* arm/at91rm9200/timer/timer.c, arm/lpc22xx/timer/timer.c,
arm/mc9328mxl/timer/timer.c, arm/s3c2400/timer/timer.c,
arm/s3c24xx/timer/timer.c, bfin/timer/timer.c,
m68k/mcf5206/timer/timer.c, m68k/mcf5272/timer/timer.c: Rename timer
driver methods to follow RTEMS programming conventions.
* sh7032/timer/timer.c, sh7045/timer/timer.c, sh7750/timer/timer.c:
Rename timer driver methods to follow RTEMS programming conventions.
* mpc505/timer/timer.c, mpc5xx/timer/timer.c, mpc6xx/timer/timer.c,
mpc8260/timer/timer.c, mpc8xx/timer/timer.c, ppc403/timer/timer.c:
* timer/timer.c: Rename timer driver methods to follow RTEMS
* mcf5206/timer/timer.c, mcf5206/timer/timerisr.S,
mcf5272/timer/timer.c, mcf5272/timer/timerisr.S: Rename timer driver
* at91rm9200/timer/timer.c, lpc22xx/timer/timer.c,
mc9328mxl/timer/timer.c, s3c2400/timer/timer.c,
s3c24xx/timer/timer.c: Rename timer driver methods to follow RTEMS
* timer/timer.c, timer/timerisr.S: Rename timer driver methods to
* timer/timer.c, timer/timerisr.c: Rename timer driver methods to
* console/console.c, include/m340timer.h, timer/timer.c: Rename timer
* bootcard.c: Fix formatting.
* console-polled.c: Error if minor < 2 not just <= 2.
* libchip/network/sonic.c: Do not declare a variable just to hold an
ignored return value.
* acinclude.m4: Add mcf52235 and mcf5329. Regenerate.
* acinclude.m4: Add bf537Stamp. Regenerate.
* Makefile.am, startup/bspstart.c: Use default bsp_pretasking_hook().
* Makefile.am: Remove another duplicate reference.
* Makefile.am: Remove duplicate reference.
* shared/vme/vme_universe.c: added implementation for
BSP_VMEResetBus().
* vmeUniverse/vmeTsi148.h, vmeUniverse/vmeTsi148.c:
added vmeTsi148ResetBusXX(), vmeTsi148ResetBus().
* timer/timer.c: Eliminate rtems_boolean.
* libnds/include/nds/jtypes.h: Use bool/stdbool.h instead of
local (non-POSIX compliant) "bool".
* Makefile.am: Remove stray include_HEADERS += irq/irq.h.
* lpc22xx/timer/timer.c: Remove broken bool implementation.
Remove unused vars.
Remove unused vars.
calc_dbat_regvals().
* shared/irq/irq_init.c: Reverse previous incorrect changes. Correct
warnings and ensure BSP still works.
* Makefile.am: Now named bspclean.c
RCS file: /usr1/CVS/rtems/c/src/lib/libcpu/powerpc/ChangeLog,v
retrieving revision 1.309
diff -u -r1.309 ChangeLog
--- ChangeLog 20 Aug 2008 17:29:18 -0000 1.309
+++ ChangeLog 22 Aug 2008 13:35:03 -0000
@@ -1,3 +1,8 @@
+2008-08-22 Sebastian Huber <sebastian.huber@embedded-brains.de>
+ * shared/include/powerpc-utility.h: Fixed parameter evaluation in
+ special purpose register macros.
2008-08-20 Sebastian Huber <sebastian.huber@embedded-brains.de>
* mpc55xx/fec/fec.c: Added copyright information.
* startup/bspclean.c: New file.
* startup/exit.c: Removed.
* Makefile.am: No BSP should use exit.c as a file name. exit() is POSIX
routine.
routine.
* Makefile.am: Added bspclean.c and use shared bsppretaskinghook.c.
* console/console.c: Added poll for char helper.
* include/bsp.h: Add macro definitions for optional reset behavior.
* startup/bspstart.c: Split out bsp_cleanup(). Clean up.
* startup/bspclean.c: New file. Not can press any key on normal
shutdown to reset board when on MPC8313erdb.
* startup/cpuinit.h: Uses now powerpc-utility.h. Changed invalid usage
of a boolean type to a proper integer type in calc_dbat_regvals().
Througout code formatting.
* libchip/i2c/spi-sd-card.c: Fixed integer conversion warnings.
* mpc55xx/dspi/dspi.c, mpc55xx/edma/edma.c, mpc55xx/esci/esci.c:
Fixed nexted extern declarations. Fixed integer conversion warnings.
* shared/include/cpuIdent.c: Added missing initializers.
* src/irq-generic.c: Fixed integer conversion warnings.
* include/mpc55xxevb.h, network/network.c, startup/sd-card-init.c,
tests/tests.c: Added copyright information. Added missing prototypes.
Fixed integer conversion warning.
* startup/bspclean.c: Include bootcard.h.
* include/tm27.h: Uses now a decrementer exception handler. Replaces
previous file.
* startup/bspstart.c: Install a default decrementer exception handler.
* block/block.c, console/console.c, dswifi/arm9/source/sgIP.h,
dswifi/arm9/source/sgIP_ARP.h, dswifi/arm9/source/sgIP_Config.h,
dswifi/arm9/source/sgIP_DHCP.h, dswifi/arm9/source/sgIP_DNS.h,
dswifi/arm9/source/sgIP_Hub.h, dswifi/arm9/source/sgIP_ICMP.h,
dswifi/arm9/source/sgIP_IP.h, dswifi/arm9/source/sgIP_TCP.h,
dswifi/arm9/source/sgIP_UDP.h, dswifi/arm9/source/sgIP_memblock.h,
dswifi/arm9/source/wifi_arm9.c, dswifi/arm9/source/wifi_arm9.h,
dswifi/include/dswifi7.h, dswifi/include/dswifi9.h, fb/fb.c,
include/my_ipc.h, libfat/source/disc_io/disc_io.h,
libfat/source/disc_io/io_nmmc.c,
libnds/include/nds/arm9/exceptions.h,
libnds/include/nds/arm9/input.h, libnds/include/nds/arm9/ndsmotion.h,
libnds/include/nds/arm9/videoGL.h, libnds/source/arm9/console.c,
libnds/source/arm9/gurumeditation.c, libnds/source/arm9/ndsmotion.c,
libnds/source/common/card.c, libnds/source/common/interrupts.c,
sound/sound.c, startup/start.c, touchscreen/reco.h, wifi/compat.c,
wifi/compat.h: Fix most warnings.
