* | dev: Add NXP SC16IS752 serial device driver | Alexander Krutwig | 2016-12-16 | 6 | -0/+875 |
| | | | | Update #2841. | ||||
* | Add SPI bus framework | Alexander Krutwig | 2016-09-16 | 5 | -0/+877 |
| | | | | | | User API is compatible to Linux userspace API. New test libtests/spi01. Update #2776. | ||||
* | i2c: Fix return status of i2c dev read/write | Sebastian Huber | 2015-07-23 | 1 | -6/+10 |
* | cpukit/dev/include/dev/i2c/i2c.h: Fix Doxygen grouping | Joel Sherrill | 2015-03-09 | 1 | -0/+2 |
* | IMFS: Replace node union with individual struct | Sebastian Huber | 2015-01-27 | 2 | -18/+14 |
| | | | | | | This reduces the average node size. Add and use IMFS_GENERIC_INITIALIZER(). | ||||
* | i2c: Do not close file descriptor 0 if open fails | Sebastian Huber | 2014-11-26 | 1 | -7/+6 |
* | i2c: Avoid undefined right shift operation | Sebastian Huber | 2014-11-26 | 1 | -5/+8 |
* | cpukit/dev/i2c/i2c-dev.c: Fix leak on error path | Joel Sherrill | 2014-11-25 | 1 | -2/+1 |
| | | | | Coverity ID 1255520. fd was not closed on error path. | ||||
* | i2c: Fix endian issue | Sebastian Huber | 2014-11-24 | 1 | -9/+14 |
* | Add NXP PCA9548A 8-channel switch I2C driver | Sebastian Huber | 2014-11-20 | 4 | -0/+173 |
* | Add NXP PCA9535 16-bit GPIO I2C driver | Sebastian Huber | 2014-11-20 | 4 | -0/+278 |
* | Add generic EEPROM I2C device driver | Sebastian Huber | 2014-11-20 | 4 | -0/+324 |
* | Add I2C driver framework | Sebastian Huber | 2014-11-20 | 5 | -0/+1092 |
| | | | | | | | | | | | | | | | | | This I2C driver framework has some major differences compared to libi2c. * It is compatible to the Linux I2C user-space API. * It uses generic IMFS nodes and thus reduces the levels of indirection. * The drivers don't have to mess around with minor numbers to get their state information. * No arbitrary bus controller model is assumed. The main task of an I2C bus controller driver is to process I2C messages. How this is done is private to the driver. * Scatter/gather operations are supported (I2C_M_NOSTART). | ||||
* | Add RTEMS port of Linux I2C user-space API | Sebastian Huber | 2014-11-20 | 4 | -0/+456 |
