* bin2s: Remove.
* bin2s.c: Remove CVS-$Log's.
* libnds/include/nds/arm9/exceptions.h,
libnds/include/nds/arm9/image.h,
libnds/include/nds/arm9/input.h,
libnds/include/nds/arm9/math.h,
libnds/include/nds/arm9/pcx.h,
libnds/include/nds/arm9/rumble.h,
libnds/include/nds/arm9/sound.h,
libnds/include/nds/arm9/trig_lut.h,
libnds/source/arm9/dcache.S,
libnds/source/arm9/exceptionHandler.S,
libnds/source/arm9/exceptions.c,
libnds/source/arm9/image.c,
libnds/source/arm9/keys.c,
libnds/source/arm9/pcx.c,
libnds/source/arm9/rumble.c,
libnds/source/arm9/sound.c,
libnds/source/arm9/system.c,
libnds/source/arm9/touch.c,
libnds/source/common/biosCalls.S,
libnds/source/common/gbfs.c,
libnds/source/common/interruptDispatcher.S,
libnds/source/common/interrupts.c:
Remove CVS-$Log's.
* shared/gdbstub/lm32-stub.c: Fix wrong computation of negative branch
targets (thanks to Manfred Scheible <mscheible@husware.de>.
* shared/tsmac/tsmac.c: Remove unused vars.
Let rtems_tsmac_driver_attach return 1.
* shared/console/console.c: Use int as return type of
BSP_uart_polled_read.
* include/bsp.h: Move extern "C" { }.
* libchip/network/smc91111.c: Formatting.
* clockdrv_shell.h: Clean up.
* shared/bsppretaskinghook.c: New file. Was really common.
* shared/bspstart.c: Removed. Was really leon2 specific.
* Makefile.am: sparc/shared/bspstart.c was really leon2 specific. So
move it here.
* startup/bspstart.c: New file.
* Makefile.am, startup/bspstart.c:
Use ../../sparc/shared/bsppretaskinghook.c.
* console/console.c: Remove sis comment.
* Makefile.am: Switch to ../../shared/bspstart.c
* clock/clockdrv.c: Split hardware initialization code into
Clock_driver_support_initialize_hardware().
* ne2000/ne2000.c: Logic on defaulting port number was inverted when
adding command line arguments.
* src/rtemsInterrupt.cc: #include <cstdlib>.
* src/rtemsMessageQueue.cc, src/rtemsSemaphore.cc,
src/rtemsTask.cc, src/rtemsTimer.cc: #include <cstring>.
* configure.ac: Check for cstdlib, cstring.
* Makefile.am, configure.ac, console/uarts.c: Add initial support for
Kit637 version of CSB637.
* README.kit637_v6, make/custom/kit637_v6.cfg: New files.
* Makefile.am, preinstall.am, at91rm9200/include/at91rm9200.h: Add
initial support for USART on at91rm9200.
* at91rm9200/include/at91rm9200_usart.h, at91rm9200/usart/usart.c:
New files.
* new-exceptions/bspsupport/ppc_exc_categories.c:
PSIM *must*not* hook SYS vector which is used e.g.,
for firmware I/O.
Added entries for AltiVec on PSIM.
* startup/init5235.c: Add volatile to prevent newer gcc versions from
optimizing away.
promCopyIcacheFlush.
* include/bsp.h: Add prototypes of promCopyDcacheFlush and
* startup/bspstart.c: Remove nested externs.
#include <libcpu/isr_entries.h.
* Makefile.am: Add shared/interrupts/isr_entries.h.
* shared/interrupts/isr_entries.h: New.
* shared/interrupts/installisrentries.c: Remove nested externs.
* startup/bspstart.c: use normal get_ppc_cpu_type()
for determining PPC flavor. This causes the appropriate
'feature' bits to be set and should work as long
as the PVR is set to 0xfffe0000 in the device tree.
* startup/linkcmds: increased RAM_SIZE to 32M.
* shared/include/cpuIdent.c: Set 604 features + altivec if
running on PSIM.
* libchip/ide/ata.c (rtems_ata_initialize): Avoid implicit cast to uint16_t.
* libchip/ide/ata.c (ata_non_data_request): Change arg from int to
uint32_t (16bit ints are too small).
* INSTALL: Remove.
* start/start.S: Ensure that initial stack is aligned to
CPU_STACK_ALIGNMENT.
* shared/start/start.S: Align initial stack to
