* | bsp/mpc5200: Set XLB timeout values | Sebastian Huber | 2013-04-23 | 1 | -0/+6 | |
* | bsp/mpc5200: Do not initialize debug registers | Sebastian Huber | 2013-04-23 | 1 | -20/+0 | |
* | bsp/mpc5200: Add and use enable_bat_4_to_7() | Sebastian Huber | 2013-04-23 | 1 | -6/+8 | |
* | bsp/mpc5200: Fix cache handling | Sebastian Huber | 2013-04-23 | 2 | -18/+6 | |
* | bsp/mpc5200: Add MPC5200_BOARD prefix | Sebastian Huber | 2013-04-23 | 6 | -27/+49 | |
* | D-cache clean&&invalidate for Tiny6410 | Peng Fan | 2013-04-17 | 1 | -0/+21 | |
* | bsp/mpc55xx: Typo | Sebastian Huber | 2013-04-17 | 1 | -1/+1 | |
* | bsp/mpc55xx: eDMA API changes | Sebastian Huber | 2013-04-08 | 5 | -183/+485 | |
* | bsp/mpc55xx: Add alternative register layout | Sebastian Huber | 2013-04-08 | 1 | -0/+17 | |
* | bsp/mpc55xx: Add PCR index enumeration | Sebastian Huber | 2013-04-08 | 2 | -2/+267 | |
* | bsp/mpc55xx: New define MPC55XX_PERIPHERAL_CLOCK | Sebastian Huber | 2013-04-08 | 1 | -0/+3 | |
* | bsp/mpc55xx: Rename BSP option | Sebastian Huber | 2013-04-08 | 2 | -6/+6 | |
* | bsp/mpc55xx: New fatal errors | Sebastian Huber | 2013-04-08 | 2 | -5/+6 | |
* | bsp/mpc55xx: Include <bsp/linker-symbols.h> | Sebastian Huber | 2013-04-08 | 1 | -0/+1 | |
* | bsp/mpc55xx: Fix warnings | Sebastian Huber | 2013-04-08 | 2 | -8/+7 | |
* | libchip/serial: Fix warnings | Sebastian Huber | 2013-04-08 | 1 | -1/+1 | |
* | bsps: Fix warnings | Sebastian Huber | 2013-04-08 | 2 | -0/+2 | |
* | bsps: Fix warnings | Sebastian Huber | 2013-04-08 | 1 | -1/+1 | |
* | bsps/powerpc: Use proper type | Sebastian Huber | 2013-04-08 | 2 | -6/+6 | |
* | bsp/gen5200: Fix syntax | Sebastian Huber | 2013-04-08 | 1 | -1/+1 | |
* | bsp/lpc24xx: Fix register address | Sebastian Huber | 2013-04-08 | 1 | -1/+2 | |
* | bsp/gen5200: Typo | Sebastian Huber | 2013-04-02 | 1 | -1/+1 | |
* | bsp/gen5200: Elaborate option help message | Sebastian Huber | 2013-04-02 | 1 | -4/+8 | |
* | bsp/gen5200: Remove superfluous option definition | Sebastian Huber | 2013-04-02 | 1 | -1/+0 | |
* | bsp/gen5200: Use busy wait | Sebastian Huber | 2013-03-28 | 2 | -3/+6 | |
| | | | | | The usage of rtems_task_wake_after() is invalid during the driver initialization. | |||||
* | bsp/gen5200: Use fatal error instead of assert | Sebastian Huber | 2013-03-28 | 2 | -4/+10 | |
* | bsps/arm: Add thread-local storage (TLS) sections | Sebastian Huber | 2013-03-26 | 1 | -1/+7 | |
* | bsp/raspberrypi: New BSP | Alan Cudmore | 2013-03-24 | 21 | -0/+1532 | |
* | bsp/mpc83xx: Add MPC83XX_NET*_INTERFACE_0_PHY_ADDR | Sebastian Huber | 2013-03-21 | 1 | -0/+5 | |
* | bsp/psim: Use shared linkcmds.base | Sebastian Huber | 2013-03-19 | 6 | -285/+62 | |
| | | | | | Several GCC tests faild due to the outdated previous linker command file. | |||||
* | bsps: Support DWARF extension | Sebastian Huber | 2013-03-18 | 8 | -0/+19 | |
* | bsp/edb7312: Improve output char | Sebastian Huber | 2013-03-14 | 1 | -11/+20 | |
| | | | | | The output char function used by printk() is now independent of the console driver initialization. | |||||
* | bsp/edb7312: Fix warnings | Sebastian Huber | 2013-03-14 | 1 | -8/+0 | |
* | mpc83xx: Add and use mpc83xx_reset() | Sebastian Huber | 2013-03-14 | 2 | -15/+22 | |
| | | | | | The inline version makes it possible to use this code in different memory areas. | |||||
* | mpc83xx: Use shared linkcmds.base | Sebastian Huber | 2013-03-14 | 13 | -495/+129 | |
* | mpc83xx: Copy nothing if necessary | Sebastian Huber | 2013-03-14 | 1 | -0/+3 | |
* | mpc83xx: Fix local access window 1 configuration | Sebastian Huber | 2013-03-14 | 1 | -0/+10 | |
* | mpc83xx: Add MPC83XX_HAS_NAND_LP_FLASH_ON_CS0 | Sebastian Huber | 2013-03-14 | 3 | -9/+27 | |
* | mvme3100/Makefile.am: Remove reference to ChangeLog | Joel Sherrill | 2013-03-11 | 1 | -1/+1 | |
* | beatnik/Makefile.am: Remove reference to ChangeLog | Joel Sherrill | 2013-03-11 | 1 | -1/+1 | |
* | RTEMS: Delete ChangeLog files. | Gedare Bloom | 2013-03-08 | 124 | -58241/+0 | |
| | | | | | | | | | This commit deletes all RTEMS ChangeLog files. These files have been abandoned since converting to git version control. The historical data may be recovered by checking out any commit before this one. Most of the contents of these ChangeLog files can also be found in the git log. Two external ChangeLog files, ChangeLog.slac and ChangeLog.zlib, remain. | |||||
* | libchip: Fix prototypes | Sebastian Huber | 2013-03-01 | 3 | -24/+24 | |
* | libchip/rtc: Fixed 19 compiler warnings | Andreas Heinig | 2013-02-28 | 3 | -3/+7 | |
* | libchip/serial: Fixed warnings | Andreas Heinig | 2013-02-28 | 1 | -0/+3 | |
* | Common file changes in support of Moxie port | Anthony Green | 2013-02-28 | 1 | -0/+1 | |
| | | | | Signed-off-by: Anthony Green <green@moxielogic.com> | |||||
* | Add sample Moxie BSP for GDB sim | Anthony Green | 2013-02-28 | 15 | -0/+646 | |
* | libchip/network: Fixed warning | Andreas Heinig | 2013-02-27 | 1 | -1/+2 | |
* | sparc: Remove dead code that was leftover from SMP development. | Jennifer Averett | 2013-02-26 | 1 | -4/+0 | |
* | bsp/mpc55xx: Add register type definition | Sebastian Huber | 2013-02-25 | 1 | -1/+1 | |
* | bsp/gen5200: New ATA driver | Sebastian Huber | 2013-02-20 | 10 | -45/+1566 | |
| | | | | This is a replacement for the ATA task. The performance is much better. |
