2023-05-20 | Update company name | Sebastian Huber | 1 | -1/+1 | |
The embedded brains GmbH & Co. KG is the legal successor of embedded brains GmbH. | |||||
2022-03-10 | cpukit/: Scripted embedded brains header file clean up | Joel Sherrill | 1 | -6/+0 | |
Updates #4625. | |||||
2020-04-16 | Canonicalize config.h include | Sebastian Huber | 1 | -2/+2 | |
Use the following variant which was already used by most source files: #ifdef HAVE_CONFIG_H #include "config.h" #endif | |||||
2017-10-02 | i2c: Fix EEPROM driver program timeout handling | Sebastian Huber | 1 | -4/+13 | |
The RTEMS_MILLISECONDS_TO_TICKS() macro doesn't round up. Do not use it to calculate the program timeout in ticks. Check program done condition after the timeout check to account for pre-emptions. Update #3162. | |||||
2017-10-02 | i2c: Send MSB of address first for EEPROMs | Sebastian Huber | 1 | -12/+21 | |
Update #3161. | |||||
2014-11-26 | i2c: Avoid undefined right shift operation | Sebastian Huber | 1 | -5/+8 | |
2014-11-20 | Add generic EEPROM I2C device driver | Sebastian Huber | 1 | -0/+260 | |
