path: root/configure (follow)
* A patch from Ralf Corsepius <corsepiu@faw.uni-ulm.de>:Joel Sherrill1998-08-211-42/+51
| | | | | | | | | | | | | | | | | | | | | | | | | | Here is another patch to hopefully enhance rtems' configuration. Motivation: Try to support other c-compilers besides gcc (I tried to build rtems under Solaris using sun's WSPro c-compiler). Here is a couple of small patches concerning the host compiler configuration, which fix/work-around the worst problems when using sun's WSPro c-compiler. Changes: * Replaced make/compilers/gcc.cfg with make/compilers/gcc.cfg.in, ie. gcc.cfg is generated by configure now. * Removed a line containing a hard-coded "gcc" from gcc.cfg (BUG-fix). * Add -g to host compiler flags only if configure reported -g to work * Add -Wall to host compiler flags only if configure reported that the host compiler is gcc (WSPro's cc chokes on -Wall). * Some modifications to make/Makefile.in * Adapted make/custom/default.cfg to the new location of gcc.cfg BTW, gcc.cfg/gcc.cfg.in seems to be full of unused code (DEBUG-VARIANTS etc.) which deserves to be cleaned up, IMO. IMO, a similar patch should be applied to gcc-target-default.cfg
* Patches from Eric NorumJoel Sherrill1998-08-201-147/+120
* Updated to reflect stack transition.Joel Sherrill1998-08-201-1/+1
* FreeBSD stack compiles for the first time (except libc/strsep.c)Joel Sherrill1998-08-201-119/+163
* Patch from Aleksey <qqi@world.std.com>:Joel Sherrill1998-08-191-37/+37
| | | | | | It fixes netboot build problem, KA9Q configuration for pc386, some compiler wardning, it also removed some stuff ifdef'ed with '#if 0'.
* Patches from Ralf Corsepius <corsepiu@faw.uni-ulm.de> and myself toJoel Sherrill1998-08-191-1/+9
| | | | | | | | | | | | | | | | | | | | | | | | make solaris target buildable. > 1. The ipc check fails since solaris does not define union semun. > The unix port code actually defines this type itself on solaris. Doing > the same thing lets it get configured. Then... > 2. It looks like BSDINSTALL is not defined properly. BSDINSTALL is defined in make/host.cfg.in as BSDINSTALL=@INSTALL@ @INSTALL@ is generated by autoconf's standard macro AC_PROG_INSTALL, which is widely used in almost any autoconf/automake configured package. In case there is really something wrong with it, then it must be considered a bug in autoconf. I can see a doubious fragment in AC_PROG_INSTALL, which is used when no appropriate bsd-install is found. Finally Ralf saw a problem with the find on solaris which I also saw and fixed.
* Per request from Chris Johns <ccj@acm.org>, I added code to detectJoel Sherrill1998-08-131-25/+35
| | | | | when the bare bsp was enabled without setting both --enable-cpu-model and --enable-cpu-cflags.
* Patch from Eric VALETTE <valette@crf.canon.fr>:Joel Sherrill1998-07-231-21/+36
| | | | | | | | | | | | | Here is a enhanced version of my previous patch. This patch enables to potentially share the new interrupt management code for all Intel targets (pc386, go32 and force386) bsp. Note : this patch is complete only for pc386. It still needs to be completed for go32 and force386. I carrefully checked that anything needed is in for force386 (only some function name changes for IDT manipulation and GDT segment manipulation). But anyway I will not be able to test any of theses targets...
* Patch from Dario Alcocer <alcocer@connectnet.com> and Ralf CorsepiusJoel Sherrill1998-07-231-27/+176
| | | | | | | | | | <corsepiu@faw.uni-ulm.de> which attempts to detect when the UNIX port is being configured on a system without System V IPC support. This is an optional component on both FreeBSD and Linux systems. Most Linux 2.x kernels ship with it enabled but it is still a real risk. This test may have undesirable side-effects on some hosts. We will address those conflicts as they arise.
* Regenerated.Joel Sherrill1998-07-171-95/+163
* Regenerated after patch from David Fiddes <D.J.Fiddes@hw.ac.uk> forJoel Sherrill1998-07-101-7/+7
| | | | one of the aclocal macros.
* Removed rtems-glom as a generated file. Regenerated aclocal.m4 and configure.Joel Sherrill1998-07-071-2/+0
* Monstrous patch from Ralf Corsepius <corsepiu@faw.uni-ulm.de>. I haveJoel Sherrill1998-06-271-96/+546
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | made no attempt to divide the comments up and place them with just the appropriate files. Here is an excerpt from Ralf's email: Changes including comments on changes I made after cycling through all the targets: * Added ranlib support. Now all targets use "ranlib" instead of "ar -s" to build an index for a library. If ranlib isn't detected during configuration, check if ar -s is working and try "ar -s" instead of * Removed $(XXX_FOR_TARGET) from make/target.cfg.in, use $(XXX) instead now. * gcc-target-default.cfg: LINK_XXXX-defines reworked to solve the -l problem under posix (cf gcc-target-default.cfg) * rtems-glom replaced by Makefile-rules inside of the wrapup/Makefile.in that has been using rtems-glom until now. * Removed CCC and friends in gcc-target-default.cfg, as they have been breaking CXX support. * Removed CONFIG.$(TARGET_ARCH).CC lines from several custom/*.cfg files, because this is now set in custom/default.cfg. * Added aclocal/ar-s.m4, check whether "ar -s" is working * Added aclocal/cygwin.m4 and aclocal/exeext.m4. * Reworked aclocal/canonicalize-tools.m4: Added ar -s check; fixes for problems when XXX_FOR_TARGET is given via environment variables (didn't work for gcc until now), adding cygwin check, improved autoconf-cache handling. * Removed -l from make rule dependencies. LINK_LIBS is now allowed to contain -L and -l. LINK_OBJS and LINK_FILES must not contain -L or -l. gcc28 make-exe rules now link using $(LINK_OBJS) $(LINK_LIBS) => Almost all custom/*.cfg are modified. This is very likely to break something because of typos or having missed to edit a file. Open problems, known bugs, things I didn't do: * custom/p4000.cfg seems to be out of date and requires to be reviewed. (JRS NOTE: It is subordinate p4650 and p4600 -- both of which build ok after minor changes.) * custom/psim.cfg needs to be reviewed, I added some changes to it, I am insecure about. (JRS NOTE: psim had a minor problem endif/endef swapped but runs fine.) * rtems-glom.in can now be removed. * gcc*.cfg files "make depend" rules don't honor language specific flags (e.g CXXFLAGS is ignored for *.cc) - Nothing to worry about now, but may cause problems for hosts/targets not using gcc or rtems-add-ons that use external packages. * AFAIS, the no_bsp BSP can't be build anymore, i.e. configure refused to configure for it whatever I tried. * The toplevel and toplevel+1 README files are quite out-dated * cygwin.m4 isn't of much use for rtems. In most cases (cf. aclocal/*.m4) it is worked around by directly using $host_os. I think I'll remove it soon after the next snapshot * Before release the cygwin patch needs to be tested under cygwin. I may have broken/missed something (esp. the sed-pattern to convert \\ into / may be broken). * You should try to build/run the posix-BSP under solaris - I don't expect problems, but I am not 100% sure, esp. with regard to ranlib/ar -s. * You should consider to convert all make/compilers/*.cfg files into make/compilers/*.cfg.in files and let autoconf generate the *.cfg. This may help getting rid of some if/then/else statements and help hard-coding some defines into those files in future and shouldn't disturb now. * Not having installed libc.a/libm.a on a host may still break building rtems, esp. when using -disable-gcc28 as the gcc27-configuration scheme directly accesses libc.a and libm.a. The problem should not appear when using gcc28 because it references libc/libm only through -lc and -lm which may be static or dynamic (I didn't test this). * shgen is not yet included (I didn't yet have enough time to integrate it). * I know about a few more configure-probs (esp. cross-checking --enable-* flags). + warn/refuse to configure when --enable-libcdir and --enable-gcc28 are given. + force --enable-libcdir when --disable-gcc28 is given * Replaced KSHELL with @KSH@ in some shell scripts generated by configure.in. * Added a dependency to aclocal/*.m4 in the toplevel Makefile => configure and aclocal.m4 will now be rebuild when any aclocal/*.m4 file is changed * Some changes to aclocal/gcc-pipe.m4 and aclocal/gcc-specs.m4 * Replaced i[[3456]]86-unknown-freebsd2.[[12]] with i[[3456]]86-*freebsd2.* in configure.in, as I suppose there might exist a variety of valid vendors (2nd field of the name-tripple) * Disabled override MAKEFLAGS in toplevel Makefile.in - Potential side-effects are not really clear to me. * In mvme162.cfg, $(LINK_LIBS) is missing in the CC line in gcc28's make-exe rule (yet another one I missed to edit). Just append $(LINK_LIBS) to the "CC" line, like I hopefully did to ALL other custom/*.cfg files. * the problem with mvme162lx.cfg is a follow-up problem of the mvme162.cfg-bug. * mvme162/console and idp/console had variables named Buffer which conflicted with similarly named variables in some tests.
* Bare bsp patch from Chris Johns and regenerated files.Joel Sherrill1998-06-251-6/+6
* Added freebsd support from Dario Alcocer <alcocer@connectnet.com>.Joel Sherrill1998-06-181-66/+72
* Regenerated aclocal and configure after cleaning up the check thatJoel Sherrill1998-06-041-67/+40
| | | | a BSP source directory was present to eliminate a chunk of redundant code.
* ppc-rtems is now an alias for powerpc-rtems.Joel Sherrill1998-06-031-2/+2
* Regenerated.Joel Sherrill1998-05-271-48/+47
* hppa1.1 -> hppa1_1 remapping crept back in somehow -- gona again.Joel Sherrill1998-05-221-83/+82
| | | | | | | Bare BSP is now only enabled when explicitly specified. Bare BSP options and variables are clearly named so as to be obviously BSP specific. This should avoid conflicts.
* Added bare bsp from Chris Johns <cjohns@plessey.com.au>.Joel Sherrill1998-05-211-97/+171
* Regenerated.Joel Sherrill1998-05-211-234/+157
* Support bsp_specs style building for linux and solaris. Improved C++Joel Sherrill1998-05-181-102/+85
| | | | support.
* Fixed bug where posix tests were not being enabled.Joel Sherrill1998-04-271-1/+1
* Ralf Corsepius suggested a way to get rid of UNIX compiler files and use ↵Joel Sherrill1998-04-141-73/+79
* Patch from Samuel Tardieu <sam@inf.enst.fr> so the messages printedJoel Sherrill1998-04-031-4/+4
| | | | followed GNU conventions.
* Renamed hppa1_1 to hppa1.1Joel Sherrill1998-03-231-74/+71
* renamed ppc to powerpcJoel Sherrill1998-03-231-74/+71
* *** empty log message ***Joel Sherrill1998-03-231-101/+67
* Fixed RTEMS_PROG_CC_WORKS and RTEMS_PROG_CXX_WORKS so they couldJoel Sherrill1998-03-211-68/+99
| | | | successfully work on powerpc-rtems and hppa1.1-rtems.
* Patch from Ralf Corsepius to properly detect that Cygwin32 does notJoel Sherrill1998-03-201-66/+75
| | | | support the -pipe option on the compiler.
* Updated so test tools are installed even when --disable-tests isJoel Sherrill1998-02-191-20/+21
| | | | specified. Otherwise a target specific runtest is not installed.
* Ralf Corsepius pushing us farther down the autconf path:Joel Sherrill1998-02-171-0/+2
| | | | | | | | | | "Ladies and Gentlement, we proudly present: a roughly hacked autoconf-ed rtems-glom.in" (:-) BTW, to follow up to the discussion about installation points, rtems-glom in its current shape is an ideal example of a target dependent file. If bsp-specific configure-scripts would exist, it might also be a bsp-dependent file that contains RTEMS_BSP hard-coded (by configure) into it.
* Update from Ralf Corsepius:Joel Sherrill1998-02-171-120/+990
| | | | | | | | | | | | Yep, I have a bunch of bug-fixes and additions pending (Yet another monster patch, ... I can hear you scream :-). 1) configure.in : one AC_CONFIG_HEADER(...) line too much. 5) configure.in: --enable-cpp should probably be renamed to --enable-cxx, as gnu-programs use "cxx" to specify C++ specific configure options, while cpp is used for the preprocessor (e.g egcs uses --with-cxx-includedir, autoconf internally uses $CXX),
* Fixed hppa1.1 configuration.Joel Sherrill1998-02-111-3/+3
* Removed special ix86-rtems stanza.Joel Sherrill1998-02-041-32/+29
* Big patch form Ralf Corsepius described in this email:Joel Sherrill1998-01-301-22/+21
* configure.inJoel Sherrill1998-01-301-16/+111
* Reverted change ...Joel Sherrill1998-01-221-2/+2
* Corrected/simplified setting of RTEMS_ROOT.Joel Sherrill1998-01-221-2/+2
* Added autoconf support for strerror/sys_errlist per Ralf Corsepius'Joel Sherrill1998-01-211-37/+94
| | | | | direction. This fixes a problem reported by Steve Evans of Radstone since he is using glibc2.
* Fixed libhwapi to reflect eeprom to non volatile memory rename.Joel Sherrill1998-01-201-16/+16
* Ralf Corsepius reported a number of missing CVS Id's:Joel Sherrill1998-01-161-24/+24
| | | | | | | | | | > RTEMS is under CVS control and has been since rtems 3.1.16 which was > around May 1995. So I just to add the $Id$. If you notice other files > with missing $Id$'s let me know. I try to keep w\up with it. Now that you have asked -- I'll attach a list of files lacking an RCS-Id to this mail. This list has been generated by a little sh-script I'll also enclose.
* Added "done" to end of list of BSPs found.Joel Sherrill1998-01-151-1/+1
* Fixed code for --disable-rtems-inlines so that it would completeJoel Sherrill1998-01-151-21/+32
| | | | | | | configuration successfully. Added code to detect configuring macros and POSIX API at the same time. There is no macro implementation for the POSIX API.
* Made --enable-gcc28 the default.Joel Sherrill1997-12-221-1/+1
* Added size_rtems as a generated file.Joel Sherrill1997-12-221-0/+2
* Changed RTEMS_BSP to RTEMS_BSP_LIST.Joel Sherrill1997-12-161-24/+23
* Modified a lot of files to take a first cut at supporting building fromJoel Sherrill1997-12-101-25/+33
* Redid hwapi makefile search to remove need for -follow option to find.Joel Sherrill1997-12-061-39/+139
| | | | Avoid generating Makefiles for KA9Q and C++ when they are disabled.
* Added better/more correct support for Linux and Solaris simulators.Joel Sherrill1997-12-041-23/+41
