* | Bump GCC_RPMREL. | Ralf Corsepius | 2009-03-11 | 1 | -1/+1 |
* | Disable sim on mingw32. | Ralf Corsepius | 2009-03-10 | 1 | -2/+2 |
* | Upgrade to gdb-6.8.50 | Ralf Corsepius | 2009-03-10 | 1 | -3/+3 |
* | Bump GDB_RPMREL. | Ralf Corsepius | 2009-02-24 | 1 | -1/+1 |
* | GCC_RPMREL = 8 | Ralf Corsepius | 2009-02-24 | 1 | -1/+1 |
* | Regenerate. | Ralf Corsepius | 2009-02-20 | 1 | -1/+1 |
* | Move %{?dist} handling to rtems4.10/*.am. | Ralf Corsepius | 2009-02-19 | 1 | -5/+5 |
* | Bump GCC_RPMREL, NEWLIB_RPMREL. | Ralf Corsepius | 2009-02-19 | 1 | -2/+2 |
* | Regenerate. | Ralf Corsepius | 2009-02-07 | 1 | -1/+1 |
* | Bump GCC_RPMREL, NEWLIB_RPMREL. | Ralf Corsepius | 2009-02-06 | 1 | -4/+4 |
| | | | | Rework CPUKIT*. | ||||
* | Bump GCC_RPMREL, NEWLIB_RPMREL to rebuild against binutils-2.19.1 | Ralf Corsepius | 2009-02-03 | 1 | -2/+2 |
* | Upgrade to binutils-2.19.1 | Ralf Corsepius | 2009-02-03 | 1 | -2/+2 |
* | Bump GCC_RPMREL, NEWLIB_RPMREL. | Ralf Corsepius | 2009-02-03 | 1 | -2/+2 |
* | Bump GDB_RPMREL. | Ralf Corsepius | 2009-01-26 | 1 | -1/+1 |
* | NEWLIB_RPMREL = 22%{?dist} | Ralf Corsepius | 2009-01-26 | 1 | -1/+1 |
* | GCC_VERS = 1%{?dist} | Ralf Corsepius | 2009-01-26 | 1 | -1/+1 |
* | GCC_VERS = 4.3.3 | Ralf Corsepius | 2009-01-26 | 1 | -1/+1 |
* | Bump GCC_RPMREL. | Ralf Corsepius | 2009-01-26 | 1 | -1/+2 |
| | | | | Add NEWLIB_RPMREL. | ||||
* | Bump GDB_RPMREL. | Ralf Corsepius | 2009-01-22 | 1 | -1/+1 |
* | newlib-1.17.0 | Ralf Corsepius | 2008-12-23 | 1 | -3/+3 |
* | Bump GDB_RPMREL. | Ralf Corsepius | 2008-12-17 | 1 | -1/+1 |
* | Update to newlib-1.16.0.cvs.20081216. | Ralf Corsepius | 2008-12-16 | 1 | -2/+2 |
* | newlib-1.16.0.cvs.20081212 | Ralf Corsepius | 2008-12-12 | 1 | -2/+2 |
* | GCC_RPMREL = 17, newlib-1.16.0.cvs.20081205. | Ralf Corsepius | 2008-12-05 | 1 | -2/+2 |
* | newlib-1.16.0.cvs.20081128. | Ralf Corsepius | 2008-11-28 | 1 | -2/+2 |
* | newlib-1.16.0.cvs.20081127 | Ralf Corsepius | 2008-11-27 | 1 | -1/+1 |
* | Bump GCC_RPMREL = 15%{?dist}. | Ralf Corsepius | 2008-11-27 | 1 | -1/+1 |
* | GCC_RELVER = 14%{?dist}. | Ralf Corsepius | 2008-11-25 | 1 | -2/+2 |
| | | | | NEWLIB_PKGVERS = $(NEWLIB_VERS).cvs.20081125. | ||||
* | newlib-1.16.0.cvs.20081124. | Ralf Corsepius | 2008-11-25 | 1 | -2/+2 |
| | | | | GCC_RPMREL = 13%{?dist}. | ||||
* | GCC_RPMREL = 12%{?dist}. | Ralf Corsepius | 2008-11-24 | 1 | -2/+2 |
* | Preps for newlib-cvs. | Ralf Corsepius | 2008-11-19 | 1 | -1/+2 |
| | | | | Bump GCC_RPMREL. | ||||
* | Bump GCC_RPMREL. | Ralf Corsepius | 2008-11-10 | 1 | -1/+1 |
* | Bump GCC_RPMREL. | Ralf Corsepius | 2008-11-07 | 1 | -1/+1 |
* | Update. | Ralf Corsepius | 2008-11-05 | 1 | -1/+1 |
* | Bump BINUTILS_RPMREL. | Ralf Corsepius | 2008-10-28 | 1 | -1/+1 |
* | binutils-2.19. | Ralf Corsepius | 2008-10-23 | 1 | -2/+2 |
* | Bump GDB_RPMREL. | Ralf Corsepius | 2008-10-16 | 1 | -1/+1 |
* | Bump BINUTILS_RPMREL. | Ralf Corsepius | 2008-10-16 | 1 | -1/+1 |
* | BINUTILS_VERS = 2.18.93 | Ralf Corsepius | 2008-10-10 | 1 | -1/+1 |
* | Update to binutils-2.18.92. | Ralf Corsepius | 2008-10-04 | 1 | -2/+2 |
* | GCC_RPMREL = 6. Disable cxx, infos. | Ralf Corsepius | 2008-10-03 | 1 | -2/+2 |
* | Bump GDB_RPMREL. | Ralf Corsepius | 2008-10-03 | 1 | -1/+1 |
* | Build binutils infos. | Ralf Corsepius | 2008-10-03 | 1 | -1/+1 |
* | New. | Ralf Corsepius | 2008-10-03 | 1 | -0/+30 |
