path: root/c (follow)
* 2002-02-28 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-02-2836-0/+7642
| | | | | | | | | | * Submitted by Victor V. Vengerov <vvv@oktet.ru> and merged into the RTEMS source. * ChangeLog, Makefile.am, README, configure.ac, include/Makefile.am, include/rtems/bdbuf.h, include/rtems/blkdev.h, include/rtems/diskdevs.h, include/rtems/ramdisk.h, include/rtems/.cvsignore, include/.cvsignore, src/Makefile.am, src/bdbuf.c, src/blkdev.c, src/diskdevs.c, src/ramdisk.c, src/.cvsignore, .cvsignore: New files.
* 2002-02-27 Ilya Alexeev <ilya@continuum.ru>Joel Sherrill2002-02-278-14/+63
| | | | | | * net/if_ppp.c, pppd/auth.c, pppd/chat.c, pppd/pppd.h, pppd/sys-rtems.c: Add server with pap-authorization capabilities as well as eliminate some warnings.
* 2002-02-27 Eric Norum <eric.norum@usask.ca>Joel Sherrill2002-02-274-2/+20
| | | | | | * net/radix.c: Properly handle fetching the default route when there is no route. This was a bug in the original FreeBSD code and this fix is from an updated version of their code.
* 2001-02-27 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-02-275-45/+3115
| | | | | | | | | | | * Significant modifications including adding thread support, the 'X' command, and reorganizing so that target CPU independent routines could be reused. * gdb_if.h: Added numerous prototypes. * mips-stub.c: Added thread support as well as 'X' command. Also noticed that the 'P' command was from the mips protocol. * rtems-stub-glue.c: New file. This file contains all generic support which should be able to be reused on another target CPU.
* 2001-02-27 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-02-272-1/+5
| | | | * startup/Makefile.am: Added rtems-stub-glue.c to C_FILES.
| | | | * rtems/score/cpu.h: Fix conditional to match current GCC.
* 2002-02-13 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-02-132-8/+4
| | | | * configure.ac: Fix the test to determine cpu context size.
* 2002-02-08 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-02-082-2/+29
| | | | | | * mips-stub.c (handle_exception): Prototype changed to be an RTEMS entry point. Added comments about possible need to flush cache. (mips_gdb_stub_install): New routine.
* 2002-02-08 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-02-082-1/+5
| | | | * mongoosev/vectorisrs/vectorisrs.c: Fixed to use new frame format.
* 2002-02-08 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-02-084-20/+54
| | | | | | * startup/Makefile.am: Now compile the gdb stub. * startup/bspstart.c: Fixed header block. * startup/gdb-support.c: New file in stub state.
* 2002-02-08 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-02-083-153/+163
| | | | | * iregdef.h, rtems/score/cpu.h: Reordered register in the exception stack frame to better match gdb's expectations.
* 2002-02-08 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-02-0810-1206/+112
| | | | | | | | | | | | | * Makefile, stubinit.S, r46kstub.ld, ioaddr.h: Removed as unused with RTEMS. * r46kstub.c: Renamed to mips-stub.c. * mips-stub.c: New file -- was r46kstub.c. * memlimits.h: New file was limits.h. * limits.h: Removed. * r4600.h: Eliminated need for this file. * README: Updated. * gdb_if.h: Added CVS Id. * mips-stub.c: Attempt to deal with MIPS1 versus MIPS3.
* 2002-02-08 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-02-0811-0/+2664
| | | | | | | | | | | * Merged r46kstub.c into RTEMS distribution without modification. I got the code from Franz Fischer <Franz.Fischer@franz-fischer.de> who had used this with an old version of RTEMS with the mips64orion port of RTEMS. After adding this to the repository, I will tailor this to work with the RTEMS exception processing model and trim no longer needed parts. * ChangeLog, gdb_if.h, ioaddr.h, limits.h, Makefile, mips_opcode.h, r4600.h, r46kstub.c, r46kstub.ld, README, stubinit.S:
* 2001-02-05 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-02-053-15/+22
| | | | | | | * isr_entries.S: Removed comment incorrectly indicating this file was cpu_asm.S. * vectorexceptions.c (mips_dump_exception_frame): New routine broken out from default exception handler.
* 2001-02-05 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-02-054-16/+227
| | | | | | | | | * cpu_asm.S: Enhanced to save/restore more registers on exceptions. * rtems/score/cpu.h (CPU_Interrupt_frame): Enhanced to list every register individually and document when it is saved. * idtcpu.h: Added constants for the coprocessor 1 registers revision and status.
* 2001-02-05 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-02-052-0/+5
| | | | * .cvsignore: Added stamp-h.in.
* 2001-02-05 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-02-0512-35/+16
| | | | * rtems/Makefile.am, rtems/score/Makefile.am: Removed again.
* 2001-02-04 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-02-042-1/+6
| | | | | * rtems/score/cpu.h: IDLE task should not be FP. This was a mistake in the previous patch that has now been confirmed.
* 2001-02-04 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-02-042-3/+6
| | | | | * configure.ac: Removed references to rtems/Makefile and rtems/score/Makefile.
* 2001-02-01 Greg Menke <gregory.menke@gsfc.nasa.gov>Joel Sherrill2002-02-024-0/+915
| | | | | | * include/lr33000.h, include/lr330x0.h, include/r3000.h, start/mg5.h: New files missed in previous commit. * timer/timer.c: Use rtems/bspIo.h not just bspIo.h.
* Fixed ChangeLog again :(Joel Sherrill2002-02-011-0/+48
* Fixed ChangeLogJoel Sherrill2002-02-011-34/+107
* 2002-02-01 Eric Valette <valette@crf.canon.fr>Joel Sherrill2002-02-0110-3420/+2644
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | * So many patches have been posted recently on the mailing list and because we were unable to find correct solution to compile on various linux distros (due to rpcgen incompatibilities), and because the coding style of rdbg was rather inconsistant among various pieces of code, I decided to: 1) make some cleaning regarding global coding style (using indent + manual edits), 2) incorporate/review the paches send by various people (S. Holford, T. Strauman), 3) Fix the bug due to varying rpcgen code generation in remdeb_svc.c, 4) Remove some dead code, 5) Apply a patches enabling to call enterRdbg imediately after rdbg initialization is done, NB : the paches is huge but it is mainly due to coding styke chnages. Only few lines of codes have been really changed and they do not impact rdbg functionnality (AFAIKT). * include/rdbg/servrpc.h, include/rdbg/i386/rdbg_f.h, include/rdbg/m68k/rdbg_f.h, include/rdbg/powerpc/rdbg_f.h, src/_servtgt.c, src/awk.svc, src/excep.c, src/ptrace.c, src/rdbg.c, src/remdeb.x, src/servbkpt.c, src/servcon.c, src/servrpc.c, src/servtgt.c, src/servtsp.c, src/servutil.c, src/i386/excep_f.c, src/i386/rdbg_f.c, src/i386/any/Makefile.am, src/i386/any/remdeb.h, src/i386/any/remdeb_svc.c, src/i386/any/remdeb_xdr.c, src/m68k/excep_f.c, src/m68k/rdbg_f.c, src/m68k/any/Makefile.am, src/m68k/any/remdeb.h, src/m68k/any/remdeb_svc.c, src/m68k/any/remdeb_xdr.c, src/powerpc/excep_f.c, src/powerpc/rdbg_f.c, src/powerpc/new_exception_processing/Makefile.am, src/powerpc/new_exception_processing/remdeb.h, src/powerpc/new_exception_processing/remdeb_svc.c, src/powerpc/new_exception_processing/remdeb_xdr.c: Modified.
* Fixed ChangeLogJoel Sherrill2002-02-011-0/+1
* 2001-02-01 Greg Menke <gregory.menke@gsfc.nasa.gov>Joel Sherrill2002-02-013-2/+8
| | | | | | * mongoosev/vectorisrs/vectorisrs.c, shared/interrupts/vectorexceptions.c: Use rtems/bspIo.h, not just bspIo.h.
* 2001-02-01 Greg Menke <gregory.menke@gsfc.nasa.gov>Joel Sherrill2002-02-012-1/+7
* 2001-02-01 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-02-015-294/+274
| | | | | | * rtems.ads, rtems.adb: Formatting cleaned up. Task based timer directives added. This is Timer_Initiate_Server, Timer_Server_Fire_After, and Timer_Server_Fire_When.
* 2001-02-01 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-02-011-0/+4
| | | | * ChangeLog: New file.
* * So many patches have been posted recently on the mailing list andJoel Sherrill2002-02-0135-5885/+6155
* 2001-02-01 Mike Siers <mikes@poliac.com>Joel Sherrill2002-02-013-1/+20
| | | | | | * pppd/rtemspppd.c (rtems_pppd_disconnect): Modified to avoid bringing the link down too fast. NOTE: Mike reports successfully running at 56K baud on a direct link.
* 2001-02-01 Greg Menke <gregory.menke@gsfc.nasa.gov>Joel Sherrill2002-02-018-425/+1071
| | | | | | | * Update of BSP to address problems restarting, provide more information during boot, and better handle ROM vs RAM images. * README, include/bsp.h, start/regs.S, start/start.S, startup/bspstart.c, startup/linkcmds, timer/timer.c: Updated
* 2001-02-01 Greg Menke <gregory.menke@gsfc.nasa.gov>Joel Sherrill2002-02-015-109/+315
| | | | | | | | | | | | | | | | * Lots of tinkering and tuning as part of improving interrupt latency and improving the per-task interrupt level control and FP mask handling. With these modifications interrupt latency was measured at a worst-case of 100us, average below 60 us on a 12 Mhz R3000 class CPU with 50 RTEMS tasks in the application. * mongoosev/README: Updated. * mongoosev/include/mongoose-v.h: Masks modified. * mongoosev/vectorisrs/vectorisrs.c: Significant overhaul to address software prioritization of interrupts. If a higher priority interrupt occurs while we are looking for new interrupts, we will reinitiate the scan of all interrupts. * shared/interrupts/vectorexceptions.c: Removed warning and deleted blank lines.
* 2001-02-01 Greg Menke <gregory.menke@gsfc.nasa.gov>Joel Sherrill2002-02-014-148/+244
| | | | | | | | | * cpu.c: Enhancements and fixes for modifying the SR when changing the interrupt level. * cpu_asm.S: Fixed handling of FP enable bit so it is properly managed on a per-task basis, improved handling of interrupt levels, and made deferred FP contexts work on the MIPS. * rtems/score/cpu.h: Modified to support above changes.
* 2002-01-31 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-02-012-11/+26
| | | | * Makefile.am: Reflect 2002-01-23 changes.
* 2001-01-31 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-02-012-0/+26
| | | | | * include/rtems/rtems/timer.h: Missed merging these modifications in previous merge of new timer functionality.
* 2001-01-31 Mike Siers <mikes@poliac.com>Joel Sherrill2002-02-013-0/+32
| | | | * pppd/rtemsdialer.h: New file missed in previous commit.
* 2001-01-31 Mike Siers <mikes@poliac.com>Joel Sherrill2002-01-313-0/+29
| | | | | | | | | | | * Nice Update of PPPD support which eliminates the requiremetn that drivers be in the termios TASK_DRIVEN mode. Mike did significant testing and reports that it seems to be more stable and handle larger packets better. This patch replaces the termios tasks with more general pppd network driver tasks. The functions pppinput() and pppstart() get called from the interrupt service routine. * libc/termios.c: Added PPCDISC.
* 2001-01-31 Mike Siers <mikes@poliac.com>Joel Sherrill2002-01-3154-1459/+21277
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | * Nice Update of PPPD support which eliminates the requiremetn that drivers be in the termios TASK_DRIVEN mode. Mike did significant testing and reports that it seems to be more stable and handle larger packets better. This patch replaces the termios tasks with more general pppd network driver tasks. The functions pppinput() and pppstart() get called from the interrupt service routine. * Makefile.am, configure.ac, net/Makefile.am, net/bpf.h, net/ethernet.h, net/if.c, net/if.h, net/if_arp.h, net/if_dl.h, net/if_ethersubr.c, net/if_llc.h, net/if_loop.c, net/if_ppp.h, net/if_pppvar.h, net/if_types.h, net/netisr.h, net/ppp-comp.h, net/ppp_defs.h, net/pppcompress.h, net/radix.c, net/radix.h, net/raw_cb.c, net/raw_cb.h, net/raw_usrreq.c, net/route.c, net/route.h, net/rtsock.c, pppd/Makefile.am, pppd/README, pppd/STATUS, pppd/auth.c, pppd/cbcp.c, pppd/ccp.c, pppd/ccp.h, pppd/chap.c, pppd/chap.h, pppd/chap_ms.c, pppd/chap_ms.h, pppd/chat.c, pppd/demand.c, pppd/fsm.c, pppd/fsm.h, pppd/ipcp.c, pppd/ipcp.h, pppd/ipxcp.c, pppd/ipxcp.h, pppd/lcp.c, pppd/lcp.h, pppd/magic.c, pppd/magic.h, pppd/options.c, pppd/patchlevel.h, pppd/pathnames.h, pppd/pppd.8, pppd/pppd.h, pppd/rtemsmain.c, pppd/rtemspppd.c, pppd/rtemspppd.h, pppd/sys-rtems.c, pppd/upap.c, pppd/upap.h, pppd/utils.c, pppd/example/README, pppd/example/netconfig.h, wrapup/Makefile.am: Modified. * net/bsd-comp.c, net/if_ppp.c, net/ppp-deflate.c, net/ppp.h, net/ppp_tty.c, net/pppcompress.c, net/zlib.c, net/zlib.h: New file. * modem/, modem/.cvsignore, modem/Makefile.am, modem/ppp.c, modem/ppp.h, modem/ppp_tty.c, modem/pppcompress.c: Subdirectory removed.
* 2002-01-31 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-01-313-26/+31
* 2002-01-31 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-01-313-29/+31
| | | | | | | * rtems/Makefile.am: Removed. * rtems/score/Makefile.am: Removed. * configure.ac: Reflect changes above. * Makefile.am: Reflect changes above.
* 2001-01-30 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-01-302-3/+20
| | | | * Makefile.am: Corrected so .h files from rtems/score/ are installed.
* 2002-01-29 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-01-3029-226/+146
* 2002-01-29 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-01-3025-273/+184
* 2002-01-28 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-01-302-1/+4
| | | | * shell/shell.c: Remove #undef __STRICT_ANSI__.
* 2002-01-28 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-01-302-2/+6
| | | | * Makefile.am: Adapt to automake-1.5.
* 2002-01-28 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-01-302-7/+11
| | | | * include/Makefile.am: Adapt to automake-1.5.
* 2002-01-28 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-01-3015-161/+103
* 2002-01-28 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-01-302-8/+21
| | | | * Makefile.am: Reflect changes from 2002-01-23.
* 2002-01-29 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-01-291-4/+0
| | | | * ChangeLog: Deleted bad entry.
