* | 2010-06-14 Arnout Vandecappelle <arnout@mind.be> | Sebastian Huber | 2010-06-14 | 2 | -0/+6 | |
| | | | | | PR 1557/misc * libchip/i2c/spi-sd-card.c: Fixed low capacity special case. | |||||
* | Remove (Abandoned). | Ralf Corsepius | 2010-06-11 | 36 | -2688/+0 | |
* | 2010-06-07 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2010-06-07 | 2 | -2/+7 | |
| | | | | | * aclocal/version.m4: Bump RTEMS_API to 4.11. Bump _RTEMS_VERSION to 4.10.99.0. | |||||
* | 2010-06-03 Joel Sherrill <joel.sherrilL@OARcorp.com> | Joel Sherrill | 2010-06-03 | 2 | -5/+5 | |
| | | | | * libchip/network/if_dc.c: Fix warning. | |||||
* | fix bug in mount table | Thomas Doerfler | 2010-06-03 | 2 | -2/+6 | |
* | 2010-06-02 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2010-06-02 | 2 | -0/+10 | |
| | | | | | * include/bsp.h: Add prototypes for BSP_disconnect_clock_handler, BSP_connect_clock_handler. | |||||
* | 2010-05-31 Joel Sherrill <joel.sherrilL@OARcorp.com> | Joel Sherrill | 2010-05-31 | 2 | -4/+7 | |
| | | | | * shared/start/start.S: Pass 0/NULL for argc/argv. | |||||
* | 2010-05-31 Chris Johns <chrisj@rtems.org> | Chris Johns | 2010-05-31 | 1 | -11/+13 | |
| | | | | * shared/umon/tfsDriver.c: Updated to the new mount API. | |||||
* | 2010-05-31 Joel Sherrill <joel.sherrilL@OARcorp.com> | Joel Sherrill | 2010-05-31 | 2 | -5/+6 | |
| | | | | * start/start.S: Pass 0/NULL for argc/argv. | |||||
* | 2010-05-31 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2010-05-31 | 2 | -6/+18 | |
| | | | | | * libchip/network/greth.c: Misc. hacks to allow compilation on 16bit targets. | |||||
* | 2010-05-31 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2010-05-31 | 2 | -0/+15 | |
| | | | | | | PR 1531/newlib * libchip/network/i82586.c: Add local copy of ALIGN(). | |||||
* | 2010-05-31 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2010-05-31 | 2 | -5/+8 | |
| | | | | | * libchip/network/cs8900.c: Misc. changes to make code 16bit-target compliant. | |||||
* | 2010-05-31 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2010-05-31 | 2 | -4/+6 | |
| | | | | | * libchip/network/i82586.c: Use int32_t instead of int for 16bit-target compliance. | |||||
* | 2010-05-31 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2010-05-31 | 2 | -4/+20 | |
| | | | | | * libchip/network/open_eth.c: Misc. changes to make code 16bit-target compliant. | |||||
* | 2010-05-30 Joel Sherrill <joel.sherrilL@OARcorp.com> | Joel Sherrill | 2010-05-30 | 4 | -2/+10 | |
| | | | | * Makefile.am: Fix typo in path. | |||||
* | 2010-05-30 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2010-05-30 | 2 | -0/+71 | |
| | | | | * shared/src/no_cache.c: New file. | |||||
* | 2010-05-29 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2010-05-29 | 3 | -68/+6 | |
| | | | | | PR 1537/libcpu * shared/cache/cache.c: Removed. | |||||
* | 2010-05-29 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2010-05-29 | 3 | -68/+7 | |
| | | | | | | PR 1538/libcpu * Makefile.am: Use shared stub implementation of cache.c (no_cache.c). * shared/cache/cache.c: Removed. | |||||
* | 2010-05-28 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2010-05-28 | 2 | -1/+6 | |
| | | | | | * umon/tfsDriver.c: Use size_t instead of int for pathnamelen. | |||||
* | 2010-05-28 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2010-05-28 | 3 | -1/+16 | |
| | | | | | | | * au1x00/include/au1x00.h: Add prototypes for mips_default_isr, assert_sw_irq, negate_sw_irq. * au1x00/vectorisrs/vectorisrs.c: Remove prototype of mips_default_isr. | |||||
* | 2010-05-25 Sebastian Huber <sebastian.huber@embedded-brains.de> | Sebastian Huber | 2010-05-25 | 3 | -0/+11 | |
| | | | | * configure.ac, include/bspopts.h.in: Added BSP_SMALL_MEMORY option. | |||||
* | 2010-05-24 Peter Dufault <dufault@hda.com> | Joel Sherrill | 2010-05-24 | 2 | -10/+14 | |
| | | | | | PR 1530/bsps * mpc55xx/edma/edma.c: Eliminate use of recently removed macros. | |||||
* | 2010-05-24 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2010-05-24 | 6 | -33/+54 | |
| | | | | | | | * Makefile.am, amba/amba.c, console/console.c, console/debugputs.c, startup/bspstart.c: Rework initialization order so AMBA bus is scanned earlier. This lets us look for UARTs earlier and support printk as early as bsp_start() returning. | |||||
* | 2010-05-23 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2010-05-23 | 3 | -5/+10 | |
| | | | | | * console/consolelite.c, network/xiltemac.c: Reflect prototypes having changed (Warning removal). | |||||
* | 2010-05-21 Vinu Rajashekhar <vinutheraj@gmail.com> | Joel Sherrill | 2010-05-21 | 3 | -34/+40 | |
| | | | | | * cache.c, page.c: Use masks and shift operations instead of bit-fields. | |||||
* | 2010-05-21 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2010-05-21 | 2 | -1/+5 | |
| | | | | * Makefile.am: Add bspreset.c | |||||
* | 2010-05-21 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2010-05-21 | 2 | -2/+8 | |
* | 2010-05-21 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2010-05-21 | 5 | -33/+37 | |
| | | | | | * sh7032/score/cpu_asm.c, sh7045/score/cpu_asm.c, sh7750/score/cpu_asm.c, shgdb/score/cpu_asm.c: Spacing. | |||||
* | Whitespace removal. | Sebastian Huber | 2010-05-21 | 1 | -2/+2 | |
* | 2010-05-21 Sebastian Huber <sebastian.huber@embedded-brains.de> | Sebastian Huber | 2010-05-21 | 2 | -5/+9 | |
| | | | | * include/lpc32xx.h: Update for utility macro changes. | |||||
* | 2010-05-21 Sebastian Huber <sebastian.huber@embedded-brains.de> | Sebastian Huber | 2010-05-21 | 2 | -8/+13 | |
| | | | | | * include/utility.h: Macros use now first and last bit values instead of shift and length parameters. | |||||
* | 2010-05-20 Sebastian Huber <sebastian.huber@embedded-brains.de> | Sebastian Huber | 2010-05-20 | 4 | -1/+80 | |
| | | | | | * configure.ac: Fixed BSP option. * include/lpc32xx.h, startup/bspstarthooks.c: Added PLL setup. | |||||
* | 2010-05-20 Sebastian Huber <sebastian.huber@embedded-brains.de> | Sebastian Huber | 2010-05-20 | 2 | -3/+4 | |
| | | | | * startup/bspstarthooks.c: Removed start section attribute defines. | |||||
* | 2010-05-20 Sebastian Huber <sebastian.huber@embedded-brains.de> | Sebastian Huber | 2010-05-20 | 4 | -3/+27 | |
| | | | | * shared/include/start.h: Define start section attributes. | |||||
* | 2010-05-20 Sebastian Huber <sebastian.huber@embedded-brains.de> | Sebastian Huber | 2010-05-20 | 6 | -30/+36 | |
| | | | | | | * include/lpc24xx.h, misc/dma-copy.c, misc/dma.c, misc/system-clocks.c, ssp/ssp.c, startup/bspstarthooks.c: Removed superfluous macros. | |||||
* | 2010-05-20 Sebastian Huber <sebastian.huber@embedded-brains.de> | Sebastian Huber | 2010-05-20 | 2 | -44/+24 | |
| | | | | * include/utility.h: Removed superfluous macros. | |||||
* | 2010-05-20 Sebastian Huber <sebastian.huber@embedded-brains.de> | Sebastian Huber | 2010-05-20 | 2 | -30/+34 | |
| | | | | * network/smsc9218i.c: Removed superfluous macros. | |||||
* | 2010-05-20 Sebastian Huber <sebastian.huber@embedded-brains.de> | Sebastian Huber | 2010-05-20 | 14 | -182/+258 | |
| | | | | | | | | | * make/custom/lpc32xx.inc, make/custom/lpc32xx_mzx_boot_int.cfg, startup/linkcmds.lpc32xx_mzx_boot_int: New files. * Makefile.am, configure.ac, preinstall.am, include/bsp.h, include/bspopts.h.in, include/lpc32xx.h, irq/irq.c, make/custom/lpc32xx_phycore.cfg, startup/bspstart.c, startup/bspstarthooks.c: Changes throughout. | |||||
* | 2010-05-20 Sebastian Huber <sebastian.huber@embedded-brains.de> | Sebastian Huber | 2010-05-20 | 5 | -26/+15 | |
| | | | | | * Makefile.am, preinstall.am, include/bsp.h, startup/bspstart.c: Use shared output character implementation. | |||||
* | 2010-05-20 Sebastian Huber <sebastian.huber@embedded-brains.de> | Sebastian Huber | 2010-05-20 | 3 | -0/+105 | |
| | | | | * include/uart-output-char.h, src/uart-output-char.c: New files. | |||||
* | 2010-05-20 Sebastian Huber <sebastian.huber@embedded-brains.de> | Sebastian Huber | 2010-05-20 | 2 | -1/+6 | |
| | | | | * make/custom/lpc32xx_phycore.cfg: Workaround for GCC bug 38644. | |||||
| | | | | * make/custom/rtl22xx_t.cfg: Workaround for GCC bug 38644. | |||||
* | 2010-05-20 Sebastian Huber <sebastian.huber@embedded-brains.de> | Sebastian Huber | 2010-05-20 | 2 | -1/+5 | |
| | | | | * make/dswifi/arm9/makefile: Workaround for GCC bug 38644. | |||||
| | | | | * make/custom/lpc24xx.inc: Workaround for GCC bug 38644. | |||||
* | 010-05-18 Chris Johns <chrisj@rtems.org> | Chris Johns | 2010-05-18 | 3 | -2/+7 | |
| | | | | | * libchip/i2c/spi-sd-card.c, libchip/ide/ata.c: PR 1448/filesystem. | |||||
* | 2010-05-15 Joel Sherrill <joel.sherrilL@OARcorp.com> | Joel Sherrill | 2010-05-15 | 2 | -2/+6 | |
| | | | | * startup/syscalls.c: Rename to avoid conflict with newlib. | |||||
* | 2010-05-14 Joel Sherrill <joel.sherrilL@OARcorp.com> | Joel Sherrill | 2010-05-14 | 3 | -5/+4 | |
| | | | | * Makefile.am, preinstall.am: Fix typo. | |||||
* | 2010-05-14 Joel Sherrill <joel.sherrilL@OARcorp.com> | Joel Sherrill | 2010-05-14 | 2 | -1/+5 | |
| | | | | * rtl8019/rtl8019.c: Fix typo. | |||||
* | 2010-05-13 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2010-05-13 | 6 | -0/+1696 | |
| | | | | | * shared/liblnk/lnklib.S, shared/liblnk/pmon.S, shared/liblnk/regs.h, shared/startup/idtmem.S, shared/startup/idttlb.S: New files. | |||||
* | 2010-05-13 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2010-05-13 | 8 | -1694/+16 | |
| | | | | | | | * Makefile.am, preinstall.am: Many files were duplicated across MIPS BSPs. Now those which were directly copied are shared. * liblnk/lnklib.S, liblnk/pmon.S, liblnk/regs.h, startup/idtmem.S, startup/idttlb.S: Removed. |
