* | Fixed symbols. | Joel Sherrill | 1997-03-21 | 1 | -2/+6 |
* | added decrementer entry. | Joel Sherrill | 1997-03-21 | 1 | -0/+17 |
* | Removed Fake input ifdef code. | Joel Sherrill | 1997-03-21 | 1 | -15/+0 |
* | Fixed timerisr symbol. | Joel Sherrill | 1997-03-21 | 1 | -2/+2 |
* | Rewrote to avoid references to C symbols from assembly. This entirely | Joel Sherrill | 1997-03-21 | 1 | -5/+9 |
| | | | | circumvents the problem of leading underscores. | ||||
* | Fixes incorrect reference to start symbol. | Joel Sherrill | 1997-03-21 | 1 | -1/+1 |
* | updates from John Gwynne | Joel Sherrill | 1997-03-11 | 2 | -0/+358 |
* | updates from John Gwynne | Joel Sherrill | 1997-03-11 | 21 | -92/+778 |
* | modified _Chain_Insert_unprotected to have the form required to be used | Joel Sherrill | 1997-03-11 | 2 | -4/+4 |
| | | | | as the sole statement in an if or else statement | ||||
* | swapped increment of _ISR_Nest_level and _Thread_Dispatch_disable_level | Joel Sherrill | 1997-03-11 | 1 | -1/+1 |
* | added include of rtems.h so the proper macro definitions would be present. | Joel Sherrill | 1997-03-10 | 2 | -0/+4 |
* | made some of this conditional on unix lib | Joel Sherrill | 1997-03-10 | 1 | -2/+5 |
* | initialized a stack variable to avoid a warning. | Joel Sherrill | 1997-03-10 | 1 | -1/+1 |
* | created. Split getpid() from types.c to allow it to be overridden by | Joel Sherrill | 1997-03-10 | 1 | -0/+22 |
| | | | | | cxe1001 of the ACVC 2.0.1. This allows gnat/rtems to pass the partition tests. | ||||
* | Fixed bug where the initial detachstate was not being set properly | Joel Sherrill | 1997-03-10 | 1 | -1/+1 |
* | updated version to 4.0.0 | Joel Sherrill | 1997-03-08 | 2 | -2/+2 |
* | added support for posix tests | Joel Sherrill | 1997-03-08 | 1 | -1/+3 |
* | Larger Workspace when it is a POSIX API. Actually this is just to cover | Joel Sherrill | 1997-03-08 | 1 | -0/+4 |
| | | | | | the extra stack used when GNAT tasks are in the system. This needs to be cleaned up. | ||||
* | Modified calls to _Thread_Change_priority to take a third argument. The new | Joel Sherrill | 1997-03-08 | 5 | -15/+50 |
| | | | | | | | | | argument indicates whether the task is to be placed at the head or tail of its priority fifo when it is lowering its own priority. POSIX normally follows the RTEMS API conventions but GNAT expects that all lowering of a task's priority by the task itself will result in being placed at the head of the priority FIFO. Normally, this would only occur as the result of lose of inherited priority. | ||||
* | Modified calls to _Thread_Change_priority to take a third argument. The new | Joel Sherrill | 1997-03-08 | 1 | -1/+1 |
| | | | | | | | | | | | | argument indicates whether the task is to be placed at the head or tail of its priority fifo when it is lowering its own priority. POSIX normally follows the RTEMS API conventions but GNAT expects that all lowering of a task's priority by the task itself will result in being placed at the head of the priority FIFO. Normally, this would only occur as the result of lose of inherited priority. The RTEMS API always puts tasks at the end of their priority group except upon loss of inherited priority. | ||||
* | Removed getpid from this file and made it its own file. This lets it | Joel Sherrill | 1997-03-08 | 1 | -10/+0 |
| | | | | get replaced as required. | ||||
* | Added commit to indicate exepcted _Thread_Dispatch_disable_level. Hopefully | Joel Sherrill | 1997-03-08 | 1 | -0/+4 |
| | | | | no one will ever get confused here again and try to enable dispatching. :( | ||||
* | Modifications to make go32 build using new i386-go32-rtems toolset | Joel Sherrill | 1997-01-29 | 4 | -8/+14 |
| | | | | and gcc 2.8.x -specs options. | ||||
* | new file explaining issues related to this bsp. | Joel Sherrill | 1997-01-29 | 1 | -0/+38 |
* | Fixed this where it works. It includes the libpc.a and libc.a from | Joel Sherrill | 1997-01-29 | 1 | -6/+6 |
| | | | | djgpp v1.x. | ||||
* | erc32 bsp supercedes sis | Joel Sherrill | 1997-01-29 | 8 | -0/+1476 |
* | Made stopping for the pause an option which can be configured in the | Joel Sherrill | 1997-01-29 | 1 | -0/+12 |
| | | | | targopts.h file. | ||||
* | Minor change to eliminate incorrect use of unaligned register. | Joel Sherrill | 1997-01-29 | 1 | -1/+2 |
* | Merged newlib's libgloss support for rtems into this directory. This | Joel Sherrill | 1997-01-29 | 11 | -74/+213 |
| | | | | should simplify the build process. | ||||
* | All RTEMS system call implementation renamed to be __rtems_*. | Joel Sherrill | 1997-01-29 | 21 | -85/+123 |
* | The CONSOLE_USE_INTERRUPTS and CONSOLE_USE_POLLED macros are now | Joel Sherrill | 1997-01-29 | 1 | -7/+1 |
| | | | | defined in the targopts.h file. | ||||
* | Removed definitions which are now in targopts.h. This eliminates the | Joel Sherrill | 1997-01-29 | 11 | -224/+8 |
| | | | | | need for the "sed'ing" of this file. This should be a significant win when addressing non-unix host and non-gnu toolsets. | ||||
* | added type to macro to eliminate warning for untyped use of a register. | Joel Sherrill | 1997-01-29 | 2 | -2/+2 |
* | Added comment. | Joel Sherrill | 1997-01-29 | 1 | -1/+1 |
* | Removed defines now handled by targopts.h. | Joel Sherrill | 1997-01-29 | 1 | -22/+0 |
* | Added include of rtems/score/cpu.h | Joel Sherrill | 1997-01-29 | 1 | -1/+0 |
* | Added include of targopts.h. | Joel Sherrill | 1997-01-29 | 9 | -6/+15 |
* | Changed include of asm.h so it is in brackets not quotes. asm.h is | Joel Sherrill | 1997-01-29 | 2 | -2/+2 |
| | | | | in a standard location and should be referenced as such. | ||||
* | Fixed spacing on comments. | Joel Sherrill | 1997-01-29 | 1 | -1/+1 |
* | Fixed spacing on comment. | Joel Sherrill | 1997-01-29 | 1 | -1/+1 |
* | Fixed comments. | Joel Sherrill | 1997-01-29 | 1 | -1/+6 |
| | | | | Fixed so this file can be included from assembly code. | ||||
* | fixed spacing problem | Joel Sherrill | 1997-01-29 | 1 | -1/+1 |
* | With the transition from command line macro definitions to targopts.h, | Joel Sherrill | 1997-01-28 | 1 | -3/+2 |
| | | | | | it was necessary to include system.h before checking if anything was defined. | ||||
* | removed include of unnecessary include file. | Joel Sherrill | 1997-01-28 | 2 | -2/+0 |
* | Switch to using newlib's implementation of time(). | Joel Sherrill | 1997-01-28 | 1 | -0/+3 |
* | new file used by gcc 2.8.x -specs option | Joel Sherrill | 1997-01-28 | 18 | -0/+612 |
* | fixed comments on vanilla 68000 SW interrupt stack (or the lack thereof) | Joel Sherrill | 1997-01-15 | 2 | -6/+2 |
* | _CPU_Trap_Table_area is now conditional based on whether or not | Joel Sherrill | 1997-01-08 | 1 | -2/+5 |
| | | | | the application requires rtems to allocate a trap table | ||||
* | removed assert() for stat on non-devices. Now it returns -1. This | Joel Sherrill | 1997-01-08 | 1 | -2/+1 |
| | | | | makes gnat pass about 55 more tests in the acvc. |
