Close #3339.
Update #3339.
Cannot read or write MSR when executing in user mode. This
is used when RTEMS_PARAVIRT is defined.
Provide alternate methods to disable/enable interrupts
Closes #3306.
This adds a simple function for setting the PIO drive strength.
Update #3285.
Update #3285.
Update #3285.
Update #3285.
Update #3285.
Update #3285.
Update #3285.
Close #3318.
Updates #3520.
The
KEEP (*(SORT(.ctors.*)))
KEEP (*(.ctors))
cannot be simplified to
KEEP (*(SORT(.ctors*)))
since
.ctors < .ctors.*
in lexicographical order.
See spglobalcon02 test case.
Update #3319.
Closes #3307.
This patch fixes the cache handling for the atsam SPI driver. Note that
this solution might doesn't have the best performance for small packets.
The SPI controller supports a decoder connected to the chip select
lines. This patch allows to use this mode.
This was at the request of a user to make it easier to have a
custom entry point. This way they just provide their own top
level linkcmds and include linkcmds.base.
Updates #3520.
Update #3290.
Close #3270.
Update #3285.
* bsps/shared/cache
Update #3285.
GCC 7.3 defines __USER_LABEL_PREFIX__ to nothing.
line option.
may suppress warnings.
erc32, imx, qoriq, etc.
* cpukit/include
* cpukit/libnetworking
* bsps/include
* bsps/@RTEMS_CPU@/include
order.
Update #3254.
Update #3085.
Update #3254.
Update #3085.
Update #3085.
Update #3085.
Update #3085.
Update #3085.
Update #3085.
Account for DPAA resources defined in the device tree.
Prevent merging of areas with incompatible MAS2.
Update #3085.
This header is used also by the motorola_powerpc BSP.
Update #3254.
Install these files only as <bsp/i2c.h> and <bsp/i2cdrv.h>.
Update #3254.
Updates #3520.
Updates #3520.
Updates #3520.
Updates #3520.
Update #3254.
