configure scripts did not match on the default value of --enable-tests.
on BSPs that install there own tools.
rtems-rc-19990326-2.diff: Enhancements to autoconf support for librdbg
* autoconf-checks for AWK and RPCGEN
* disable librdbg if either AWK, RPCGEN or librdbg/$target_cpu
cannot be found
releasing a snapshot:
1. Cleanup to aclocal/
cvs rm -f aclocal/cygwin.m4
cvs rm -f aclocal/exeext.m4
2. rtems-rc-19990328-0.diff
Some (minor) bug-fixes:
3. rtems-rc-19990328-1.diff
-ac -am -ci.
(reduces size of configure.in
description follows:
Description:
config.h.ins)
acpolish
configure scripts
Remarks:
[$(prefix)].
issues.
egcs/contrib/egcs_update).
ATTENTION:
* "make RTEMS_BSP=<bsp> dist"
OK, I 've made up my mind to cut a big chunk of my automake-patches (:-).
Below you can find a drop-in replacement of the aclocal directory. It
contains a lot of new macro files, most of them are directly cut from rtems
top-level configure script, some are new some are identical to former
versions. The motivation behind these files is to reuse parts from rtems
current top-level configure.in script in up-coming subdirectory configure.in
scripts.
I'd like to ask you to untar the archive ontop of the source tree and to
add/commit these files to CVS. Adding these files should not have any
influence on RTEMS momentary configuration (except of you are required to
run aclocal -I aclocal && autoconf afterwards), because most of them
currently are not used at all.
BTW: Please upgrade to autoconf-2.13 and automake-2.4, if you havn't done
this already (egcs/CVS require them, too). My upcoming automake files
require automake-2.4 which requires autoconf-2.13 or later.
<ccj@acm.org>.
--enable-tests flag.
automake:
* I didn't yet touch the cpu subdirectory. I still need some time to
think on how to handle them.
* I probably will wait for the next snapshot before mailing more patches
(I still have some pending), giving you a chance to apply them and me a
chance to become target of the bullets which will probably be aimed at
me after these modifications.
all conflicts.
Hello,
host :
- one for RTEMS it self,
- one for GDB-4.17.
1/ RTEMS patch
This patch adds 2 libraries :
- the Remote Debugger library
--enable-rdbg
rtems_rdbg_initialize ();
2/ GDB-4.17 patch
To connect to a target, use :
And... Debug ;)
PROBLEMS
can/will be fixed.
it work.
with libchip.
scripts (make/rtems.cfg)
Testing:
2. "make profile" doesn't work. It aborts when building host-tools
for embedded targets. I didn't yet have enough time to fix this
problem. AFAIS this problem is related to handling of
LDFLAGS_PROFILE[|_V] in gcc.cfg.in. For host applications, we use
gcc for linking host applications, too. With profiling enabled
CFLAGS_PROFILE_V contains -pg and is used to compile, but
LDFLAGS_PROFILE_V is empty, hence -pg will not be passed to the
linker causing gcc to fail to link, because it can't resolve some
symbols introduced by compiling with -pg.
I am not sure if I can provide a patch for this - Ether it is trivial
to fix or requires basic work on host configuration ;-
Fixing this one was trivial - But hard to trace.
LDFLAGS_PROFILE_V needs to contain the same flags as CFLAGS_PROFILE_V,
if gcc is used for linking (What else should have been expected ?,
:-). The same problem was present for *_DEBUG_V, but apparently wasn't
noticed by anybody, because things didn't break, but were silently
ignored.
I fixed these problems by setting these flags in configure.in whenever
gcc is reported to be the host-compiler. For non-gcc host compilers
"make debug" and "make profile" now becomes the same as an ordinary
"make". This is a hack and addressing this problen could be more
sophisticated, but I don't think it gives much sense to support
compile variants for any host program (Who will ever try to
profile/debug host tools?). Therefore I don't think it's useful
to invest more effort into this problem.
As mentioned in other mails before, there is are minor inconsistencies in the
posix custom/*cfg files.
Linux-posix.cfg sets RTEMS_BSP=posix
FreeBSD-posix.cfg sets RTEMS_BSP=posix
Solaris-posix.cfg first sets RTEMS_BSP=posix, later it sets
RTEMS_BSP=solaris2
1. Setting RTEMS_BSP=posix is redunant to settings in default.cfg
2. The solaris variant of setting RTEMS_BSP is merely non-functional.
The patch attached to this mail should clean up this issue.
The patch was tested by building the posix bsp under
i686-pc-linux-glibc1/glibc2 and Solaris2.6 (I did not run any
rtems program, however) The HPUX9 and FreeBSD configuration files
were adapted in analogy to the solaris and linux configurations.
test were suggested by Ian Taylor <ian@airs.com> and Joel did the
hard part of putting it in aclocal and editting all the offending
Makefiles and source code which could use this feature.
Here is another patch to hopefully enhance rtems' configuration.
Motivation: Try to support other c-compilers besides gcc (I tried to
build rtems under Solaris using sun's WSPro c-compiler).
Here is a couple of small patches concerning the host compiler
configuration, which fix/work-around the worst problems when using sun's
WSPro c-compiler.
* Replaced make/compilers/gcc.cfg with make/compilers/gcc.cfg.in, ie.
gcc.cfg is generated by configure now.
* Removed a line containing a hard-coded "gcc" from gcc.cfg (BUG-fix).
* Add -g to host compiler flags only if configure reported -g to work
* Add -Wall to host compiler flags only if configure reported that the
host compiler is gcc (WSPro's cc chokes on -Wall).
* Some modifications to make/Makefile.in
* Adapted make/custom/default.cfg to the new location of gcc.cfg
BTW, gcc.cfg/gcc.cfg.in seems to be full of unused code (DEBUG-VARIANTS
etc.) which deserves to be cleaned up, IMO.
IMO, a similar patch should be applied to gcc-target-default.cfg
It fixes netboot build problem, KA9Q configuration
for pc386, some compiler wardning, it also removed some stuff
ifdef'ed with '#if 0'.
BSDINSTALL=@INSTALL@
in autoconf.
fixed.
when the bare bsp was enabled without setting both --enable-cpu-model
and --enable-cpu-cflags.
of theses targets...
<corsepiu@faw.uni-ulm.de> which attempts to detect when the UNIX port
is being configured on a system without System V IPC support. This
is an optional component on both FreeBSD and Linux systems. Most
Linux 2.x kernels ship with it enabled but it is still a real risk.
This test may have undesirable side-effects on some hosts. We will
address those conflicts as they arise.
one of the aclocal macros.
all the targets:
breaking CXX support.
handling.
after minor changes.)
insecure about.
external packages.
may be broken).
disturb now.
--enable-* flags).
--enable-gcc28 are given.
mvme162.cfg-bug.
a BSP source directory was present to eliminate a chunk of redundant code.
Bare BSP is now only enabled when explicitly specified.
Bare BSP options and variables are clearly named so as to be obviously
BSP specific. This should avoid conflicts.
support.
followed GNU conventions.
