* | bsp/mpc55xx: PR2077: Avoid PPC_USE_SPE | Peter Dufault | 2012-10-02 | 1 | -3/+1 |
* | bsp/mpc55xx: PR2077: Mapping for external flash | Peter Dufault | 2012-10-02 | 1 | -53/+6 |
* | bsps: PR2076: SMC91111 fixes for mpc55xxevb BSP | Peter Dufault | 2012-10-02 | 2 | -8/+7 |
| | | | | | | | | - A typo prevents if_smc.c from being built when configured; - The argument passed to the interrupt handler was incorrect and the addition of support for RTEMS_INTERRUPT_SHARED exposed it; - A "#ifdef DEBUG" is supposed to be "#if DEBUG" since 0 is supposed to make it quiet. | ||||
* | bsp/mpc55xx: Fix bsp_idle_thread() | Sebastian Huber | 2012-10-02 | 4 | -13/+41 |
* | bsp/mpc55xx: Add and use MPC55XX_CHIP_FAMILY | Sebastian Huber | 2012-10-02 | 19 | -40/+44 |
* | pc386: Add Cirrus FB Driver to Makefile and configure.ac | Joel Sherrill | 2012-09-28 | 2 | -1/+13 |
| | | | | | | The user has to explicitly enable this driver, choosing it over the existing (and lame) CGA frame buffer driver using USE_CIRRUS_GD5446=1 on the configure command line. | ||||
* | FB driver for Cirrus GD5446 graphic hardware. | Alexandru-Sever Horin | 2012-09-28 | 1 | -0/+764 |
| | | | | | | | | | | | | | | | | | | | | | | | | | Implementation is tested to work on QEMU simulator only. QEMU offers this hardware by default for PC platform but it can be requested by "-vga cirrus" option for other PCI aware systems in development/next QEMU releases as well. Next sources have been used for driver implementation: - RTEMS fb_vga.c - Rosimildo da Silva ( rdasilva@connecttel.com ) - Cirrus xf86 driver - used as VGA hardware setup documentation - CL-GD5446 Technical Reference Manual, 1996, Second Edition fb_vga.c has to be replaced by fb_cirrus.c in rtems/c/src/lib/libbsp/i386/pc386/Makefile.am to test the driver now. We expect to discus and include driver section mechanism after driver testing. Patch version 2: - comments style updated according to Joel Sherrill review - use static for variables and functions to compile without warnings Signed-off-by: Alexandru-Sever Horin <alex.sever.h@gmail.com> Signed-off-by: Pavel Pisa <pisa@cmp.felk.cvut.cz> | ||||
* | bsp/mpc55xx: Add e200z7 specific idle task | Sebastian Huber | 2012-09-28 | 1 | -0/+13 |
* | bsps/arm: Fix rtems_mii_ioctl() usage | Sebastian Huber | 2012-09-28 | 1 | -1/+1 |
* | bsps/arm: Add LPC_DMA_CHANNEL_COUNT | Sebastian Huber | 2012-09-28 | 3 | -2/+10 |
* | mpc55xxevb: Fix compilation in start-config-siu-pcr.c | Joel Sherrill | 2012-09-06 | 1 | -2/+2 |
* | bsp/mpc55xx: Use a one second timeout | Christian Mauderer | 2012-08-21 | 1 | -117/+217 |
* | bsp/mpc55xx: Fix SMSC9218I_BIG_ENDIAN_SUPPORT | Christian Mauderer | 2012-08-21 | 2 | -7/+15 |
* | bsp/mpc55xx: Move work from ISR to task context | Christian Mauderer | 2012-08-21 | 1 | -6/+8 |
* | bsp/gen83xx: Add br_uid BSP variant | Thomas Doerfler | 2012-08-20 | 8 | -0/+139 |
* | bsp/lpc32xx: Specify scratch area alignment | Sebastian Huber | 2012-08-20 | 1 | -1/+2 |
* | bsp/lpc32xx: Stop unused DDRAM_CLK | Sebastian Huber | 2012-08-20 | 1 | -1/+1 |
* | bsp/lpc32xx: Fix clock name | Sebastian Huber | 2012-08-20 | 2 | -7/+7 |
| | | | | Rename lpc32xx_dram_clk() in lpc32xx_ddram_clk() | ||||
* | bsp/lpc32xx: Add lpc32xx_select_nand_controller() | Sebastian Huber | 2012-08-20 | 3 | -0/+53 |
* | bsp/lpc24xx: Use USB RAM for fast data section | Sebastian Huber | 2012-08-20 | 3 | -3/+6 |
* | Delete leftover bspopts.h.in from revert | Gedare Bloom | 2012-08-06 | 1 | -31/+0 |
* | Revert "Add bspopts.h.in." | Gedare Bloom | 2012-08-06 | 85 | -3770/+1 |
| | | | | | | | | | | | | This reverts commit daffa606cc4a45d93c1f0f4fe365fde0fda6acbb. Conflicts: c/src/lib/libbsp/arm/lpc24xx/include/bspopts.h.in c/src/lib/libbsp/powerpc/mpc55xxevb/include/bspopts.h.in c/src/lib/libbsp/powerpc/qoriq/include/bspopts.h.in Manually deleted conflicting files. | ||||
* | bsp/mpc55xx: eQADC register changes | Sebastian Huber | 2012-07-25 | 1 | -4/+6 |
* | bsp/mpc55xx: Add MPC55XX_CONSOLE_MINOR | Sebastian Huber | 2012-07-25 | 3 | -8/+9 |
| | | | | Remove MPC55XX_ESCI_CONSOLE_MINOR. | ||||
* | bsp/mpc55xx: Whitespace changes | Sebastian Huber | 2012-07-25 | 1 | -7/+7 |
* | bsp/mpc55xx: New EBI settings for MPC5674F boards | Sebastian Huber | 2012-07-25 | 6 | -16/+14 |
* | Use http://www.rtems.org/bugzilla as bug-URL. | Ralf Corsépius | 2012-07-19 | 15 | -15/+15 |
* | Reformat AC_INIT. | Ralf Corsépius | 2012-07-19 | 1 | -2/+1 |
* | Remove CVS-Ids. | Ralf Corsépius | 2012-07-19 | 47 | -89/+13 |
* | Remove CVS-Ids. | Ralf Corsépius | 2012-07-19 | 13 | -30/+0 |
* | Require automake-1.12.2. | Ralf Corsépius | 2012-07-19 | 121 | -121/+121 |
* | Require autoconf-2.69. | Ralf Corsépius | 2012-07-19 | 123 | -123/+123 |
* | bsp/mpc55xx: Add SMSC9218I_IRQ_PIN | Sebastian Huber | 2012-07-18 | 3 | -2/+10 |
* | bsp/mpc55xx: Add SMSC9218I_RESET_PIN | Sebastian Huber | 2012-07-18 | 3 | -3/+11 |
* | bsp/mpc55xx: Add SMSC9218I_ENABLE_LED_OUTPUTS | Sebastian Huber | 2012-07-18 | 4 | -0/+16 |
* | bsp/mpc55xx: Add SMSC9218I_BIG_ENDIAN_SUPPORT | Sebastian Huber | 2012-07-18 | 3 | -16/+44 |
* | bsp/mpc55xx: New ECU508 BSPs | Sebastian Huber | 2012-07-18 | 12 | -6/+223 |
* | bsp/mpc55xx: Add ESCI_C and ESCI_D support | Sebastian Huber | 2012-07-18 | 2 | -7/+30 |
* | bsp/mpc55xx: Add MPC55XX_SYSTEM_CLOCK_DIVIDER | Sebastian Huber | 2012-07-18 | 3 | -6/+9 |
* | bsp/mpc55xx: Add MPC55XX_NULL_POINTER_PROTECTION | Sebastian Huber | 2012-07-18 | 3 | -1/+9 |
* | bsp/mpc55xx: Add MPC55XX_NEEDS_LOW_LEVEL_INIT | Sebastian Huber | 2012-07-18 | 8 | -132/+169 |
* | bsp/mpc55xx: Implement network interface off | Christian Mauderer | 2012-07-18 | 1 | -3/+29 |
* | bsp/mpc55xx: Support re-initialization of eDMA | Christian Mauderer | 2012-07-18 | 1 | -6/+20 |
* | bsp/mpc55xx: Add bsp_restart() | Christian Mauderer | 2012-07-18 | 3 | -1/+28 |
* | bsp/mpc55xx: Add union name | Sebastian Huber | 2012-07-18 | 1 | -1/+1 |
* | bsp/mpc55xx: Add output value to PCR config | Sebastian Huber | 2012-07-18 | 3 | -77/+76 |
* | mips/malta: Add sections for new FreeBSD TCP/IP stack | Joel Sherrill | 2012-07-17 | 1 | -10/+25 |
* | mips/jmr3904: Add sections for new FreeBSD TCP/IP stack | Joel Sherrill | 2012-07-17 | 1 | -10/+25 |
* | Fix broken _endtext symbol | Sebastian Huber | 2012-07-16 | 1 | -2/+2 |
* | shsim linkcmds: Add new FreeBSD TCP/IP stack sections | Joel Sherrill | 2012-07-14 | 1 | -0/+24 |
