote the special value of
-1, which automatically results in an unsigned type.
Message-Id: <20200921165303.9115-14-andre.przywara@arm.com>
in a comparison in fdt_resize().
A negative buffer size will surely do us no good, so let's rule this
case out first.
In the actual comparison we then know that a cast to an unsigned type is
safe.
Message-Id: <20200921165303.9115-10-andre.przywara@arm.com>
in a comparison in fdt_splice_().
Since we just established that oldlen is not negative, we can safely
Message-Id: <20200921165303.9115-8-andre.przywara@arm.com>
In the first two cases, we have just established that the signed values
are not negative, so it's safe to cast the values to an unsigned type.
Signed-off-by: Simon Glass <sjg@chromium.org>
Message-Id: <20200921165303.9115-7-andre.przywara@arm.com>
in a comparison in fdt_grab_space_().
All the involved values cannot be negative, so let's switch the types of
the local variables to unsigned to make the compiler happy.
Message-Id: <20200921165303.9115-4-andre.przywara@arm.com>
in comparisons in fdt_mem_rsv().
Since all involved values must be positive, change the used types to be
unsigned.
Message-Id: <20200921165303.9115-3-andre.przywara@arm.com>
With -Wsign-compare, compilers warn about mismatching signedness in
comparisons in fdt_offset_ptr().
This mostly stems from "offset" being passed in as a signed integer,
even though the function would not really tolerate negative values.
Short of changing the prototype, check that offset is not negative, and
use an unsigned type internally.
Message-Id: <20200921165303.9115-2-andre.przywara@arm.com>
fdt_check_node_offset_() checks for a valid offset but also changes the
offset by calling fdt_next_tag(). Hence, do not skip this function if
ASSUME_VALID_INPUT is set but only omit the initial offset check in that
case.
As this function works very similar to fdt_check_prop_offset_(), do the
offset check there as well depending on ASSUME_VALID_INPUT.
Message-Id: <1913141.TlUzK5foHS@noys4>
Signed-off-by: Patrick Oppenlander <patrick.oppenlander@gmail.com>
Message-Id: <20200618042117.131731-1-patrick.oppenlander@gmail.com>
This condition uses bitwise OR but should be logical OR. Fix it.
Reported-by: kernel test robot <lkp@intel.com>
Message-Id: <20200615160033.87328-1-sjg@chromium.org>
libfdt: fix undefined behaviour in fdt_splice_()
Along the lines of commit d0b3ab0a0f46 ("libfdt: Fix undefined behaviour
in fdt_offset_ptr()"), fdt_splice_() similarly may not use pointer
arithmetic to do overflow checks. (The left side of the checks added by
d4c7c25c9ed1 ["libfdt: check for potential overrun in _fdt_splice()"]
doesn't really lend itself to similar replacement though.)
Signed-off-by: Jan Beulich <jbeulich@suse.com>
Message-Id: <f2d09e81-7cb8-c5cc-9699-1ac05b0626ff@suse.com>
This error indicates a logic bug in the code calling libfdt, so VALID_DTB
is not really the right check. Update it to use VALID_INPUT instead.
Suggested-by: David Gibson <david@gibson.dropbear.id.au>
Message-Id: <20200302190255.51426-4-sjg@chromium.org>
If libfdt returns -FDT_ERR_INTERNAL that generally indicates a bug in the
library. Add a new assumption for these cases since it should be save to
disable these checks regardless of the input.
Message-Id: <20200302190255.51426-3-sjg@chromium.org>
Add a little more detail in a few of these comments.
Message-Id: <20200302190255.51426-2-sjg@chromium.org>
Fix 'saftey' and 'additional' typos noticed in the assumption series.
Reword the ASSUME_NO_ROLLBACK slightly to improve clarity.
Message-Id: <20200302190255.51426-1-sjg@chromium.org>
This function is used to perform a full check of the device tree. Allow
it to be excluded if all assumptions are enabled.
Reviewed-by: David Gibson <david@gibson.dropbear.id.au>
Message-Id: <20200220214557.176528-9-sjg@chromium.org>
Add a way to remove this check and the reordering code, which is
unnecessary if the dtb is known to be correctly ordered.
Message-Id: <20200220214557.176528-8-sjg@chromium.org>
Allow enabling FDT_ASSUME_LATEST to disable version checks.
Message-Id: <20200220214557.176528-7-sjg@chromium.org>
Allow enabling FDT_ASSUME_NO_ROLLBACK to disable rolling back after a
failed operation.
Message-Id: <20200220214557.176528-6-sjg@chromium.org>
Allow enabling ASSUME_VALID_INPUT to disable sanity checks on the device
tree and the parameters to libfdt. This assumption covers that cases where
the problem could be with either.
Message-Id: <20200220214557.176528-5-sjg@chromium.org>
Support ASSUME_VALID_DTB to disable some sanity checks
If we assume that the DTB itself is valid then we can skip some checks and
save code space. Add various conditions to handle this.
Message-Id: <20200220214557.176528-4-sjg@chromium.org>
Add a new ASSUME_MASK option, which allows for some control over the
checks used in libfdt. With all assumptions enabled, libfdt assumes that
the input data and parameters are all correct and that internal errors
cannot happen.
By default no assumptions are made and all checks are enabled.
Message-Id: <20200220214557.176528-3-sjg@chromium.org>
There does not seem to be a strong reason to inline this function. Also
we are about to add some extra code to it which will increase its size.
Move it into fdt.c and use a simple declaration in libfdt.h
Message-Id: <20200220214557.176528-2-sjg@chromium.org>
This function returns an int32_t, however the prototype in
libfdt_internal.h shows it returning an int. We haven't caught this before
because they're the same type on nearly all platforms this gets built on.
Apparently it's not the case on FreeRTOS, so someone hit this mismatch
building for that platform.
Reported-by: dharani kumar <dharanikumarsrvn@gmail.com>
c12b2b0c20eb "libfdt: fdt_address_cells() and fdt_size_cells()" introduced
a bug as it consolidated code between the helpers for getting
#address-cells and #size-cells. Specifically #size-cells is allowed to
be 0, and is frequently found so in practice for /cpus. IEEE1275 only
requires implementations to handle 1..4 for #address-cells, although one
could make a case for #address-cells == #size-cells == 0 being used to
represent a bridge with a single port.
While we're there, it's not totally obvious that the existing implicit
cast of a u32 to int will give the correct results according to strict C,
although it does work in practice. Straighten that up to cast only after
we've made our range checks.
Reported-by: yonghuhaige via https://github.com/dgibson/dtc/issues/28
In libfdt we often sanity test fdt_totalsize(fdt) fairly early, then
trust it (but *only* that header field) for the remainder of our work.
However, Coverity gets confused by this - it sees the byteswap in
fdt32_ld() and assumes that means it is coming from an untrusted source
everytime, resulting in many tainted data warnings.
Most of these end up with logic in fdt_get_string() as the unsafe
destination for this tainted data, so let's tweak the logic there to make
it clearer to Coverity that this is ok.
We add a sanity test on fdt_totalsize() to fdt_probe_ro_(). Because the
interface allows bare ints to be used for offsets, we already have the
assumption that totalsize must be 31-bits or less (2GiB would be a
ludicrously large fdt). This makes this more explicit.
We also make fdt_probe_ro() return the size for convenience, and change the
logic in fdt_get_string() to keep it in a local so that Coverity can see
that it has already been bounds-checked.
Replace instances of dual GPLv2 or BSD license boilerplate with SPDX tags.
Message-Id: <20190620211944.9378-3-robh@kernel.org>
