* | Modified to reflect test change where reinitialize mutex test case was | Joel Sherrill | 1999-10-25 | 1 | -1/+1 |
| | | | | removed. | ||||
* | Removed reinitialize mutex test case to reflect earlier code change in | Joel Sherrill | 1999-10-25 | 1 | -1/+8 |
| | | | | the executive. | ||||
* | Changed leading spaces to periods to ease comparing test output. | Joel Sherrill | 1999-10-25 | 3 | -3/+3 |
* | Modified to produce correct output with new version of sis. | Joel Sherrill | 1999-10-25 | 1 | -1/+6 |
* | Removed warning. | Joel Sherrill | 1999-10-21 | 1 | -0/+2 |
* | Increased stack size of initialization thread. | Joel Sherrill | 1999-10-21 | 1 | -0/+2 |
* | Added rtems_semaphore_flush directive. | Joel Sherrill | 1999-10-21 | 3 | -1/+105 |
* | Renamed CONFIGURE_POSIX_INIT_TASK_STACK_SIZE to | Joel Sherrill | 1999-10-21 | 1 | -6/+6 |
| | | | | CONFIGURE_POSIX_INIT_THREAD_STACK_SIZE because in POSIX they are threads. | ||||
* | Fixed core dump caused when output parameter (otimer) was NULL. | Joel Sherrill | 1999-10-21 | 1 | -3/+7 |
* | Added Semaphore_Flush. | Joel Sherrill | 1999-10-21 | 2 | -0/+18 |
* | Added prototype for rtems_task_is_suspended at request of | Joel Sherrill | 1999-10-20 | 1 | -1/+12 |
| | | | | Eric Norum. | ||||
* | Spacing. | Joel Sherrill | 1999-10-12 | 3 | -0/+3 |
* | Split null handlers table to own file and renamed. | Joel Sherrill | 1999-10-12 | 19 | -163/+44 |
| | | | | Renamed IMFS handler tables to include IMFS prefix. | ||||
* | Added rtems_filesystem_freenode() macro and added calls at appropriate | Joel Sherrill | 1999-10-12 | 35 | -188/+140 |
| | | | | | places to make sure memory allocated for filesystem specifif nodes gets freed. | ||||
* | Fixed spacing. | Joel Sherrill | 1999-10-12 | 3 | -3/+3 |
* | Corrected mistakes in the IMFS file handlers table and added the missing | Joel Sherrill | 1999-10-12 | 10 | -31/+301 |
| | | | | routine imfs_fcntl.c | ||||
* | Added call to freenod to let each filesystem free its own internal | Joel Sherrill | 1999-10-12 | 31 | -140/+470 |
| | | | | node used to manage file access. | ||||
* | Changed bcopy to strncpy to stick to ANSI/ISO routines. | Joel Sherrill | 1999-10-12 | 2 | -2/+2 |
* | Moved RTEMS error and association from libmisc to libc support to | Joel Sherrill | 1999-10-11 | 7 | -13/+13 |
| | | | | | avoid cyclic dependencies generated when moving packages to the top level. | ||||
* | Removed targets and configurations that are no longer functional | Joel Sherrill | 1999-10-11 | 14 | -1428/+0 |
| | | | | | | | | | | | | | | and not likely to become so. Comments on each configuration are below. + Force CPU386 - This BSP was developed as part of the initial port of RTEMS to the i386. This board has been unavailable for a long time now. + GO32 - This BSP and some CPU code supported djgpp v1.x. This version is now quite old. No one has stepped forward to update the code to v2.x which may be technically impossible anyway. More importantly, go32 has been superceded by the pc386 BSP. | ||||
* | Added as part of moving librdbg to its own top level package. This was | Joel Sherrill | 1999-10-11 | 6 | -0/+141 |
| | | | | done as part of a patch from Ralf Corsepius <corsepiu@faw.uni-ulm.de>. | ||||
* | Patch from Ralf Corsepius <corsepiu@faw.uni-ulm.de> to move librdbg | Joel Sherrill | 1999-10-11 | 12 | -131/+1081 |
| | | | | to its own top level package. | ||||
* | Now compiles for coff and elf. | Joel Sherrill | 1999-10-11 | 1 | -65/+185 |
* | New directive added -- rtems_task_is_suspended. | Joel Sherrill | 1999-10-07 | 2 | -1/+77 |
* | Added Is_Suspended method. | Joel Sherrill | 1999-10-07 | 2 | -0/+20 |
* | Removed targets and configurations that are no longer functional | Joel Sherrill | 1999-10-06 | 26 | -5265/+0 |
* | New file. | Joel Sherrill | 1999-10-06 | 4 | -0/+56 |
* | Removed aclocal.m4 generated from aclocal macros | Joel Sherrill | 1999-10-06 | 37 | -27023/+0 |
* | Removed configure generated from configure.in | Joel Sherrill | 1999-10-06 | 37 | -81630/+0 |
* | Modified to avoid conflicts on definitions of malloc. newlib 1.8.2 | Joel Sherrill | 1999-10-06 | 7 | -7/+7 |
| | | | | | | | | now prototypes the malloc family in stdlib.h. This causes conflicts with the way the network stack overrides the definitions of malloc. As best I (being Joel) can tell, commenting stdlib.h out keeps the files compiling and referencing the desired malloc/free but results in more warnings. | ||||
* | Modified to explicitly list all files as part of C_PIECES. | Joel Sherrill | 1999-10-06 | 1 | -1/+2 |
* | Corrected build order so it was not as dependent on the mpc750 check. | Joel Sherrill | 1999-10-06 | 2 | -6/+2 |
* | Added sections as required by C++ and ELF. | Joel Sherrill | 1999-10-06 | 4 | -3/+14 |
* | Added more sections and made minor modifications to let the linkcmds | Joel Sherrill | 1999-10-06 | 8 | -29/+54 |
| | | | | | work with m68k-elf on late model versions of binutils (990901+) without overlapping or missing section errors. | ||||
* | Fixed spelling error (FAMILLY --> FAMILY). | Joel Sherrill | 1999-10-06 | 1 | -4/+4 |
* | Invalid value used for baud rate per bug report from | Joel Sherrill | 1999-10-05 | 2 | -2/+2 |
| | | | | Jay Kulpinski <jskulpin@eng01.gdds.com>. | ||||
* | Removed ifdef on go32. | Joel Sherrill | 1999-10-05 | 1 | -1/+1 |
* | Removed go32 ifdefs | Joel Sherrill | 1999-10-05 | 2 | -6/+0 |
* | Added comment with CVS Id. | Joel Sherrill | 1999-10-05 | 1 | -0/+4 |
* | Changed bra.s to bra.l to remove error with new version of binutils. | Joel Sherrill | 1999-10-05 | 2 | -4/+4 |
* | Changed bra.s to bra.l to correct compilation error triggered by new | Joel Sherrill | 1999-10-05 | 2 | -2/+2 |
| | | | | version of binutils. | ||||
* | Corrected so sections did not overlap with new version of binutils. | Joel Sherrill | 1999-10-05 | 1 | -0/+6 |
* | Corrected comment. | Joel Sherrill | 1999-10-05 | 2 | -2/+2 |
* | Added Jay Kulpinski (jskulpin@eng01.gdds.com) for mvme2307 BSP submission. | Joel Sherrill | 1999-10-05 | 1 | -0/+6 |
* | Removed targets and configurations that are no longer functional | Joel Sherrill | 1999-10-05 | 2 | -20/+0 |
* | Removed targets and configurations that are no longer functional | Joel Sherrill | 1999-10-05 | 2 | -73/+1 |
* | Removed targets and configurations that are no longer functional | Joel Sherrill | 1999-10-05 | 1 | -16/+16 |
* | Modified to remove reference to Force CPU386. Actually this was a misnamed | Joel Sherrill | 1999-10-05 | 1 | -2/+2 |
| | | | | conditional that should have been fixed long ago. | ||||
* | Modified to remove error for overlapping sections now that | Joel Sherrill | 1999-10-05 | 1 | -27/+19 |
| | | | | gnu.linkonce* sections are included. | ||||
* | Patch from Wayne Bullaughey <wayne@wmi.com>. Comments follow: | Joel Sherrill | 1999-10-05 | 2 | -2/+2 |
| | | | | | | | | | | | | I'm working on code to mount my host based file system on the base file system (imfs) and have a suggestion for a change to eval.c in the c/src/lib/libc directory of the 8/20/1999 snapshot. The current version does not test the result value returned from the evalpath callback (line 47) in the case where follow_link is true. Attached is my suggested change. Without this test the node_type callback may be called after evalpath failed. node_type could set the type to some value other then RTEMS_FILESYSTEM_HARD_LINK or RTEMS_FILESYSTEM_SYM_LINK but it seems cleaner to add the check on result. |
