* libchip/network/if_fxp.c: Add include of <sys/errno.h>.
* startup/linkcmds: Add gnu.linkonce.r sections.
* Makefile.am: Add -D__INSIDE_RTEMS_BSD_TCPIP_STACK__ for network.
* network/network.c: Add include of <sys/errno.h>.
* network/ne2000.c: Add include of <sys/errno.h>.
* 3c509/3c509.c: Add <sys/errno.h>.
* startup/linkcmds: Add .jcr section.
* at91rm9200/.cvsignore, mc9328mxl/.cvsignore, shared/.cvsignore:
New files.
* .cvsignore: New file.
* .cvsignore, ChangeLog, Makefile.am, configure.ac: New files.
* ChangeLog, Makefile.am, arm920/mmu.c, include/mmu.h: New files.
* ChangeLog, Makefile.am, clock/.cvsignore, clock/clockdrv.c,
include/mc9328mxl.h, irq/.cvsignore, irq/bsp_irq_asm.S,
irq/bsp_irq_init.c, irq/irq.c, irq/irq.h, timer/.cvsignore,
timer/timer.c: New files.
* ChangeLog, Makefile.am, clock/.cvsignore, clock/clock.c,
dbgu/.cvsignore, dbgu/dbgu.c, include/at91rm9200.h,
include/at91rm9200_dbgu.h, include/at91rm9200_emac.h,
include/at91rm9200_gpio.h, include/at91rm9200_mem.h,
include/at91rm9200_pmc.h, include/bits.h, irq/.cvsignore,
irq/bsp_irq_asm.S, irq/bsp_irq_init.c, irq/irq.c, irq/irq.h,
pmc/pmc.c, timer/.cvsignore, timer/timer.c: New files.
* acinclude.m4: Added csb336 and csb337 BSPs
* .cvsignore, ChangeLog, Makefile.am, README, bsp_specs, configure.ac,
times, console/uarts.c, include/.cvsignore, include/bsp.h,
include/tm27.h, network/.cvsignore, network/network.c,
start/.cvsignore, start/start.S, startup/.cvsignore,
startup/bspstart.c, startup/exit.c, startup/linkcmds,
startup/memmap.c: New files.
* console/.cvsignore, include/.cvsignore, network/.cvsignore,
start/.cvsignore, startup/.cvsignore: New files.
* ChangeLog, Makefile.am, README, bsp_specs, configure.ac, times,
console/uart.c, include/bsp.h, include/tm27.h, network/lan91c11x.c,
network/lan91c11x.h, network/network.c, start/start.S,
PR 615/bsps
* include/tm27.h: Removing USE_ENHANCE_INTR_API conditional check since
that is the only kind this BSP supports and tm27 does not care which
interrupt model is used as long as the macros are properly defined.
PR 619/bsps
* mpc6xx/clock/c_clock.c: The PPC decrementer must be reloaded on each
clock tick. Currently, this is done by just reloading a fixed value.
The attached patch takes into account the time that elapsed since the
decrementer crossed zero in order to adjust the value to be
re-loaded. Without the patch, the effective system clock cycle is
increased by the exception handler latency.
* PR 624/bsps
startup/bspstart.c: When probing the memory, make sure not to
corrupt the application. Only probe addresses beyond rtemsFreeMemStart.
* Let IBMPC_outch() convert LF -> CRLF to avoid printk scrambling
the screen.
* PR/625/networking
* libchip/network/dec21140.c, ... : Prevent name clashes by making
'ld_le32()' etc. static inlines. Let dec21140 attach routine return
an error rather than panic if no chip is detected (thus allowing
for probing).
* libchip/network/elnk.c: Let elnk bail out if autoneg never completes
instead of looping forever. Avoid divide by zero (crashed my PC).
* libchip/network/if_fxp.c: Enable more fxp chip variants but warn that
they are UNTESTED.
* network/network.c: Include errno.h as a consequence of recent updates
to BSD header files.
* ne2000/ne2000.c, wd8003/wd8003.c: Include errno.h as a consequence of
recent updates to BSD header files.
* aclocal/check-cxx.m4: Remove CPLUS_LD_LIBS.
PR 610/bsps
* Makefile.am: Add include/tm27.h, Cosmetics.
* include/tm27.h: Final cosmetics.
* include/tm27.h: New.
* libchip/network/dec21140.c, libchip/network/elnk.c:
#include <errno.h>.
* include/bsp.h: Remove (Unused).
* Makefile.am: Reflect change above.
PR 611/bsps
* Makefile.am, include/bsp.h, wrapup/Makefile.am: Follow conventions
for tm27 and do not add another macro definition.
* startup/tm27supp.c: New file.
PR 613/bsps
PR 614/bsps
* Makefile.am: Remove C_FILES (Unused).
* libchip/network/if_media.h: Update from FreeBSD.
* libchip/network/open_eth.c, libchip/network/cs8900.c,
libchip/network/i82586.c: #include <errno.h>.
* start/start.S: DWARF on the m68k requires that all objects me a
multiple of a 16-bit word in length.
