* | 2011-03-08 Joel Sherrill <joel.sherrilL@OARcorp.com> | Joel Sherrill | 2011-03-09 | 2 | -2/+7 |
| | | | | | PR 1760/misc * compilers/gcc-target-default.cfg: Fix typo in CPP definition. | ||||
* | 2011-03-08 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2011-03-08 | 2 | -5/+9 |
| | | | | | * Makefile.inc.in: Fix PROJECT_ROOT to match usage in templates and existing Makefiles. | ||||
* | 2011-03-07 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2011-03-07 | 3 | -4/+67 |
| | | | | * Makefile.am, configure.ac: Move file generation into Makefile. | ||||
* | 2011-03-07 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2011-03-07 | 2 | -1/+5 |
| | | | | * Makefile.inc.in: Set PROJECT_ROOT = @pkgdatadir@. | ||||
| | | | | * Makefile.am: Install *.cfgs into $(pkgdatadir)/make. | ||||
* | 2011-03-07 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2011-03-07 | 2 | -0/+2 |
| | | | | * aclocal/rtems-top.m4: Add pkgdatadir. | ||||
* | 2011-03-07 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2011-03-07 | 2 | -3/+4 |
| | | | | * configure.ac: Remove dead code. | ||||
* | 2011-03-07 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2011-03-07 | 2 | -2/+5 |
| | | | | | PR 1753/misc: * host.cfg.in: Remove RTEMS_HOST. | ||||
* | 2011-03-05 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2011-03-05 | 2 | -5/+5 |
| | | | | | PR 1754/misc: * host.cfg.in: Remove GCCSED. | ||||
* | 2011-03-04 Joel Sherrill <joel.sherrilL@OARcorp.com> | Joel Sherrill | 2011-03-04 | 2 | -8/+27 |
| | | | | * timer/timer.c: Retry up to 5 times when the calibration loop fails. | ||||
* | 2011-03-04 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2011-03-04 | 2 | -1/+5 |
| | | | | * configure.ac: Rename RTEMS_API into _RTEMS_API. | ||||
* | 2011-03-04 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2011-03-04 | 3 | -2/+7 |
| | | | | | * aclocal/rtems-top.m4, aclocal/version.m4: Rename RTEMS_API into _RTEMS_API. | ||||
* | 2011-03-04 Till Straumann <strauman@slac.stanford.edu> | Joel Sherrill | 2011-03-04 | 4 | -30/+66 |
| | | | | | | | PR 1738/bsps * clock/clock.c, include/bsp.h, network/network.c: system clock driver programs the PIT w/o assuming the CPU clock frequency being a power of two. | ||||
* | 2011-03-04 Joel Sherrill <joel.sherrilL@OARcorp.com> | Joel Sherrill | 2011-03-04 | 2 | -1/+7 |
| | | | | | | PR 1751/bsps * start/start.S: Fix typo which was not caught by binutils prior to a recent bug fix. | ||||
* | 2011-03-04 Joel Sherrill <joel.sherrilL@OARcorp.com> | Joel Sherrill | 2011-03-04 | 3 | -6/+21 |
| | | | | | | | | PR 1748/bsps * clock/ckinit.c, include/leon.h: When the clock tick generates an interrupt WHILE we have interrupts disabled doing a get TOD or uptime, the get nanoseconds handler was returning a bogusly large number. | ||||
* | 2011-03-04 Joel Sherrill <joel.sherrilL@OARcorp.com> | Joel Sherrill | 2011-03-04 | 4 | -7/+30 |
| | | | | | | | PR 1748/bsps * clock/ckinit.c: When the clock tick generates an interrupt WHILE we have interrupts disabled doing a get TOD or uptime, the get nanoseconds handler was returning a bogusly large number. | ||||
* | 2011-03-03 Joel Sherrill <joel.sherrilL@OARcorp.com> | Joel Sherrill | 2011-03-03 | 2 | -162/+169 |
| | | | | | | | PR 1750/bsps * console/erc32_console.c, make/custom/erc32.cfg: The new console driver did not support polled mode. It also had a bug in which it could lose a transmitter interrupt. | ||||
* | 2011-03-01 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2011-03-01 | 2 | -4/+5 |
| | | | | | * acinclude.m4: Regenerate (Reflect the i386ex and tx_386ex BSP have been removed.). | ||||
* | Remove (Abandoned). | Ralf Corsepius | 2011-03-01 | 114 | -16513/+0 |
* | 2011-02-28 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2011-02-28 | 2 | -11/+68 |
| | | | | | * console/erc32_console.c: Add polled support. Tinker with interrupt handler to not dequeue characters unless TX is empty. | ||||
* | 2011-02-28 Sebastian Huber <sebastian.huber@embedded-brains.de> | Sebastian Huber | 2011-02-28 | 2 | -58/+31 |
| | | | | | * console.c: Register also normal device file of the console device. Call initialization before the device file registration. | ||||
* | 2011-02-25 Sebastian Huber <sebastian.huber@embedded-brains.de> | Sebastian Huber | 2011-02-25 | 2 | -22/+39 |
| | | | | | | * mpc83xx/network/tsec.c: New default MAC configuration. Set MDIO clock according to actual CCB frequency. Print media info only if we have a PHY. Avoid infinite loop in media adaption. | ||||
* | 2011-02-25 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2011-02-25 | 2 | -2/+4 |
| | | | | * configure.ac: Remove RTEMS_CANONICAL_TARGET_CPU. | ||||
* | 2011-02-25 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2011-02-25 | 2 | -4/+8 |
| | | | | | | * configure.ac: Remove RTEMS_CANONICAL_TARGET_CPU. Remove AC_ARG_VAR([RTEMS_BSP],[]). Add RTEMS_ENV_RTEMSBSP. | ||||
* | 2011-02-25 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2011-02-25 | 12 | -12/+24 |
* | 2011-02-25 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2011-02-25 | 2 | -3/+6 |
| | | | | | * tools/configure.ac: Remove RTEMS_CANONICAL_TARGET_CPU. Fix package name. | ||||
* | 2011-02-25 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2011-02-25 | 2 | -8/+17 |
| | | | | | | | * aclocal/canonical-target-name.m4: Stop pretending no_cpu* was buildable. Derive RTEMS_CPU from "$host_cpu". Error out if "$host" doesn't match "*-*-rtems*". | ||||
* | 2011-02-22 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2011-02-22 | 2 | -2/+4 |
| | | | | * configure.ac: Remove AM_CONDITIONAL(HAS_POSIX) (Unused). | ||||
* | 2011-02-21 Joel Sherrill <joel.sherrilL@OARcorp.com> | Joel Sherrill | 2011-02-21 | 2 | -1/+5 |
| | | | | * timer/timer.c: Include <bsp.h> before <rtems/btimer.h>. | ||||
* | 2011-02-21 Sebastian Huber <sebastian.huber@embedded-brains.de> | Sebastian Huber | 2011-02-21 | 4 | -0/+52 |
| | | | | | | * misc/restart.c: New file. * Makefile.am: Reflect change from above. * include/bsp.h: Declare bsp_restart(). | ||||
* | Typo. | Sebastian Huber | 2011-02-21 | 1 | -1/+1 |
* | 2010-02-21 Sebastian Huber <sebastian.huber@embedded-brains.de> | Sebastian Huber | 2011-02-21 | 3 | -8/+16 |
| | | | | | * include/bsp.h, lpc32xx/misc/restart.c: Renamed lpc32xx_restart() in bsp_restart(). | ||||
* | 2011-02-17 Till Straumann <strauman@slac.stanford.edu> | Joel Sherrill | 2011-02-17 | 5 | -326/+442 |
| | | | | | | | | | PR 1738/bsps * README, startup/bspstart.c, startup/linkcmds: Add support for dynamic clock speed determination. This algorithm is described in the README file. The output of the RTEMS Timing Tests was moved to TIMES to signicantly shrink the README. * TIMES: New file. | ||||
* | 2011-02-17 Sebastian Huber <sebastian.huber@embedded-brains.de> | Sebastian Huber | 2011-02-17 | 2 | -70/+85 |
| | | | | | | * new-exceptions/bspsupport/vectors.h: Added defines PPC_EXC_GPR_TYPE, PPC_EXC_GPR_SIZE, PPC_EXC_GPR_OFFSET, PPC_EXC_MINIMAL_FRAME_SIZE, and PPC_EXC_FRAME_SIZE. Changed layout of BSP_Exception_frame. | ||||
* | 2011-02-17 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2011-02-17 | 2 | -0/+12 |
| | | | | * new-exceptions/bspsupport/vectors.h: Add extern "C" {}. | ||||
* | 2011-02-16 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2011-02-16 | 228 | -2636/+2832 |
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | * ada-tests/mptests/mp01/mp01.adb, ada-tests/mptests/mp01/mptest.adb, ada-tests/mptests/mp01/mptest.ads, ada-tests/mptests/mp01/node1/mp01_node1.adb, ada-tests/mptests/mp01/node2/mp01_node2.adb, ada-tests/mptests/mp02/mptest.adb, ada-tests/mptests/mp02/mptest.ads, ada-tests/mptests/mp02/node1/mp02_node1.adb, ada-tests/mptests/mp02/node2/mp02_node2.adb, ada-tests/mptests/mp03/mptest.adb, ada-tests/mptests/mp03/mptest.ads, ada-tests/mptests/mp03/node1/mp03_node1.adb, ada-tests/mptests/mp03/node2/mp03_node2.adb, ada-tests/mptests/mp04/mptest.adb, ada-tests/mptests/mp04/mptest.ads, ada-tests/mptests/mp04/node1/mp04_node1.adb, ada-tests/mptests/mp04/node2/mp04_node2.adb, ada-tests/mptests/mp05/mptest.adb, ada-tests/mptests/mp05/mptest.ads, ada-tests/mptests/mp05/node1/mp05_node1.adb, ada-tests/mptests/mp05/node2/mp05_node2.adb, ada-tests/mptests/mp06/mptest.adb, ada-tests/mptests/mp06/mptest.ads, ada-tests/mptests/mp06/node1/mp06_node1.adb, ada-tests/mptests/mp06/node2/mp06_node2.adb, ada-tests/mptests/mp07/mptest.adb, ada-tests/mptests/mp07/mptest.ads, ada-tests/mptests/mp07/node1/mp07_node1.adb, ada-tests/mptests/mp07/node2/mp07_node2.adb, ada-tests/mptests/mp08/mptest.adb, ada-tests/mptests/mp08/mptest.ads, ada-tests/mptests/mp08/node1/mp08_node1.adb, ada-tests/mptests/mp08/node2/mp08_node2.adb, ada-tests/mptests/mp09/mptest.adb, ada-tests/mptests/mp09/mptest.ads, ada-tests/mptests/mp09/node1/mp09_node1.adb, ada-tests/mptests/mp09/node2/mp09_node2.adb, ada-tests/mptests/mp10/mptest.adb, ada-tests/mptests/mp10/mptest.ads, ada-tests/mptests/mp10/node1/mp10_node1.adb, ada-tests/mptests/mp10/node2/mp10_node2.adb, ada-tests/mptests/mp11/mptest.adb, ada-tests/mptests/mp11/mptest.ads, ada-tests/mptests/mp11/node1/mp11_node1.adb, ada-tests/mptests/mp11/node2/mp11_node2.adb, ada-tests/mptests/mp12/mptest.adb, ada-tests/mptests/mp12/mptest.ads, ada-tests/mptests/mp12/node1/mp12_node1.adb, ada-tests/mptests/mp12/node2/mp12_node2.adb, ada-tests/mptests/mp13/mptest.adb, ada-tests/mptests/mp13/mptest.ads, ada-tests/mptests/mp13/node1/mp13_node1.adb, ada-tests/mptests/mp13/node2/mp13_node2.adb, ada-tests/mptests/mp14/mptest.adb, ada-tests/mptests/mp14/mptest.ads, ada-tests/mptests/mp14/node1/mp14_node1.adb, ada-tests/mptests/mp14/node2/mp14_node2.adb, ada-tests/samples/base_mp/mptest.adb, ada-tests/samples/base_mp/mptest.ads, ada-tests/samples/base_sp/base_sp.adb, ada-tests/samples/base_sp/sptest.adb, ada-tests/samples/base_sp/sptest.ads, ada-tests/samples/hello/hello.adb, ada-tests/samples/hello/sptest.adb, ada-tests/samples/hello/sptest.ads, ada-tests/samples/nsecs/nsecs.adb, ada-tests/samples/nsecs/sptest.adb, ada-tests/samples/nsecs/sptest.ads, ada-tests/samples/ticker/sptest.adb, ada-tests/samples/ticker/sptest.ads, ada-tests/samples/ticker/ticker.adb, ada-tests/sptests/sp01/sp01.adb, ada-tests/sptests/sp01/sptest.adb, ada-tests/sptests/sp01/sptest.ads, ada-tests/sptests/sp02/sp02.adb, ada-tests/sptests/sp02/sptest.adb, ada-tests/sptests/sp02/sptest.ads, ada-tests/sptests/sp03/sp03.adb, ada-tests/sptests/sp03/sptest.adb, ada-tests/sptests/sp03/sptest.ads, ada-tests/sptests/sp04/sp04.adb, ada-tests/sptests/sp04/sptest.adb, ada-tests/sptests/sp04/sptest.ads, ada-tests/sptests/sp05/sp05.adb, ada-tests/sptests/sp05/sptest.adb, ada-tests/sptests/sp05/sptest.ads, ada-tests/sptests/sp06/sp06.adb, ada-tests/sptests/sp06/sptest.adb, ada-tests/sptests/sp06/sptest.ads, ada-tests/sptests/sp07/sp07.adb, ada-tests/sptests/sp07/sptest.adb, ada-tests/sptests/sp07/sptest.ads, ada-tests/sptests/sp08/sp08.adb, ada-tests/sptests/sp08/sptest.adb, ada-tests/sptests/sp08/sptest.ads, ada-tests/sptests/sp09/sp09.adb, ada-tests/sptests/sp09/sptest.adb, ada-tests/sptests/sp09/sptest.ads, ada-tests/sptests/sp11/sp11.adb, ada-tests/sptests/sp11/sptest.adb, ada-tests/sptests/sp11/sptest.ads, ada-tests/sptests/sp12/sp12.adb, ada-tests/sptests/sp12/sptest.adb, ada-tests/sptests/sp12/sptest.ads, ada-tests/sptests/sp13/sp13.adb, ada-tests/sptests/sp13/sptest.adb, ada-tests/sptests/sp13/sptest.ads, ada-tests/sptests/sp14/sp14.adb, ada-tests/sptests/sp14/sptest.adb, ada-tests/sptests/sp14/sptest.ads, ada-tests/sptests/sp15/sp15.adb, ada-tests/sptests/sp15/sptest.adb, ada-tests/sptests/sp15/sptest.ads, ada-tests/sptests/sp16/sp16.adb, ada-tests/sptests/sp16/sptest.adb, ada-tests/sptests/sp16/sptest.ads, ada-tests/sptests/sp17/sp17.adb, ada-tests/sptests/sp17/sptest.adb, ada-tests/sptests/sp17/sptest.ads, ada-tests/sptests/sp19/sp19.adb, ada-tests/sptests/sp19/sptest.adp, ada-tests/sptests/sp19/sptest.ads, ada-tests/sptests/sp20/sp20.adb, ada-tests/sptests/sp20/sptest.adb, ada-tests/sptests/sp20/sptest.ads, ada-tests/sptests/sp22/sp22.adb, ada-tests/sptests/sp22/sptest.adb, ada-tests/sptests/sp22/sptest.ads, ada-tests/sptests/sp23/sp23.adb, ada-tests/sptests/sp23/sptest.adb, ada-tests/sptests/sp23/sptest.ads, ada-tests/sptests/sp24/sp24.adb, ada-tests/sptests/sp24/sptest.adb, ada-tests/sptests/sp24/sptest.ads, ada-tests/sptests/sp25/sp25.adb, ada-tests/sptests/sp25/sptest.adb, ada-tests/sptests/sp25/sptest.ads, ada-tests/support/test_support.adb, ada-tests/tmtests/tm01/tm01.adb, ada-tests/tmtests/tm01/tmtest.adb, ada-tests/tmtests/tm01/tmtest.ads, ada-tests/tmtests/tm02/tm02.adb, ada-tests/tmtests/tm02/tmtest.adb, ada-tests/tmtests/tm02/tmtest.ads, ada-tests/tmtests/tm03/tm03.adb, ada-tests/tmtests/tm03/tmtest.adb, ada-tests/tmtests/tm03/tmtest.ads, ada-tests/tmtests/tm04/tm04.adb, ada-tests/tmtests/tm04/tmtest.adb, ada-tests/tmtests/tm04/tmtest.ads, ada-tests/tmtests/tm05/tm05.adb, ada-tests/tmtests/tm05/tmtest.adb, ada-tests/tmtests/tm05/tmtest.ads, ada-tests/tmtests/tm06/tm06.adb, ada-tests/tmtests/tm06/tmtest.adb, ada-tests/tmtests/tm06/tmtest.ads, ada-tests/tmtests/tm07/tm07.adb, ada-tests/tmtests/tm07/tmtest.adb, ada-tests/tmtests/tm07/tmtest.ads, ada-tests/tmtests/tm08/tm08.adb, ada-tests/tmtests/tm08/tmtest.adb, ada-tests/tmtests/tm08/tmtest.ads, ada-tests/tmtests/tm09/tm09.adb, ada-tests/tmtests/tm09/tmtest.adb, ada-tests/tmtests/tm09/tmtest.ads, ada-tests/tmtests/tm10/tm10.adb, ada-tests/tmtests/tm10/tmtest.adb, ada-tests/tmtests/tm10/tmtest.ads, ada-tests/tmtests/tm11/tm11.adb, ada-tests/tmtests/tm11/tmtest.adb, ada-tests/tmtests/tm11/tmtest.ads, ada-tests/tmtests/tm12/tm12.adb, ada-tests/tmtests/tm12/tmtest.adb, ada-tests/tmtests/tm12/tmtest.ads, ada-tests/tmtests/tm13/tm13.adb, ada-tests/tmtests/tm13/tmtest.adb, ada-tests/tmtests/tm13/tmtest.ads, ada-tests/tmtests/tm14/tm14.adb, ada-tests/tmtests/tm14/tmtest.adb, ada-tests/tmtests/tm14/tmtest.ads, ada-tests/tmtests/tm15/tm15.adb, ada-tests/tmtests/tm15/tmtest.adb, ada-tests/tmtests/tm15/tmtest.ads, ada-tests/tmtests/tm16/tm16.adb, ada-tests/tmtests/tm16/tmtest.adb, ada-tests/tmtests/tm16/tmtest.ads, ada-tests/tmtests/tm17/tm17.adb, ada-tests/tmtests/tm17/tmtest.adb, ada-tests/tmtests/tm17/tmtest.ads, ada-tests/tmtests/tm18/tm18.adb, ada-tests/tmtests/tm18/tmtest.adb, ada-tests/tmtests/tm18/tmtest.ads, ada-tests/tmtests/tm19/tm19.adb, ada-tests/tmtests/tm19/tmtest.adb, ada-tests/tmtests/tm19/tmtest.ads, ada-tests/tmtests/tm20/tm20.adb, ada-tests/tmtests/tm20/tmtest.adb, ada-tests/tmtests/tm20/tmtest.ads, ada-tests/tmtests/tm21/tm21.adb, ada-tests/tmtests/tm21/tmtest.adb, ada-tests/tmtests/tm21/tmtest.ads, ada-tests/tmtests/tm22/tm22.adb, ada-tests/tmtests/tm22/tmtest.adb, ada-tests/tmtests/tm22/tmtest.ads, ada-tests/tmtests/tm23/tm23.adb, ada-tests/tmtests/tm23/tmtest.adb, ada-tests/tmtests/tm23/tmtest.ads, ada-tests/tmtests/tm24/tm24.adb, ada-tests/tmtests/tm24/tmtest.adb, ada-tests/tmtests/tm24/tmtest.ads, ada-tests/tmtests/tm25/tm25.adb, ada-tests/tmtests/tm25/tmtest.adb, ada-tests/tmtests/tm25/tmtest.ads, ada-tests/tmtests/tm28/tm28.adb, ada-tests/tmtests/tm28/tmtest.adb, ada-tests/tmtests/tm28/tmtest.ads, ada-tests/tmtests/tm29/tm29.adb, ada-tests/tmtests/tm29/tmtest.adb, ada-tests/tmtests/tm29/tmtest.ads, ada-tests/tmtests/tmck/tmck.adb, ada-tests/tmtests/tmck/tmtest.adb, ada-tests/tmtests/tmck/tmtest.ads, ada-tests/tmtests/tmoverhd/dummy_rtems.adb, ada-tests/tmtests/tmoverhd/dummy_rtems.ads, ada-tests/tmtests/tmoverhd/tmoverhd.adb, ada-tests/tmtests/tmoverhd/tmtest.adb, ada-tests/tmtests/tmoverhd/tmtest.ads: Account for RTEMS binding child package rework. Eliminate all warnings. | ||||
* | 2011-02-16 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2011-02-16 | 42 | -3212/+4442 |
| | | | | | | | | | | | | | | | | | | | | | * ada/Makefile.am, ada/preinstall.am, ada/rtems.adb, ada/rtems.ads: Split RTEMS Ada95 binding into a master package and a child package per Manager. This is better Ada style. * ada/rtems-barrier.adb, ada/rtems-barrier.ads, ada/rtems-clock.adb, ada/rtems-clock.ads, ada/rtems-cpu_usage.ads, ada/rtems-debug.adb, ada/rtems-debug.ads, ada/rtems-event.adb, ada/rtems-event.ads, ada/rtems-extension.adb, ada/rtems-extension.ads, ada/rtems-fatal.adb, ada/rtems-fatal.ads, ada/rtems-interrupt.ads, ada/rtems-io.adb, ada/rtems-io.ads, ada/rtems-message_queue.adb, ada/rtems-message_queue.ads, ada/rtems-object.adb, ada/rtems-object.ads, ada/rtems-partition.adb, ada/rtems-partition.ads, ada/rtems-port.adb, ada/rtems-port.ads, ada/rtems-rate_monotonic.adb, ada/rtems-rate_monotonic.ads, ada/rtems-region.adb, ada/rtems-region.ads, ada/rtems-semaphore.adb, ada/rtems-semaphore.ads, ada/rtems-signal.adb, ada/rtems-signal.ads, ada/rtems-stack_checker.ads, ada/rtems-tasks.adb, ada/rtems-tasks.ads, ada/rtems-timer.adb, ada/rtems-timer.ads: New files. | ||||
* | 2011-02-16 Sebastian Huber <sebastian.huber@embedded-brains.de> | Sebastian Huber | 2011-02-16 | 2 | -2/+204 |
| | | | | | | * shared/include/powerpc-utility.h: Fixed LINKER_SYMBOL() for assembler compatibilty. Added synchronization, cache, and alternate time base functions. | ||||
* | 2011-02-16 Sebastian Huber <sebastian.huber@embedded-brains.de> | Sebastian Huber | 2011-02-16 | 2 | -27/+15 |
| | | | | | * libchip/serial/ns16550.c: Revert previous commit and extend existing mechanic. | ||||
* | 2011-02-15 Jennifer Averett | Joel Sherrill | 2011-02-15 | 3 | -8/+30 |
| | | | | | * libchip/serial/ns16550.c, libchip/serial/ns16550_p.h: Support i386 style IRQs. | ||||
* | 2011-02-15 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2011-02-15 | 2 | -0/+10 |
| | | | | * ChangeLog, shared/start/start.S: Add HLT instruction on exit. | ||||
* | 2011-02-15 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2011-02-15 | 2 | -0/+9 |
| | | | | * ChangeLog, start/start.S: Add HLT instruction on exit. | ||||
* | 2011-02-14 Joel Sherrill <joel.sherrilL@OARcorp.com> | Joel Sherrill | 2011-02-14 | 2 | -1/+5 |
| | | | | * shared/irq/irq_asm.S: Fix typo. | ||||
* | 2011-02-11 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2011-02-11 | 2 | -1/+6 |
| | | | | | * dswifi/common/source/spinlock.h: Use "__asm__" instead of "__asm" for improved c99-compliance. | ||||
| | | | | | * mpc55xx/include/mpc55xx.h: Use "__asm__" instead of "asm" for improved c99-compliance. | ||||
* | 2011-02-11 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2011-02-11 | 5 | -5/+5 |
| | | | | | | | | | | * sh7032/delay/delay.c, sh7032/score/cpu_asm.c, sh7032/score/ispsh7032.c, sh7045/sci/sci.c, sh7045/sci/sci_termios.c, sh7045/score/cpu_asm.c, sh7045/score/ispsh7045.c, sh7750/sci/sh4uart.c, sh7750/score/cpu_asm.c, sh7750/score/ispsh7750.c, shgdb/score/cpu_asm.c, shgdb/score/ispshgdb.c: Use "__asm__" instead of "asm" for improved c99-compliance. | ||||
| | | | | | * libchip/network/smc91111config.h: Use "__asm__" instead of "asm" for improved c99-compliance. | ||||
* | 2011-02-11 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2011-02-11 | 4 | -2/+12 |
| | | | | | * shmsupp/lock.c: Use "__asm__" instead of "asm" for improved c99-compliance. | ||||
* | 2011-02-11 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2011-02-11 | 6 | -9/+24 |
| | | | | | * include/tm27.h: Use "__asm__" instead of "asm" for improved c99-compliance. |
