c/src/lib/librtems++ and c/src/lib/include/rtems++ to
their own package librtems++ at the top of the tree.
mkdir c/src/librtems++
cp c/src/lib/librtems++/README c/src/librtems++
mkdir c/src/librtems++/src
cp c/src/lib/librtems++/*.cc c/src/librtems++/src
cp c/src/lib/librtems++/Makefile.in c/src/librtems++/src
mkdir c/src/librtems++/include
mkdir c/src/librtems++/include/rtems++
cp c/src/lib/include/rtems++/*.h c/src/librtems++/include/rtems++
patch -p1 <rtems-rc-19990802-5.diff
rm -rf c/src/lib/librtems++
rm -rf c/src/lib/include/rtems++
Attention:
* The procedure above copies the files first, then patches them
and finally removes the old files afterwards. This has been done
to enable you to copy the files in CVS to preserve their history.
Somehow a nasty bug has made it in sh/start.S ("|", instead of "!", to
begin an asm comment).
I have no idea how this could remain undiscovered for so long (It is in
rtems-4.0.0, too!), however upgrading to binutils from sourceware's CVS
sh-rtems-as chokes on this bug. => I guess, either binutils changed its
conventions or an obvious bug in as has been fixed.
support for return codes from POSIX threads that do an implicit exit
by returning from the bottom of the main function.
This patch addresses a few configuration issues and removes some
duplicate configuration files.
Background:
* some files used in AC_INIT were not unique enough and can lead to
problems if a user plays with configure scripts.
* the Makefile templates are independent of the target/cpu and bsp, so
the bsp dependent versions (c/src/make/Templates) are removed.
patch -p1 < rtems-rc-19990820-3.diff
rm -f c/src/make/Templates
ATTENTION: This patch removes several files and one directory :)
1. Addition of maintainer-mode dependencies on config.status and
aclocal.m4 for autoconf toplevel Makefile.ins. These rules are taken
over from automake generated Makefile.ins, i.e. they are contained in
any automake generated toplevel Makefile.in. Having this patch in is at
least a great releaf for me when working on RTEMS configuration :)
2. Automated support for #1 in acpolish
3. Some minor "beautifications" on Makefile.ins resulting from running
acpolish.
FYI: This patch has been generated by running
tools/update/rtems-polish.sh -ac on the source tree and manually editing
the resulting patch afterwards to work around a problem with acpolish,
which still corrupts one Makefile.in - WARNING: Be careful with running
acpolish!
in the compiler not in the header file.
The patch below actually consists of 3 patches:
at least a great releaf for me when working on RTEMS configuration :)
running acpolish.
acpolish!
I expect this patch not to have any influence on normal users, unless
they use --enable-maintainer-mode, thus merging it should be rather
harmless.
running acpolish.
acpolish!
harmless.
fixed by Joel.
This one is a minor fix for the librdg-Makefiles for mcp750, mostly an
adaptation to the Makefiles used for the i386.
the minor number indicated the port number to try.
against 3.6.0 so was painful to merge. It should be OK but there
is no guarantee and there are no BSPs in the tree to exercise it.
Please take a look at this new patch. It contains a cleaner implementation
of the reset operation. These patches are against 4.0.0. But the files
did not change from the 3.6.0 release. Also, the cpu.h patch below still
applies. I.e. instead of using i960ca_PRCB, use i960_PRCB.
Explanation:
The previous patch removed the use of the reset instruction,
because it always fails. But this was due to the fact that
some of the registers were corrupted by the re-init procedure.
The new patches save and restore those registers when a re-init
is done.
configuration and unix/posix:
c/src/lib/libc/Makefile.in
only (was completely broken).
Linux-posix.cfg.
of other bsp's/CPU.
cd <srcdir>
and
cd c/src/lib; autoconf
or
After upgrading my linux box to the brand new SuSE 6.2 release, which is
glibc-2.1 based, I came across a bug in RTEMS - IIRC, I even warned you
about it about 1/2 a year ago, but nothing has been done since then :-.
The *.m4 macros to check for SYSV/IPC are broken for linux/glibc2.1,
because they assume that linux always defines union semun, which isn't
true anymore for glibc2.1 (the manpage for semctl states _X_OPEN
specifies it this way). Therefore I have tried to implement a more
general approach for handling SYSV for unix/posix which checks for
presence of struct semun, instead of trying to evaluate OS specific
preprocessor symbols.
This approach is a bit adventureous, because I only tested it with
linux/glibc2.1 and linux/libc5, but not under other Unix variants RTEMS
supports. I am quite confident it will work on other hosts, too, but who
knows :-.
[FYI: I think this might also is the cause of some problems with RedHat
6.X / Mandrake linux recently reported on the rtems list -- rtems-4.0.0
can not be build for posix on any glibc2.1 based host]
Furthermore the patch below contains a couple of minor fixes and
configuration cleanups, which IMO should be applied before releasing a
new snapshot.
To apply this patch:
patch -p1 < rtems-rc-19990709-8.diff
I'm attaching a big patch for the ts_386ex BSP which adds and includes
the following:
1) Conversion to ELF format + minor code cleanups + documentation.
2) An Ada95 binding to FreeBSD sockets, based on Samuel Tardieu's
adasockets-0.1.3 package. This includes some sample applications.
3) Some Ada and C interfaces to add serial-port debugging to
programs. Comes with examples, too; the Ada one shows how
transparent adding the support can be. Note that Rosimildo sent me
the original C code.
The network stuff is not BSP specific, and could be added to your Ada
code collection. The debugging stuff is specific to the i386. Right
now, everything sits in my "tools" directory.
Eric Valette <valette@crf.canon.fr>.
<raguet@crf.canon.fr>:
- the dec21140 driver code has been hardened (various bug fixed) Emmanuel,
- bug in the mcp750 init code have been fixed (interrupt stack/initial
stack initialization), BSS correctly cleared (Eric V)
- remote debugging over TCP/IP is nearly complete (berakpoints,
backtrace, variables,...) (Eric V),
- exception handling code has also been improved in order to fully
support RDBG requirements (Eric V),
problem with the HAS_MP patch and regenerated files.
I just released erc32ccs-2.0.6 which includes some fixes and the
Ada-self optimisation. Remote debugging of Ada programs did not
work due to a conflict between monior and rtems trap handlers.
I have attached a modified gnatsupp.c that makes remote debugging
possible again.
initialization typo and make i8259s_cache only accessed from C.
to fix problem reported by Ralf Corsepius <corsepiu@faw.uni-ulm.de>.
Date: Fri, 30 Jul 1999 14:53:20 -0500 (CDT)
it is used like this in i386ex/start/start.S
/* set up same values in cache */
start.S: movw $0xFFFB, SYM(i8259s_cache)
I am heading out the door. Any other ideas what could have tripped this?
This instruction appears in a .code16 section. In a .code16 section,
current versions of gas assume that all addresses are 16 bits unless
told otherwise.
If you change the line to
addr32 movw $0xFFFB, SYM(i8259s_cache)
then you will get a 32 bit address reference.
You may want to use addr32 only when NEW_GAS is defined.
cd <srcdir>
CHANGES
autoconf check
autoconf check
$(prefix)/<bsp>/make/bsp.cfg
compatible.
Makefile.ins
Problem: a posix thread which is created by
pthread_attr_init(&tattr);
pthread_attr_setinheritsched(&tattr, PTHREAD_EXPLICIT_SCHED);
pthread_attr_setschedpolicy(&tattr, SCHED_RR);
pthread_create(&th, &tattr, func, arg);
has a first timeslice of 2^32 ticks (changing a running thread to
SCHED_RR id ok).
I use RTEMS-4.0.0. I am not sure if the problem exists in the current CVS
head revision. If it's not fixed, the patch at the end should do it.
Peter
--- pthreadcreate.c.orig Wed Jul 28 14:45:58 1999
+++ pthreadcreate.c Wed Jul 28 15:06:09 1999
@@ -199,6 +199,10 @@
api->schedpolicy = schedpolicy;
api->schedparam = schedparam;
+ if ( schedpolicy == SCHED_RR ) {
+ the_thread->cpu_time_budget = _Thread_Ticks_per_timeslice;
* This insures we evaluate the process-wide signals pending when we
* first run.
This file is necessary because the bootloader is compiled with different
options than the basic C library.
to address m68k-rtemself for the MVME167.
Here is the rtems patch I promissed you a long time ago to enable ELF
with m68k. The target name I selected is m68k-rtemself. It preserves the
m68k-rtems COFF target, and is parterned after the other ELF/COFF dual
targets.
The mvme167.cfg file causes the -qelf flag to be used during compilation
if the name of the compiler contains rtemself. This flag is used in the
bsp_specs file to select the elflinkcmds file rather than the linkcmds
file. The former is for ELF, the latter for COFF.
Some patches are required to the mc68040 FPSP code. Some of the
assembler files contain instructions that were rejected by the
m68k-rtemself-as assembler. This is a minor bug in the m68k ELF
assembler, I think.
from Jay Kulpinski <jskulpin@eng01.gdds.com>.
bug report from David Decotigny <David.Decotigny@irisa.fr>:
During the last few days, I've been back working on RTEMS. Let me
remind you that RTEMS didn't boot on our (old) Dell P90 machines (ref:
PC 590) : we could only get a reboot out of them.
1/ The symptoms
Hopefully, the problem was rather deterministic. The stack couldn't be
written correctly : issueing one or more "push" would always push '0'
onto the stack. The way to solve this was to issue a "pop", such as
"pushl eax ; popl eax". After this "pop", the stack would be writeable
again.
BUT, it will be writable for 8 consecutive "push"s. After these 8
"push"s, the other "push"s are wrong again, and a blank push/pop is
needed.
Considering that the L1 cache lines of this pentium are 32 bytes long,
and that 8 long int are 32 bytes long too, it came to us that there
was a problem with the cache.
Actually, the bug of the push could be shown through memory accesses
directly : writing on an not-in-cache mem location would put 0 until
this mem location is accessed through a single "read". Then, the whole
cache line would be right again.
2/ The consequences
Of course, that was the first thing that we've been able to observe ;)
RTEMS could not boot. Actually, when a "call" pushed 0 onto the stack,
the ret could only lead to raise an exception a bit later. Since, in
the early stage, the Interrupt vector points to 0, averything couldn't
get worse : triple fault + reboot.
3/ Explanation
This cache mechanism corruption only appeared after load_segment()
returned (through a jump). Investigating a bit further shows that this
appears /sometimes/ during the PICs initialization.
"Sometimes" proved to be "When writing something with the 4th bit of
%al set". That is "when writing 0x28 or 0xff" for example. Clearing
this bit would just make the things work right.
Actually, this isn't a bug in the proper PIC initialization (which is
quite academic). It came from the "delay" routine, which theoretically
does nothing but writing to an "inexistant" port (0xed), in order to
lose some time.
BUT, in the special case of our Dell P90, it appears that this 0xed
port does something cruel with the cache mechanism when its 4th bit
(aka bit 3 or 0x8) is set.
I didn't investigate this non-standard behaviour of the P90 any
further : I don't know if this is documented, or if it is just another
(known ?) bug of the early Pentiums. Just notice that we have 5 such
machines, and it has the same effect on the cache mechanism.
CHANGES:
c/Makefile.am removed
still in - remove it?)
(Cygwin support)
REMARK:
inside the build-tree.
APPLYING THE PATCH
autogen
