* | dec21140.c: Fix PRIxx formatter | Joel Sherrill | 2017-04-20 | 1 | -1/+1 |
* | m68k/mrm332/./sci.c: Use inttypes.h constants removes 6 warnings. | Cillian O'Donnell | 2017-04-14 | 1 | -6/+7 |
* | powerpc/haleakala/./mmu_405.c: Use inttypes.h constants removes 11 warnings. | Cillian O'Donnell | 2017-04-14 | 1 | -6/+14 |
* | powerpc/mvme550/./pci.c: Use inttypes.h constant to fix 1 warning. | Cillian O'Donnell | 2017-04-14 | 1 | -1/+2 |
* | virtex4/startup/bspstart.c: Use %p to fix 11 warnings. | Cillian O'Donnell | 2017-04-14 | 1 | -13/+14 |
* | virtex5/startup/bspstart.c: Use %p to fix 11 warnings. | Cillian O'Donnell | 2017-04-14 | 1 | -13/+14 |
* | libbsp/.../sparc64/loader/main.c: Use inttypes.h constants to remove 1 warning | Cillian O'Donnell | 2017-04-14 | 1 | -1/+2 |
* | libchip/network/dec21140.c: Use inttypes.h to fix 1 warning. | Cillian O'Donnell | 2017-04-14 | 1 | -1/+3 |
* | libbsp/powerpc/./pci/detect_raven_bridge.c: Use inttypes.h to fix 1 warning. | Cillian O'Donnell | 2017-04-14 | 1 | -1/+2 |
* | bootstrap: regenerate files after sort order fix | Gedare Bloom | 2017-04-13 | 2 | -4/+4 |
| | | | | Updates #2965. | ||||
* | libcpu/../mpc5xx/.../vectors_init.c: Using inttype macros fixes 39 format ↵ | Cillian O'Donnell | 2017-04-07 | 1 | -39/+41 |
| | | | | warnings | ||||
* | lm32/shared/timer/timer.c: Include <rtems/bspIo.h> | Joel Sherrill | 2017-04-05 | 1 | -0/+1 |
* | lm32/shared/milkymist_video/video.c: Include <rtems/bspIo.h> | Joel Sherrill | 2017-04-05 | 1 | -0/+1 |
* | lm32/shared/milkymist_pfpu/pfpu.c: Fix indentation and braces | Joel Sherrill | 2017-04-05 | 1 | -4/+5 |
* | lm32/shared/milkymist_timer/timer.c: Include <rtems/bspIo.h> | Joel Sherrill | 2017-04-05 | 1 | -0/+1 |
* | lm32/shared/milkymist_framebuffer/framebuffer.c: Fix indentation and braces | Joel Sherrill | 2017-04-05 | 1 | -0/+1 |
* | bsp/qoriq: Comment out post-link hook | Sebastian Huber | 2017-04-05 | 1 | -6/+6 |
| | | | | | | The U-Boot mkimage is not available in general. Close #2969. | ||||
* | gen68340/startup/dumppanic.c: Fix warnings | Joel Sherrill | 2017-04-04 | 1 | -28/+28 |
* | lpc176x/../*-testsuite.tcfg: Add linpack | Joel Sherrill | 2017-04-04 | 3 | -0/+3 |
* | lpc24xx/../*-testsuite.tcfg: Add linpack | Joel Sherrill | 2017-04-04 | 2 | -0/+3 |
* | lpc32xx_mzx_stage_1-testsuite.tcfg: Add linpack | Joel Sherrill | 2017-04-04 | 1 | -0/+1 |
* | lm3s69xx/../*-testsuite.tcfg: Add linpack | Joel Sherrill | 2017-04-04 | 3 | -0/+3 |
* | atsamv-testsuite.tcfg: Add linpack | Joel Sherrill | 2017-04-04 | 1 | -0/+1 |
* | rtl22xx/../*-testsuite.tcfg: Add linpack | Joel Sherrill | 2017-04-04 | 2 | -0/+2 |
* | stm32f4/../*-testsuite.tcfg: Add linpack | Joel Sherrill | 2017-04-04 | 2 | -0/+2 |
* | tms570/../*-testsuite.tcfg: Add linpack | Joel Sherrill | 2017-04-04 | 3 | -0/+9 |
* | mpc55xxevb/.../*-testsuite.tcfg: Add linpack | Joel Sherrill | 2017-04-04 | 11 | -0/+17 |
* | mrm332-testsuite.tcfg: Add linpack | Joel Sherrill | 2017-04-04 | 1 | -0/+1 |
* | mcf5225x-testsuite.tcfg: Add linpack | Joel Sherrill | 2017-04-04 | 1 | -0/+1 |
* | mcf52235-testsuite.tcfg: Add linpack | Joel Sherrill | 2017-04-04 | 1 | -0/+1 |
* | gensh1-testsuite.tcfg: Add linpack | Joel Sherrill | 2017-04-04 | 1 | -0/+1 |
* | simsh*-testsuite.tcfg: Add linpack | Joel Sherrill | 2017-04-04 | 4 | -0/+4 |
* | gensh2-testsuite.tcfg: Add linpack | Joel Sherrill | 2017-04-04 | 1 | -0/+1 |
* | bsp/qoriq: Fix L1 cache flush | Sebastian Huber | 2017-04-03 | 1 | -6/+13 |
* | bsp/qoriq: Adjust MMU config only once | Sebastian Huber | 2017-04-03 | 3 | -5/+10 |
* | bsp/qoriq: Add post-link hook | Sebastian Huber | 2017-04-03 | 1 | -0/+7 |
* | bsps: Fix baud settings | Sebastian Huber | 2017-04-03 | 6 | -7/+7 |
| | | | | Update #2897. | ||||
* | arm: Optimize context switch | Sebastian Huber | 2017-03-28 | 1 | -12/+0 |
| | | | | | | | | | Set CPU_ENABLE_ROBUST_THREAD_DISPATCH to TRUE. In this case the interrupts are always enabled during a context switch even after interrupt processing (see #2751). Remove the CPSR from the context control since it contains only volatile bits. Close #2954. | ||||
* | bsp/qoriq: Regenerate preinstall.am | Sebastian Huber | 2017-03-27 | 1 | -4/+0 |
* | bsp/tms570: Use shared benchmark timer | Sebastian Huber | 2017-03-27 | 2 | -62/+1 |
* | bsps: Add simple CPU counter benchmark timer | Sebastian Huber | 2017-03-27 | 1 | -0/+35 |
* | bsp/tms570: Simplify CPU counter support | Sebastian Huber | 2017-03-27 | 1 | -63/+13 |
| | | | | Only touch the cycle counter settings. Do not enable user mode access. | ||||
* | bsps/arm: Add Performance Monitors Extension | Sebastian Huber | 2017-03-27 | 1 | -1/+446 |
* | bsp/tms570: Simplify <bsp.h> | Sebastian Huber | 2017-03-27 | 1 | -12/+0 |
* | bsp/tms570: Remove OPERATION_COUNT define | Sebastian Huber | 2017-03-27 | 1 | -3/+0 |
| | | | | This is the wrong place to define it. | ||||
* | termios: Synchronize with latest FreeBSD headers | Kevin Kirspel | 2017-03-22 | 38 | -100/+123 |
| | | | | | | | | | | | Adding modified FreeBSD headers to synchronize RTEMS termios with FreeBSD. Modify termios to support dedicated input and output baud for termios structure. Updated BSPs to use dedicated input and output baud in termios structure. Updated tools to use dedicated input and output baud in termios structure. Updated termios testsuites to use dedicated input and output baud in termios structure. Close #2897. | ||||
* | bsp/atsam: Fix DMA support of some drivers | Sebastian Huber | 2017-03-22 | 3 | -0/+3 |
* | libchip/serial/mc68681.c: Add error check | Joel Sherrill | 2017-03-14 | 1 | -0/+2 |
| | | | | This was spotted by Coverity Scan. | ||||
* | libbsp/mips/shared/irq/i8259.c: Add include of rtems/bspIo.h | Joel Sherrill | 2017-03-09 | 1 | -0/+1 |
* | libbsp/shared/clock/clockdrv.c: Remove unneeded printk() | Joel Sherrill | 2017-03-09 | 1 | -1/+0 |
