* | Thread iterator and libgjc support submitted too early. | Joel Sherrill | 2000-06-14 | 25 | -2025/+10 |
* | Fix typo. | Joel Sherrill | 2000-06-14 | 1 | -1/+1 |
* | Added crude i960ka support. | Joel Sherrill | 2000-06-13 | 3 | -6/+38 |
* | Pickup console-polled.c from the libbsp/shared directory. | Joel Sherrill | 2000-06-13 | 1 | -0/+2 |
* | Removing clock and timer since this BSP does not currently | Joel Sherrill | 2000-06-13 | 1 | -2/+0 |
| | | | | have them. | ||||
* | Prototypes for cache manager support functions now agree. | Joel Sherrill | 2000-06-13 | 2 | -7/+3 |
* | New file. | Joel Sherrill | 2000-06-13 | 1 | -0/+137 |
* | Moved i386 and m68k cache management code to libcpu. Everything | Joel Sherrill | 2000-06-13 | 25 | -579/+605 |
| | | | | | | now is an implementation of the prototypes in rtems/rtems/cache.h. The libcpu/i386/wrapup directory is no longer needed. The PowerPC needs this done to it. | ||||
* | Added .cvsignore. | Joel Sherrill | 2000-06-13 | 6 | -0/+12 |
* | Added .cvsignore. | Joel Sherrill | 2000-06-13 | 11 | -0/+33 |
* | Added .cvsignore files. | Joel Sherrill | 2000-06-13 | 2 | -0/+15 |
* | Accounted for 1 task used. | Joel Sherrill | 2000-06-13 | 1 | -0/+1 |
* | Removed unused directories from Makefile.am and warnings | Joel Sherrill | 2000-06-13 | 3 | -1/+17 |
| | | | | from cvs by adding .cvsignore files. | ||||
* | Temporary hack to compile. Need to probably address definition | Joel Sherrill | 2000-06-13 | 3 | -0/+3 |
| | | | | of all FIO constants and conflict with libnetworking code. | ||||
* | Temporary hack to compile. | Joel Sherrill | 2000-06-13 | 2 | -2/+0 |
* | Patch from John Cotton <john.cotton@nrc.ca>, Charles-Antoine Gauthier | Joel Sherrill | 2000-06-12 | 43 | -7762/+0 |
| | | | | | | | | | | | | | | | <charles.gauthier@iit.nrc.ca>, and Darlene A. Stewart <Darlene.Stewart@nrc.ca> to add support for a number of very significant things: + BSPs for many variations on the Motorola MBX8xx board series + Cache Manager including initial support for m68040 and PowerPC + Rework of mpc8xx libcpu code so all mpc8xx CPUs now use same code base. + Rework of eth_comm BSP to utiltize above. John reports this works on the 821 and 860. | ||||
* | Fixed so hppa1.1 compiles with only problems in simhppa BSP. | Joel Sherrill | 2000-06-12 | 3 | -6/+16 |
* | Patch from John Cotton <john.cotton@nrc.ca>, Charles-Antoine Gauthier | Joel Sherrill | 2000-06-12 | 15 | -0/+1790 |
| | | | | | | | | | | | | | | | <charles.gauthier@iit.nrc.ca>, and Darlene A. Stewart <Darlene.Stewart@nrc.ca> to add support for a number of very significant things: + BSPs for many variations on the Motorola MBX8xx board series + Cache Manager including initial support for m68040 and PowerPC + Rework of mpc8xx libcpu code so all mpc8xx CPUs now use same code base. + Rework of eth_comm BSP to utiltize above. John reports this works on the 821 and 860 | ||||
* | Patch from John Cotton <john.cotton@nrc.ca>, Charles-Antoine Gauthier | Joel Sherrill | 2000-06-12 | 102 | -470/+12509 |
* | Ensure that when -msoft-float is specified for multilib builds, that | Joel Sherrill | 2000-06-12 | 1 | -1/+2 |
| | | | | | something indicates this. Eventually this needs to be merged into gcc. | ||||
* | Works on Solaris and Linux. | Joel Sherrill | 2000-06-12 | 1 | -8/+6 |
* | Removed references to printk as part of moving it to a more shareable | Joel Sherrill | 2000-06-12 | 6 | -171/+6 |
| | | | | location in libc. | ||||
* | Added printk as a generic, shared routine. | Joel Sherrill | 2000-06-12 | 7 | -3/+367 |
* | New file. This is a simple termios console driver which is sufficient | Joel Sherrill | 2000-06-12 | 1 | -0/+148 |
| | | | | to do polled IO on a single port with VERY little support code. | ||||
* | Added i960sim BSP which (ignoring the 3 instructions not supported | Joel Sherrill | 2000-06-12 | 18 | -0/+641 |
| | | | | by gdb 5.0's i960 simulator) is enough to run hello world. | ||||
* | Merge lossage. Apparently the DOS/UNIX CRLF issue got lost. | Joel Sherrill | 2000-06-12 | 1 | -1438/+1438 |
* | Merged from 4.5.0-beta3a | Joel Sherrill | 2000-06-12 | 1431 | -10240/+81752 |
* | New file. | Joel Sherrill | 2000-05-24 | 1 | -0/+0 |
* | New file added on 4.5 branch | Joel Sherrill | 2000-05-08 | 2 | -0/+0 |
* | New file added on 4.5 branch | Joel Sherrill | 2000-05-08 | 1 | -0/+0 |
* | Added on 4.5 branch. | Joel Sherrill | 2000-05-03 | 4 | -0/+0 |
* | Added on 4.5-branch | Joel Sherrill | 2000-05-01 | 8 | -0/+0 |
* | New files. | Joel Sherrill | 2000-04-29 | 4 | -0/+8 |
* | New files added as part of librpc upgrade. | Joel Sherrill | 2000-04-29 | 28 | -0/+0 |
* | New files added as part of librpc upgrade. | Joel Sherrill | 2000-04-29 | 156 | -0/+0 |
* | New directory added as part of librpc upgrade. | Joel Sherrill | 2000-04-29 | 46 | -0/+0 |
* | New files added on 4.5 branch. | Joel Sherrill | 2000-04-28 | 4 | -0/+0 |
* | New file. | Joel Sherrill | 2000-04-13 | 1 | -0/+367 |
* | Patch rtems-rc-4.5.0-13-cvs.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>. | Joel Sherrill | 2000-04-13 | 346 | -0/+1244 |
| | | | | adds .cvsignore. | ||||
* | Patch rtems-rc-4.5.0-13-cvs.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>. | Joel Sherrill | 2000-04-13 | 437 | -0/+1515 |
* | Removed. | Joel Sherrill | 2000-04-07 | 1 | -18/+0 |
* | New file. Copied from i386ex BSP as missing from submission. | Joel Sherrill | 2000-04-05 | 1 | -0/+18 |
* | New files from John Cotton <John.Cotton@nrc.ca> and Charles-Antoine | Joel Sherrill | 2000-04-05 | 3 | -0/+3223 |
| | | | | | | | | | | | | | | | | | | | | | Gauthier <charles.gauthier@nrc.ca>. The power supply in their VMEbus cage died so it was submitted at this point. It passes ttcp which is a really good sign but they would like to do more testing and cleanup once their hardware is functional again. Please contact them if you are interested in using or fixing this driver. As their comments indicate, the performance is actually quite good even at this point as indicated by the ttcp results. Please note that this is by no means a final version. The code is still fairly ugly, and will require some further fixing. On the bright side, what is attached works. I finally ran the test programs successfully with optimized code and data cache enabled: netdemos worked, but failed on the UDP transfer (runs out of buffers). ttcp worked, with something like 1036 KB/sec Rx, 952 KB/sec Tx. tftp worked | ||||
* | New file from Ralf Corsepius <corsepiu@faw.uni-ulm.de> as part of | Joel Sherrill | 2000-04-03 | 1 | -0/+56 |
| | | | | | rtems-rc-4.5.0-7.diff. This file is being added to the main branch in hopes that it will be easier to deal with the full merge later. | ||||
* | Added routines to get and set C3x IOF register. The code is conditionally | Joel Sherrill | 2000-03-01 | 1 | -13/+71 |
| | | | | compiled and there is no comparable code for the C4x. | ||||
* | BSP now compiles and links with CAVSL board information. This includes | Joel Sherrill | 2000-02-29 | 4 | -10/+5 |
| | | | | | | | | | | linkcmds updated, simio references removed, and switch to libchip for serial ports from simio. Added a MEMORY_MAP file to capture information about the various addresses on this board. In addition, many of the beta patches are now included. | ||||
* | Fixed typo. | Joel Sherrill | 2000-02-28 | 1 | -1/+1 |
* | New port of RTEMS to TI C3x and C4x. | Joel Sherrill | 2000-02-22 | 1 | -0/+44 |
* | New port of RTEMS to TI C3x and C4x. | Joel Sherrill | 2000-02-22 | 47 | -0/+5488 |
* | Increased block size to 128 and added comments based on feedback from | Joel Sherrill | 2000-02-11 | 3 | -3/+39 |
| | | | | Java folks including Oscar Martinez de la Torre <omt@wm.estec.esa.nl>. |
