alias simcpu32 that supports the CPU32 simulator in BSVC. At this
point, it is still under development.
in ROM.
is available.
the correct circumstances of DMA buffer size, serial
line interrupts, and ethernet interrupts the termios osend routine would
lock up waiting for the raw output buffer semaphore.
that switches the sparc from targopts.h to cpuopts.h.
That BSP now has a stub clock driver so the tests can link even
if they won't execute. A handful of Makefiles had to be updated
and we had to account for printk.c being a shared file now.
removes warnings from the network.c file and has slight additions
to the configuration file to support Java.
is no such thing on the C4x.
that removes an unnecessary inclusion of @RTEMS_BSP@.cfg.
by Till Straumann <strauman@SLAC.Stanford.EDU>. With this
patch, the motorola_shared BSP should also support the MVME2303.
This update addresses the following:
+ the ISR enable/disable/flash macros now work with old gcc versions.
+ the UI CCR bits are now masked since other example code did so
+ _ISR_Dispatch disables interrupts during call setup
Together these removed the instabilities he was seeing.
cpuopts.h.
exec/configure.in, only.
quoting bugs in autoconf).
formating changes :)
cpuopts.h.
to disabled.
problems at runtime.
are now in libcpu. This primarily required moving erc32 specific
information from score/cpu files to libcpu/sparc and the erc32 BSP.
using cpuopts.h and not targopts.h.
are now in libcpu. This required significant rework of the
score/cpu header files and the creation of multiple header files
and subdirectories in libcpu/i960.
