* | Remove RTEMS_CFLAGS. | Ralf Corsepius | 2009-10-23 | 2 | -10/+2 |
* | 2009-10-23 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2009-10-23 | 1 | -0/+6 |
| | | | | | | * configure.ac: Rework CFLAGS setup. * aclocal/prog-cc.m4: Remove RTEMS_CFLAGS. * automake/compile.am: Remove RTEMS_CFLAGS. | ||||
* | Rework CFLAGS setup. | Ralf Corsepius | 2009-10-23 | 1 | -2/+10 |
* | add new files for exception handler | Thomas Doerfler | 2009-10-23 | 9 | -0/+1232 |
* | Fix broken formating. | Ralf Corsepius | 2009-10-23 | 1 | -1/+2 |
* | 2009-10-23 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2009-10-23 | 1 | -0/+5 |
| | | | | | * console/console.c: Include <rtems/error.h>. * spi/spi.c: Remove m8xx_spi_softc_ptr (Unused). | ||||
* | Remove m8xx_spi_softc_ptr (Unused). | Ralf Corsepius | 2009-10-23 | 1 | -1/+1 |
* | Include <rtems/error.h>. | Ralf Corsepius | 2009-10-23 | 1 | -1/+1 |
* | Update for exception support changes. | Thomas Doerfler | 2009-10-23 | 103 | -1580/+1601 |
* | 2009-10-23 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2009-10-23 | 3 | -1/+7 |
| | | | | | * irq/irq.h: Add BSP_irq_enabled_at_cpm. * network/network.c: Remove local decl of BSP_irq_enabled_at_cpm. | ||||
* | 2009-10-23 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2009-10-23 | 6 | -12/+34 |
| | | | | | | | * irq/BSP_irq.c, network/if_100MHz/GT64260eth.c, network/if_1GHz/if_wm.c, network/if_1GHz/pci_map.c, startup/bspstart.c: Add missing prototypes. Adjust bogus types. Remove unused vars. | ||||
* | 2009-10-22 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2009-10-22 | 2 | -2/+5 |
| | | | | | * new-exceptions/bspsupport/vectors_init.c: Remove duplicate defines DEAR_BOOKE, DEAR_405. | ||||
* | 2009-10-22 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2009-10-22 | 2 | -4/+8 |
| | | | | * libchip/ide/ata.h: Move extern "C". | ||||
* | 2009-10-22 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2009-10-22 | 1 | -0/+5 |
| | | | | | * clock/clock-config.c, misc/dma.c, network/network.c, rtc/rtc-config.c, ssp/ssp.c: Remove unused vars. | ||||
* | Remove unused vars. | Ralf Corsepius | 2009-10-22 | 5 | -9/+0 |
* | 2009-10-22 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2009-10-22 | 1 | -0/+8 |
| | | | | | | | | * libchip/i2c/spi-flash-m25p40.c, libchip/i2c/spi-fram-fm25l256.c: Use hex-constants to avoid implicit int-casts. * libchip/i2c/spi-memdrv.c: Use hex-constants to avoid implicit int-casts. Use rtems_off64_t offsets to avoid loosing precision. | ||||
* | Use hex-constants to avoid implicit int-casts. | Ralf Corsepius | 2009-10-22 | 1 | -4/+4 |
* | Use hex-constants to avoid implicit int-casts. | Ralf Corsepius | 2009-10-22 | 2 | -8/+8 |
* | 2009-10-22 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2009-10-22 | 3 | -4/+10 |
| | | | | | | * clock/clock.c: Add missing prototypes. Remove argument from clockOff(). * tod/pcf8563.c: Add missing const. | ||||
* | 2009-10-22 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2009-10-22 | 2 | -3/+7 |
| | | | | * mpc6xx/mmu/bat.c: Add missing prototypes. | ||||
* | add missing change | Thomas Doerfler | 2009-10-21 | 2 | -4/+16 |
* | various maintenance changes | Thomas Doerfler | 2009-10-21 | 3 | -0/+999 |
* | removed erronously added spi.c and spi.h | Thomas Doerfler | 2009-10-21 | 2 | -993/+0 |
* | add missing file | Thomas Doerfler | 2009-10-21 | 2 | -0/+993 |
* | interrupt handler type change | Thomas Doerfler | 2009-10-21 | 29 | -245/+129 |
* | 2009-10-21 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2009-10-21 | 3 | -6/+5 |
| | | | | | * make/custom/c3xsim.cfg: Remove RTEMS_BSP_FAMILY. * make/custom/c4xsim.cfg: Remove RTEMS_BSP_FAMILY. | ||||
* | 2009-10-21 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2009-10-21 | 2 | -3/+4 |
| | | | | * make/custom/leon3.cfg: Remove RTEMS_BSP_FAMILY. | ||||
* | 2009-10-21 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2009-10-21 | 2 | -2/+4 |
| | | | | * make/custom/leon2.cfg: Remove RTEMS_BSP_FAMILY. | ||||
| | | | | * make/custom/erc32.cfg: Remove RTEMS_BSP_FAMILY. | ||||
* | 2009-10-21 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2009-10-21 | 5 | -4/+7 |
| | | | | | | | * make/custom/simsh1.cfg: Remove RTEMS_BSP_FAMILY. * make/custom/simsh2.cfg: Remove RTEMS_BSP_FAMILY. * make/custom/simsh2e.cfg: Remove RTEMS_BSP_FAMILY. * make/custom/simsh4.cfg: Remove RTEMS_BSP_FAMILY. | ||||
* | 2009-10-21 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2009-10-21 | 2 | -4/+4 |
| | | | | * make/custom/gensh4.cfg: Remove RTEMS_BSP_FAMILY. | ||||
| | | | | * make/custom/gensh2.cfg: Remove RTEMS_BSP_FAMILY. | ||||
| | | | | * make/custom/gensh1.cfg: Remove RTEMS_BSP_FAMILY. | ||||
| | | | | * make/custom/virtex.cfg: Remove RTEMS_BSP_FAMILY. | ||||
| | | | | * make/custom/tqm8xx.inc: Remove RTEMS_BSP_FAMILY. | ||||
| | | | | * make/custom/ss555.cfg: Remove RTEMS_BSP_FAMILY. | ||||
| | | | | * make/custom/score603e.cfg: Remove RTEMS_BSP_FAMILY. | ||||
| | | | | * make/custom/qemuppc.cfg: Remove RTEMS_BSP_FAMILY. | ||||
| | | | | * make/custom/psim.cfg: Remove RTEMS_BSP_FAMILY. | ||||
| | | | | * make/custom/mvme5500.cfg: Remove RTEMS_BSP_FAMILY. | ||||
| | | | | * make/custom/mvme3100.cfg: Remove RTEMS_BSP_FAMILY. | ||||
| | | | | * make/custom/mpc8260ads.cfg: Remove RTEMS_BSP_FAMILY. | ||||
| | | | | * make/custom/mpc55xx.cfg: Remove RTEMS_BSP_FAMILY. | ||||
* | 2009-10-21 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2009-10-21 | 5 | -12/+7 |
| | | | | | | | * make/custom/mcp750.cfg: Remove RTEMS_BSP_FAMILY. * make/custom/mtx603e.cfg: Remove RTEMS_BSP_FAMILY. * make/custom/mvme2100.cfg: Remove RTEMS_BSP_FAMILY. * make/custom/mvme2307.cfg: Remove RTEMS_BSP_FAMILY. | ||||
| | | | | * make/custom/mbx8xx.inc: Remove RTEMS_BSP_FAMILY. | ||||
| | | | | * make/custom/haleakala.cfg: Remove RTEMS_BSP_FAMILY. | ||||
| | | | | * make/custom/gen83xx.inc: Remove RTEMS_BSP_FAMILY. | ||||
| | | | | * make/custom/gen5200.inc: Remove RTEMS_BSP_FAMILY. | ||||
| | | | | * make/custom/ep1a.cfg: Remove RTEMS_BSP_FAMILY. | ||||
| | | | | * make/custom/no_bsp.cfg: Remove RTEMS_BSP_FAMILY. |
