PR 1589/build
* leaf.cfg, target.cfg.in, compilers/gcc-target-default.cfg: Remove
obsolete optional manager capability.
PR 1589/build
* optman/.cvsignore, optman/Makefile.am, optman/preinstall.am,
optman/rtems/no-barrier.c, optman/rtems/no-dpmem.c,
optman/rtems/no-event.c, optman/rtems/no-mp.c, optman/rtems/no-msg.c,
optman/rtems/no-part.c, optman/rtems/no-region.c,
optman/rtems/no-rtmon.c, optman/rtems/no-sem.c,
optman/rtems/no-signal.c, optman/rtems/no-timer.c,
optman/sapi/no-ext.c, optman/sapi/no-io.c: Removed.
* libchip/network/sonic.c: Make sonic_enable_interrupts,
sonic_disable_interrupts, sonic_clear_interrupts,
sonic_command static.
* umon/tfsDriver.c: Include <rtems/umon.h> (Missing prototype).
* umon/monlib.c: Make DisableMonLock, EnableMonLock static.
* startup/umonsupp.c: Include <rtems/umon.h> (Missing prototype).
* libchip/ide/ata.c: Make ata_interrupt_on, ata_interrupt_off,
ata_interrupt_isOn static.
* misc/system-clocks.c: New file.
* Makefile.am: Reflect change from above.
* include/nand-mlc.h: Fixed lpc32xx_mlc_is_bad_page().
* make/custom/lpc32xx.inc, make/custom/lpc32xx_mzx_stage_1.cfg: Flags
for EABI tool chain.
* configure.ac, include/bsp.h, include/lpc32xx.h, misc/emc.c,
misc/i2c.c, rtc/rtc-config.c, startup/bspstarthooks.c: Avoid compile
time ARM_CLK and HCLK.
* make/custom/lpc24xx.inc: Flags for EABI tool chain.
* libchip/serial/mc68681.c (mc68681_open):
Var "status" needs to be signed.
* ChangeLog: Add PR number to ChangeLog entry
* milkymist_midi/midi.c: move MIDI message detection from higher layers
to the MIDI interrupt handler
PR 1975/misc
* libchip/ide/ata.c, libchip/ide/ata_util.c: Fixed warnings.
* libchip/ide/ata.c: Make ata_interrupt_handler static.
* libchip/ide/ide_controller.c: Include libchip/ide_ctrl.h.
* libchip/display/disp_hcms29xx.c: Add missing initializer.
* start/start.S: Add bsp_reset() label to exit point.
* mpc8260/console-generic/console-generic.c,
mpc8xx/console-generic/console-generic.c:
Eliminate unused var "nb_overflow".
* console/console.c: Eliminate unused var "nb_overflow".
* shared/include/cpuIdent.c, shared/include/cpuIdent.h
(get_ppc_cpu_type_name): Return const char*.
* Makefile.am: Add shared/startup/bsp-start-memcpy.S
PR 1972/bsps
* milkymist_video/milkymist_video.h, milkymist_video/video.c: Adds an
ioctl to implement selection of composite on any connector, S-Video
and Component sources on the Milkymist One.
PR 1970/bsps
* milkymist_clock/ckinit.c, milkymist_console/console.c,
milkymist_console/uart.c, milkymist_timer/timer.c: Support for the
new Milkymist sysctl and clock frequency detection.
PR 1970/bsps
* include/system_conf.h: Support for the new Milkymist sysctl and clock
PR 1966/bsps
* milkymist_console/console.c, milkymist_console/uart.c,
milkymist_console/uart.h, milkymist_midi/midi.c: support for the new
UART core and interrupt map
PR 1966/bsps
* include/system_conf.h: support for the new UART core and interrupt
map
PR 1925
* shared/irq/irq.h: Changed i386 console to libchip style console and
added support for com3 and com4.
PR 1925
* Makefile.am, preinstall.am, console/serial_mouse_config.c,
include/bsp.h, start/start.S: Converted 1386 console to the libchip
style console
* console/conscfg.c, console/console_control.c,
console/printk_support.c, console/vgacons.c, console/vgacons.h: New
files.
* console.c: Added a some error checks and fixed a error message.
PR 1924/cpukit
* bootcard.c: Update due to API changes.
PR 1927/bsps:
* mpc83xx/network/tsec.c: Fixed integer truncation.
PR 1929/bsps
* irq/irq_init.c: Fixed warning.
PR 1934/bsps
* libchip/serial/ns16550.c: Change to unsigned variable.
* include/lpc17xx.h: New file.
* Makefile.am, preinstall.am: Reflect change above. Update due to API
changes.
* configure.ac, console/console-config.c, include/bsp.h, include/io.h,
include/irq.h, include/lcd.h, include/lpc-clock-config.h,
include/lpc24xx.h, include/start-config.h, irq/irq-dispatch.c,
irq/irq.c, misc/bspidle.c, misc/io.c, misc/lcd.c, misc/restart.c,
misc/system-clocks.c, ssp/ssp.c, startup/bspreset.c,
startup/bspstart.c, startup/bspstarthooks.c,
startup/start-config-emc-dynamic.c, startup/start-config-emc-static.c,
startup/start-config-pinsel.c: Basic support for LPC17XX. New memory
configurations for W9825G2JB75I, IS42S32800B, and SST39VF3201.
* shared/startup/bsp-start-copy-sections.c,
shared/startup/bsp-start-memcpy.S: New files.
* shared/include/start.h: Declare bsp_start_copy_sections().
* shared/start/start.S, shared/include/linker-symbols.h: Moved
content. Support for ARMv7-M.
* make/custom/mpc5566evb_spe.cfg, make/custom/mpc5674fevb_spe.cfg,
startup/linkcmds.mpc5566evb_spe, startup/linkcmds.mpc5674fevb_spe,
startup/reset.c: New files.
* Makefile.am, preinstall.am: Reflect changes above.
* startup/early-init.c: Added missing section attribute.
* configure.ac, network/smsc9218i.c: New BSP options
SMSC9218I_EDMA_RX_CHANNEL and SMSC9218I_EDMA_TX_CHANNEL. Enable reset
at cleanup.
* include/utility.h: Fixed some casts.
* include/irq-generic.h: Define bsp_interrupt_handler_index_type
conditionally.
* new-exceptions/bspsupport/ppc_exc_async_normal.S: Bugfix for
MPC5674F. Use it for all to be safe.
* mpc55xx/include/emios.h: Fixed eMIOS module count.
* mpc55xx/include/irq.h: Fixed CAN vector numbers.
BSP_INTERRUPT_HANDLER_TABLE_SIZE is now a BSP option.
PR 1953/bsps
* console/uart.c: Do not use /dev/console in libchip configuration
table. Shared driver framework selects device to use as /dev/console.
PR 1953/bsps
* console/uarts.c: Do not use /dev/console in libchip configuration
* console/console-config.c: Avoid explicit type.
PR 1951/bsps
* Makefile.am, console/console-config.c: Update due to API changes.
* console_private.h: Removed Console_Port_Minor declaration.
* console.c: Define console_initialized as static.
* libchip/serial/serial.h: Declare Console_Port_Minor.
* shared/console/conscfg.c: Whitespace and style fixes.
* shared/console/conscfg.c: Give console port a name.
* ChangeLog: Fix ChangeLog with name and email address
* shared/score/interrupt.S: Pass ISR correct pointer to interrupt frame
PR 1945/cpukit
* libchip/i2c/spi-memdrv.c: Replace rtems_off64_t with off_t.
PR 1945/cpukit
* umon/tfsDriver.c: Replace rtems_off64_t with off_t.
* ChangeLog, Makefile.am: Add bsp_reset() stub.
PR 1944/misc
* libchip/serial/mc68681.c: Remove #if 0.
