* aclocal/version.m4: Bump RTEMS_API to 4.11.
Bump _RTEMS_VERSION to 4.10.99.0.
* libchip/network/if_dc.c: Fix warning.
* include/bsp.h: Add prototypes for BSP_disconnect_clock_handler,
BSP_connect_clock_handler.
* shared/start/start.S: Pass 0/NULL for argc/argv.
* shared/umon/tfsDriver.c: Updated to the new mount API.
* start/start.S: Pass 0/NULL for argc/argv.
* libchip/network/greth.c: Misc. hacks to allow compilation on
16bit targets.
PR 1531/newlib
* libchip/network/i82586.c:
Add local copy of ALIGN().
* libchip/network/cs8900.c:
Misc. changes to make code 16bit-target compliant.
Use int32_t instead of int for 16bit-target compliance.
* libchip/network/open_eth.c:
* Makefile.am: Fix typo in path.
* shared/src/no_cache.c: New file.
PR 1537/libcpu
* shared/cache/cache.c: Removed.
PR 1538/libcpu
* Makefile.am: Use shared stub implementation of cache.c (no_cache.c).
* umon/tfsDriver.c:
Use size_t instead of int for pathnamelen.
* au1x00/include/au1x00.h: Add prototypes for
mips_default_isr, assert_sw_irq, negate_sw_irq.
* au1x00/vectorisrs/vectorisrs.c: Remove prototype of
mips_default_isr.
* configure.ac, include/bspopts.h.in: Added BSP_SMALL_MEMORY option.
PR 1530/bsps
* mpc55xx/edma/edma.c: Eliminate use of recently removed macros.
* Makefile.am, amba/amba.c, console/console.c, console/debugputs.c,
startup/bspstart.c: Rework initialization order so AMBA bus is
scanned earlier. This lets us look for UARTs earlier and support
printk as early as bsp_start() returning.
* console/consolelite.c, network/xiltemac.c:
Reflect prototypes having changed (Warning removal).
* cache.c, page.c: Use masks and shift operations instead of
bit-fields.
* Makefile.am: Add bspreset.c
* sh7032/score/cpu_asm.c, sh7045/score/cpu_asm.c,
sh7750/score/cpu_asm.c, shgdb/score/cpu_asm.c: Spacing.
* include/lpc32xx.h: Update for utility macro changes.
* include/utility.h: Macros use now first and last bit values instead
of shift and length parameters.
* configure.ac: Fixed BSP option.
* include/lpc32xx.h, startup/bspstarthooks.c: Added PLL setup.
* startup/bspstarthooks.c: Removed start section attribute defines.
* shared/include/start.h: Define start section attributes.
* include/lpc24xx.h, misc/dma-copy.c, misc/dma.c,
misc/system-clocks.c, ssp/ssp.c, startup/bspstarthooks.c: Removed
superfluous macros.
* include/utility.h: Removed superfluous macros.
* network/smsc9218i.c: Removed superfluous macros.
* make/custom/lpc32xx.inc, make/custom/lpc32xx_mzx_boot_int.cfg,
startup/linkcmds.lpc32xx_mzx_boot_int: New files.
* Makefile.am, configure.ac, preinstall.am, include/bsp.h,
include/bspopts.h.in, include/lpc32xx.h, irq/irq.c,
make/custom/lpc32xx_phycore.cfg, startup/bspstart.c,
startup/bspstarthooks.c: Changes throughout.
* Makefile.am, preinstall.am, include/bsp.h, startup/bspstart.c: Use
shared output character implementation.
* include/uart-output-char.h, src/uart-output-char.c: New files.
* make/custom/lpc32xx_phycore.cfg: Workaround for GCC bug 38644.
* make/custom/rtl22xx_t.cfg: Workaround for GCC bug 38644.
* make/dswifi/arm9/makefile: Workaround for GCC bug 38644.
* make/custom/lpc24xx.inc: Workaround for GCC bug 38644.
* libchip/i2c/spi-sd-card.c, libchip/ide/ata.c: PR
1448/filesystem.
* startup/syscalls.c: Rename to avoid conflict with newlib.
* Makefile.am, preinstall.am: Fix typo.
* rtl8019/rtl8019.c: Fix typo.
* shared/liblnk/lnklib.S, shared/liblnk/pmon.S, shared/liblnk/regs.h,
shared/startup/idtmem.S, shared/startup/idttlb.S: New files.
* Makefile.am, preinstall.am: Many files were duplicated across MIPS
BSPs. Now those which were directly copied are shared.
* liblnk/lnklib.S, liblnk/pmon.S, liblnk/regs.h, startup/idtmem.S,
startup/idttlb.S: Removed.
* liblnk/lnklib.S, liblnk/pmon.S, liblnk/regs.h, startup/idtmem.S:
Removed.
* Makefile.am, preinstall.am, start/start.S: Many files were duplicated
across MIPS BSPs. Now those which were directly copied are shared.
* start/regs.h: Removed.
