path: root/c/src (follow)
* 2003-09-26 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2003-09-2642-2361/+0
| | | | | | | | | | | | | | | | | | | | | | | | | | | | * hppa1.1/.cvsignore, hppa1.1/ChangeLog, hppa1.1/Makefile.am, hppa1.1/acinclude.m4, hppa1.1/configure.ac, hppa1.1/simhppa/.cvsignore, hppa1.1/simhppa/ChangeLog, hppa1.1/simhppa/Makefile.am, hppa1.1/simhppa/bsp_specs, hppa1.1/simhppa/configure.ac, hppa1.1/simhppa/times, hppa1.1/simhppa/include/.cvsignore, hppa1.1/simhppa/include/Makefile.am, hppa1.1/simhppa/include/bsp.h, hppa1.1/simhppa/include/ttydrv.h, hppa1.1/simhppa/shmsupp/.cvsignore, hppa1.1/simhppa/shmsupp/Makefile.am, hppa1.1/simhppa/shmsupp/README, hppa1.1/simhppa/shmsupp/addrconv.c, hppa1.1/simhppa/shmsupp/cause_intr.c, hppa1.1/simhppa/shmsupp/getcfg.c, hppa1.1/simhppa/shmsupp/lock.c, hppa1.1/simhppa/shmsupp/mpisr.c, hppa1.1/simhppa/start/.cvsignore, hppa1.1/simhppa/start/Makefile.am, hppa1.1/simhppa/start/start.S, hppa1.1/simhppa/startup/.cvsignore, hppa1.1/simhppa/startup/Makefile.am, hppa1.1/simhppa/startup/bspclean.c, hppa1.1/simhppa/startup/bspstart.c, hppa1.1/simhppa/startup/linkcmds, hppa1.1/simhppa/startup/setvec.c, hppa1.1/simhppa/tools/.cvsignore, hppa1.1/simhppa/tools/ChangeLog, hppa1.1/simhppa/tools/Makefile.am, hppa1.1/simhppa/tools/configure.ac, hppa1.1/simhppa/tools/print_dump.c, hppa1.1/simhppa/tty/.cvsignore, hppa1.1/simhppa/tty/Makefile.am, hppa1.1/simhppa/tty/tty.c, hppa1.1/simhppa/wrapup/.cvsignore, hppa1.1/simhppa/wrapup/Makefile.am: Removed.
* 2003-09-26 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2003-09-2621-3067/+13
| | | | | | | | | | | | | * hppa1.1/.cvsignore, hppa1.1/ChangeLog, hppa1.1/Makefile.am, hppa1.1/configure.ac, hppa1.1/clock/.cvsignore, hppa1.1/clock/Makefile.am, hppa1.1/clock/clock.c, hppa1.1/include/.cvsignore, hppa1.1/include/Makefile.am, hppa1.1/include/runway.h, hppa1.1/include/semaphore.h, hppa1.1/milli/.cvsignore, hppa1.1/milli/Makefile.am, hppa1.1/milli/milli.S, hppa1.1/semaphore/.cvsignore, hppa1.1/semaphore/Makefile.am, hppa1.1/semaphore/semaphore.c, hppa1.1/timer/.cvsignore, hppa1.1/timer/Makefile.am, hppa1.1/timer/timer.c: Removed.
* 2003-09-26 Till Strauman <strauman@slac.stanford.edu>Joel Sherrill2003-09-262-1/+8
| | | | | | | PR 496/bsps * startup/Makefile.am: Use PowerPC shared sbrk() implementation which is used when initial heap size is limited to first 32 MB of RAM to satisfy boot loader requirements.
* 2003-09-26 Till Strauman <strauman@slac.stanford.edu>Joel Sherrill2003-09-263-2/+93
| | | | | | | | | | | | | | | | | | | | | PR 496/bsps * startup/sbrk.c: New file. * startup/bspstart.c: This patch implements 'sbrk' for the powerpc-shared BSP to work around what's known as the '32Mb problem' in combination with run-time loaded code. GCC normally generates (PowerPC) code doing 'short jumps' which requires all text segments being in the same 32Mb area of memory. However, some run-time loaders use (e.g. heap-) memory violating the stated limitation on hardware with more than 32Mb of memory. (NOTE: portable loaders are probably not even aware of this GCC/CPU specific problem.) This patch implements a simple workaround: At boot time, the system is only provided with 32Mb of memory. The user is supposed to load all necessary modules prior to that limit being exhausted. Once that happens, newlib/malloc end up trying to 'sbrk()' for more memory and the implementation provided by this patch will then make the rest of the physical memory available.
* 2003-09-26 Till Straumann <strauman@slac.stanford.edu>Joel Sherrill2003-09-262-0/+25
| | | | | | | PR 497/bsps * BOOTING: Document letting the bootloader shut down the network interface since it continues to run after loading RTEMS application and has to be dealt with.
* 2003-09-26 Till Straumann <strauman@slac.stanford.edu>Joel Sherrill2003-09-262-12/+46
| | | | | | | | PR 497/bsps * bootloader/head.S: Let the bootloader shut down the network interface. NOTE: this involves a PPCBug system call and will hence fail if other software is used to boot. Need to #undef USE_PPCBUG in such cases!
* 2003-09-26 Cedric Aubert <cedric_aubert@yahoo.fr>Joel Sherrill2003-09-262-19/+55
| | | | | | | | | | | PR 499/rtems_misc * serial/mc68681.c: Miscellaneous corrections: - Correction of ACR_BIT[7] (Baudrate table) Configuration - Correction of Parity Bit Configuration (Odd was forced) - Correction of Stop Bit configuration (inversed) - Correction of ISR Handler to call rtems_termios_dequeue_character() only if is a Tx Empty IRQ. - Add RTS CTS Hardware flow control Configuration
* 2003-09-26 Cedric Aubert <cedric_aubert@yahoo.fr>Joel Sherrill2003-09-262-13/+32
| | | | | | | | | PR 501/rtems_misc * console.c: console_open disables ICANON on non-console port, which should be ok for the first open but not for subsequent ones. If you open one serial port, you will configure it, when you reopen it you will lost the ICANON parameters if you had put it. Should be done by console only at first open.
* 2003-09-24 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-09-246-25/+12
| | | | * bsp_specs: Remove *lib:.
* 2003-09-19 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-09-1914-56/+28
* 2003-09-19 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-09-192-8/+4
* 2003-09-19 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-09-198-32/+16
* 2003-09-19 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-09-1928-112/+56
* 2003-09-17 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-09-188-32/+16
* 2003-09-18 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-09-181-0/+5
| | | | | * shared/cache/cache.c (m68030): fix prototype mismatch of _CPU_cache_flush_entire_data.
* 2003-09-18 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-09-181-1/+1
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | * shared/cache/cache.c (m68030): fix prototype mismatch of _CPU_cache_flush_entire_data. 2003-09-04 Joel Sherrill <joel@OARcorp.com> * shared/misc/m68kidle.c: URL for license changed. 2003-08-18 Ralf Corsepius <corsepiu@faw.uni-ulm.de> * Makefile.am: Reflect having moved aclocal/. 2003-08-16 Ralf Corsepius <corsepiu@faw.uni-ulm.de> * Makefile.am: Reflect having moved automake/. * m68040/Makefile.am: Reflect having moved automake/. * m68040/fpsp/Makefile.am: Reflect having moved automake/. * shared/Makefile.am: Reflect having moved automake/. * shared/cache/Makefile.am: Reflect having moved automake/. * shared/misc/Makefile.am: Reflect having moved automake/. 2003-08-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de> * configure.ac: Use rtems-bugs@rtems.com as bug report email address. 2003-03-06 Ralf Corsepius <corsepiu@faw.uni-ulm.de> * configure.ac: Remove AC_CONFIG_AUX_DIR. 2003-02-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de> * configure.ac: AM_INIT_AUTOMAKE([1.7.2]). 2003-02-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de> * configure.ac: AC_PREREQ(2.57). 2002-01-15 Ralf Corsepius <corsepiu@faw.uni-ulm.de> * m68040/fpsp/Makefile.am: Don't include @RTEMS_BSP@.cfg. Eliminate *_O_FILES. * shared/cache/Makefile.am: Ditto. * shared/misc/Makefile.am: Ditto. 2002-12-06 Ralf Corsepius <corsepiu@faw.uni-ulm.de> * configure.ac: Remove RTEMS_CHECK_BSP_CACHE. 2002-12-01 Ralf Corsepius <corsepiu@faw.uni-ulm.de> * configure.ac: Add RTEMS_PROG_CCAS. 2002-10-21 Ralf Corsepius <corsepiu@faw.uni-ulm.de> * .cvsignore: Reformat. Add autom4te*cache. Remove autom4te.cache. 2002-08-21 Joel Sherrill <joel@OARcorp.com> * configure.ac, shared/misc/Makefile.am: PR217 required that the idle task be moved to libcpu so it could be more acutely aware of the CPU model. This file was modified to pick up the idle task from there. * shared/misc/m68kidle.c: New file. 2002-08-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de> * m68040/fpsp/Makefile.am: Use .$(OBJEXT) instead of .o. * mcf5206/clock/Makefile.am: Use .$(OBJEXT) instead of .o. * mcf5206/console/Makefile.am: Use .$(OBJEXT) instead of .o. * mcf5206/mbus/Makefile.am: Use .$(OBJEXT) instead of .o. * mcf5206/timer/Makefile.am: Use .$(OBJEXT) instead of .o. * shared/cache/Makefile.am: Use .$(OBJEXT) instead of .o. * shared/misc/Makefile.am: Use .$(OBJEXT) instead of .o. 2002-08-06 Joel Sherrill <joel@OARcorp.com> * configure.ac: Be more specific about looking at CPU32 and CPU32+ CPU model names so we can turn on the best compile of memcpy.c. 2002-08-06 Ralf Corsepius <corsepiu@faw.uni-ulm.de> * configure.ac: Replace mcpu32 by mcpu32p conditional. * share/misc/Makefile.am: Fix AM_CPPFLAGS bug. 2002-08-05 Joel Sherrill <joel@OARcorp.com> * Per PR260 eliminate use of make-target-options. This impacted RTEMS allowing a distinction between the CPU32 and CPU32+ in the SuperCore and required that the m68k optimized memcpy be moved to libcpu. * shared/misc/memcpy.c: Moved from score/cpu/m68k. * configure.ac, shared/Makefile.am: Modified to reflect new directory. * shared/misc/.cvsignore, shared/misc/Makefile.am: New file. 2002-03-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de> * configure.ac: AC_INIT(package,_RTEMS_VERSION,_RTEMS_BUGS). AM_INIT_AUTOMAKE([no-define foreign 1.6]). * m68040/fpsp/Makefile.am: Remove AUTOMAKE_OPTIONS. * m68040/Makefile.am: Remove AUTOMAKE_OPTIONS. * Makefile.am: Remove AUTOMAKE_OPTIONS. * shared/cache/Makefile.am: Remove AUTOMAKE_OPTIONS. * shared/Makefile.am: Remove AUTOMAKE_OPTIONS. 2001-10-26 Joel Sherrill <joel@OARcorp.com> * Makefile.am, configure.ac: New libcpu support for mcf5206e. 2001-10-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de> * .cvsignore: Add autom4te.cache for autoconf > 2.52. * configure.in: Remove. * configure.ac: New file, generated from configure.in by autoupdate. 2001-09-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de> * shared/cache/Makefile.am: Use 'PREINSTALL_FILES ='. * shared/cache/Makefile.am: Use 'CLEANFILES ='. 2001-03-03 Ralf Corsepius <corsepiu@faw.uni-ulm.de> * m68040/fpsp/Makefile.am, shared/cache/Makefile.am: Apply include_*HEADERS instead of H_FILES. 2000-11-09 Ralf Corsepius <corsepiu@faw.uni-ulm.de> * Makefile.am: Use ... instead of RTEMS_TOPdir in ACLOCAL_AMFLAGS. 2000-11-02 Ralf Corsepius <corsepiu@faw.uni-ulm.de> * Makefile.am: Switch to ACLOCAL_AMFLAGS = -I $(RTEMS_TOPdir)/aclocal. 2000-10-26 Ralf Corsepius <corsepiu@faw.uni-ulm.de> * Makefile.am: ACLOCAL_AMFLAGS= -I $(RTEMS_TOPdir)/macros. Switch to GNU canonicalization. 2000-09-04 Ralf Corsepius <corsepiu@faw.uni-ulm.de> * m68040/fpsp/Makefile.am, shared/cache/Makefile.am: Include compile.am 2000-08-10 Joel Sherrill <joel@OARcorp.com> * ChangeLog: New file.
* 2003-09-15 Jennifer Averett <jennifer@OARcorp.com>Jennifer Averett2003-09-153-2/+6
| | | | * psxhdrs/sync01.c, psxhdrs/sync02.c: Correct fd creation
* 2003-09-15 Jay Monkman <jtm@smoothsmoothie.com>Jennifer Averett2003-09-152-6/+5
| | | | | PR 480/bsps * shared/irq/irq_asm.S: Remove duplicate code.
* 2003-09-15 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2003-09-153-2/+22
| | | | | | PR 483/bsps * startup/bspstart.c, startup/start_c.c: Spurious interrupt handlers cannot be installed until RTEMS has initialized the vector table.
* 2003-09-15 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2003-09-156-2/+40
| | | | | | PR 483/bsps * start/start.c, startup/bspstart.c: Spurious interrupt handlers cannot be installed until RTEMS has initialized the vector table.
* 2003-09-08 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-09-086-23/+12
* 2003-09-08 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-09-082-8/+4
* 2003-09-08 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-09-0812-48/+24
* 2003-09-04 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2003-09-042-1/+8
| | | | | | | * lib/libcpu/shared/include/cache.h, lib/libcpu/shared/src/cache_aligned_malloc.c, lib/libcpu/shared/src/cache_manager.c, support/version.c: URL for license changed.
* 2003-09-04 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2003-09-044-3/+8
| | | | | * shared/include/cache.h, shared/src/cache_aligned_malloc.c, shared/src/cache_manager.c: URL for license changed.
* 2003-09-04 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2003-09-0434-34/+34
| | | | | | * addlq.c, cnvpkt.c, dump.c, fatal.c, getlq.c, getpkt.c, init.c, initlq.c, intr.c, mpci.h, mpisr.c, poll.c, receive.c, retpkt.c, send.c, setckvec.c, shm_driver.h: URL for license changed.
* 2003-09-04 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2003-09-045-4/+9
| | | | | * rtems-multiprocessing.adb, rtems-multiprocessing.ads, rtems.adb, rtems.ads: URL for license changed.
* 2003-09-04 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2003-09-0498-97/+125
| | | | | | | | | | | | | | | | | | | | | | | | | | | | * include/timesys.h, tm01/system.h, tm01/task1.c, tm01/tm01.doc, tm02/system.h, tm02/task1.c, tm02/tm02.doc, tm03/system.h, tm03/task1.c, tm03/tm03.doc, tm04/system.h, tm04/task1.c, tm04/tm04.doc, tm05/system.h, tm05/task1.c, tm05/tm05.doc, tm06/system.h, tm06/task1.c, tm06/tm06.doc, tm07/system.h, tm07/task1.c, tm07/tm07.doc, tm08/system.h, tm08/task1.c, tm08/tm08.doc, tm09/system.h, tm09/task1.c, tm09/tm09.doc, tm10/system.h, tm10/task1.c, tm10/tm10.doc, tm11/system.h, tm11/task1.c, tm11/tm11.doc, tm12/system.h, tm12/task1.c, tm12/tm12.doc, tm13/system.h, tm13/task1.c, tm13/tm13.doc, tm14/system.h, tm14/task1.c, tm14/tm14.doc, tm15/system.h, tm15/task1.c, tm15/tm15.doc, tm16/system.h, tm16/task1.c, tm16/tm16.doc, tm17/system.h, tm17/task1.c, tm17/tm17.doc, tm18/system.h, tm18/task1.c, tm18/tm18.doc, tm19/system.h, tm19/task1.c, tm19/tm19.doc, tm20/system.h, tm20/task1.c, tm20/tm20.doc, tm21/system.h, tm21/task1.c, tm21/tm21.doc, tm22/system.h, tm22/task1.c, tm22/tm22.doc, tm23/system.h, tm23/task1.c, tm23/tm23.doc, tm24/system.h, tm24/task1.c, tm24/tm24.doc, tm25/system.h, tm25/task1.c, tm25/tm25.doc, tm26/fptest.h, tm26/system.h, tm26/task1.c, tm26/tm26.doc, tm27/system.h, tm27/task1.c, tm27/tm27.doc, tm28/system.h, tm28/task1.c, tm28/tm28.doc, tm29/system.h, tm29/task1.c, tm29/tm29.doc, tmck/system.h, tmck/task1.c, tmck/tmck.doc, tmoverhd/dumrtems.h, tmoverhd/empty.c, tmoverhd/system.h, tmoverhd/testtask.c, tmoverhd/tmoverhd.doc: URL for license changed.
| | | | | * include/timesys.h, tmitronsem01/init.c, tmitronsem01/system.h, tmitronsem01/tmitronsem01.doc: URL for license changed.
* 2003-09-04 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2003-09-042-1/+5
| | | | * include/tmacros.h: URL for license changed.
* 2003-09-04 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2003-09-04185-184/+231
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | * sp01/init.c, sp01/sp01.doc, sp01/system.h, sp01/task1.c, sp02/init.c, sp02/preempt.c, sp02/sp02.doc, sp02/system.h, sp02/task1.c, sp02/task2.c, sp02/task3.c, sp03/init.c, sp03/sp03.doc, sp03/system.h, sp03/task1.c, sp03/task2.c, sp04/init.c, sp04/sp04.doc, sp04/system.h, sp04/task1.c, sp04/task2.c, sp04/task3.c, sp04/tswitch.c, sp05/init.c, sp05/sp05.doc, sp05/system.h, sp05/task1.c, sp05/task2.c, sp05/task3.c, sp06/init.c, sp06/sp06.doc, sp06/system.h, sp06/task1.c, sp06/task2.c, sp06/task3.c, sp07/init.c, sp07/sp07.doc, sp07/system.h, sp07/task1.c, sp07/task2.c, sp07/task3.c, sp07/task4.c, sp07/taskexit.c, sp07/tcreate.c, sp07/tdelete.c, sp07/trestart.c, sp07/tstart.c, sp08/init.c, sp08/sp08.doc, sp08/system.h, sp08/task1.c, sp09/delay.c, sp09/init.c, sp09/isr.c, sp09/screen01.c, sp09/screen02.c, sp09/screen03.c, sp09/screen04.c, sp09/screen05.c, sp09/screen06.c, sp09/screen07.c, sp09/screen08.c, sp09/screen09.c, sp09/screen10.c, sp09/screen11.c, sp09/screen12.c, sp09/screen13.c, sp09/screen14.c, sp09/sp09.doc, sp09/system.h, sp09/task1.c, sp09/task2.c, sp09/task3.c, sp09/task4.c, sp11/init.c, sp11/sp11.doc, sp11/system.h, sp11/task1.c, sp11/task2.c, sp11/timer.c, sp12/init.c, sp12/pridrv.c, sp12/pritask.c, sp12/sp12.doc, sp12/system.h, sp12/task1.c, sp12/task2.c, sp12/task3.c, sp12/task4.c, sp12/task5.c, sp13/fillbuff.c, sp13/init.c, sp13/putbuff.c, sp13/sp13.doc, sp13/system.h, sp13/task1.c, sp13/task2.c, sp13/task3.c, sp14/asr.c, sp14/init.c, sp14/sp14.doc, sp14/system.h, sp14/task1.c, sp14/task2.c, sp15/init.c, sp15/sp15.doc, sp15/system.h, sp15/task1.c, sp16/init.c, sp16/sp16.doc, sp16/system.h, sp16/task1.c, sp16/task2.c, sp16/task3.c, sp16/task4.c, sp16/task5.c, sp17/asr.c, sp17/init.c, sp17/sp17.doc, sp17/system.h, sp17/task1.c, sp17/task2.c, sp19/first.c, sp19/fptask.c, sp19/fptest.h, sp19/init.c, sp19/inttest.h, sp19/sp19.doc, sp19/system.h, sp19/task1.c, sp20/getall.c, sp20/init.c, sp20/sp20.doc, sp20/system.h, sp20/task1.c, sp21/init.c, sp21/sp21.doc, sp21/system.h, sp21/task1.c, sp22/delay.c, sp22/init.c, sp22/prtime.c, sp22/sp22.doc, sp22/system.h, sp22/task1.c, sp23/init.c, sp23/sp23.doc, sp23/system.h, sp23/task1.c, sp24/init.c, sp24/resume.c, sp24/sp24.doc, sp24/system.h, sp24/task1.c, sp25/init.c, sp25/sp25.doc, sp25/system.h, sp25/task1.c, sp26/init.c, sp26/sp26.doc, sp26/system.h, sp26/task1.c, sp30/init.c, sp30/resume.c, sp30/sp30.doc, sp30/system.h, sp30/task1.c, sp31/delay.c, sp31/init.c, sp31/prtime.c, sp31/sp31.doc, sp31/system.h, sp31/task1.c, sp32/init.c, spfatal/fatal.c, spfatal/init.c, spfatal/puterr.c, spfatal/spfatal.doc, spfatal/system.h, spfatal/task1.c, spsize/getint.c, spsize/init.c, spsize/size.c, spsize/system.h: URL for license changed.
* 2003-09-04 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2003-09-0435-34/+48
| | | | | | | | | | | | | | * README, base_mp/apptask.c, base_mp/init.c, base_mp/system.h, base_mp/node1/base_mp.doc, base_mp/node2/base_mp.doc, base_sp/apptask.c, base_sp/base_sp.doc, base_sp/init.c, base_sp/system.h, cdtest/init.c, cdtest/main.cc, cdtest/system.h, fileio/fileio.doc, fileio/init.c, fileio/system.h, hello/hello.doc, hello/init.c, hello/system.h, minimum/init.c, minimum/minimum.doc, paranoia/init.c, paranoia/paranoia.doc, paranoia/system.h, ticker/init.c, ticker/system.h, ticker/tasks.c, ticker/ticker.doc, unlimited/init.c, unlimited/system.h, unlimited/test1.c, unlimited/test2.c, unlimited/test3.c, unlimited/unlimited.doc: URL for license changed.
* 2003-09-04 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2003-09-04199-198/+263
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | * psx01/init.c, psx01/system.h, psx01/task.c, psx02/init.c, psx02/system.h, psx02/task.c, psx03/init.c, psx03/system.h, psx03/task.c, psx04/init.c, psx04/system.h, psx04/task1.c, psx04/task2.c, psx04/task3.c, psx05/init.c, psx05/system.h, psx05/task.c, psx05/task2.c, psx05/task3.c, psx06/init.c, psx06/system.h, psx06/task.c, psx06/task2.c, psx07/init.c, psx07/system.h, psx07/task.c, psx08/init.c, psx08/system.h, psx08/task1.c, psx08/task2.c, psx08/task3.c, psx09/init.c, psx09/system.h, psx10/init.c, psx10/system.h, psx10/task.c, psx10/task2.c, psx10/task3.c, psx11/init.c, psx11/system.h, psx11/task.c, psx12/init.c, psx12/system.h, psx12/task.c, psx13/main.c, psx13/test.c, psxcancel/init.c, psxfile01/main.c, psxfile01/test.c, psxhdrs/clock01.c, psxhdrs/clock02.c, psxhdrs/clock03.c, psxhdrs/clock04.c, psxhdrs/clock05.c, psxhdrs/clock06.c, psxhdrs/cond01.c, psxhdrs/cond02.c, psxhdrs/cond03.c, psxhdrs/cond04.c, psxhdrs/cond05.c, psxhdrs/cond06.c, psxhdrs/cond07.c, psxhdrs/cond08.c, psxhdrs/cond09.c, psxhdrs/cond10.c, psxhdrs/key01.c, psxhdrs/key02.c, psxhdrs/key03.c, psxhdrs/key04.c, psxhdrs/mutex01.c, psxhdrs/mutex02.c, psxhdrs/mutex03.c, psxhdrs/mutex04.c, psxhdrs/mutex05.c, psxhdrs/mutex06.c, psxhdrs/mutex07.c, psxhdrs/mutex08.c, psxhdrs/mutex09.c, psxhdrs/mutex10.c, psxhdrs/mutex11.c, psxhdrs/mutex12.c, psxhdrs/mutex13.c, psxhdrs/mutex14.c, psxhdrs/mutex15.c, psxhdrs/mutex16.c, psxhdrs/proc01.c, psxhdrs/proc02.c, psxhdrs/proc03.c, psxhdrs/proc04.c, psxhdrs/proc05.c, psxhdrs/proc06.c, psxhdrs/proc07.c, psxhdrs/proc08.c, psxhdrs/proc09.c, psxhdrs/proc10.c, psxhdrs/proc11.c, psxhdrs/proc12.c, psxhdrs/proc13.c, psxhdrs/proc14.c, psxhdrs/pthread01.c, psxhdrs/pthread02.c, psxhdrs/pthread03.c, psxhdrs/pthread04.c, psxhdrs/pthread05.c, psxhdrs/pthread06.c, psxhdrs/pthread07.c, psxhdrs/pthread08.c, psxhdrs/pthread09.c, psxhdrs/pthread10.c, psxhdrs/pthread11.c, psxhdrs/pthread12.c, psxhdrs/pthread13.c, psxhdrs/pthread14.c, psxhdrs/pthread15.c, psxhdrs/pthread16.c, psxhdrs/pthread17.c, psxhdrs/pthread18.c, psxhdrs/pthread19.c, psxhdrs/pthread20.c, psxhdrs/pthread21.c, psxhdrs/pthread22.c, psxhdrs/pthread23.c, psxhdrs/pthread24.c, psxhdrs/pthread25.c, psxhdrs/pthread26.c, psxhdrs/pthread27.c, psxhdrs/pthread28.c, psxhdrs/pthread29.c, psxhdrs/pthread30.c, psxhdrs/pthread31.c, psxhdrs/pthread32.c, psxhdrs/pthread33.c, psxhdrs/pthread34.c, psxhdrs/pthread35.c, psxhdrs/pthread36.c, psxhdrs/sched01.c, psxhdrs/sched02.c, psxhdrs/sched03.c, psxhdrs/sched04.c, psxhdrs/sched05.c, psxhdrs/sched06.c, psxhdrs/sched07.c, psxhdrs/sched08.c, psxhdrs/signal01.c, psxhdrs/signal02.c, psxhdrs/signal03.c, psxhdrs/signal04.c, psxhdrs/signal05.c, psxhdrs/signal06.c, psxhdrs/signal07.c, psxhdrs/signal08.c, psxhdrs/signal09.c, psxhdrs/signal10.c, psxhdrs/signal11.c, psxhdrs/signal12.c, psxhdrs/signal13.c, psxhdrs/signal14.c, psxhdrs/signal15.c, psxhdrs/signal16.c, psxhdrs/signal17.c, psxhdrs/signal18.c, psxhdrs/signal19.c, psxhdrs/signal20.c, psxhdrs/signal21.c, psxhdrs/signal22.c, psxhdrs/signal23.c, psxhdrs/sync01.c, psxhdrs/sync02.c, psxhdrs/sync03.c, psxhdrs/time01.c, psxhdrs/time02.c, psxhdrs/time03.c, psxhdrs/time04.c, psxhdrs/time05.c, psxhdrs/time06.c, psxhdrs/time07.c, psxhdrs/time08.c, psxhdrs/time09.c, psxhdrs/time10.c, psxhdrs/time11.c, psxhdrs/time12.c, psxhdrs/time13.c, psxhdrs/timer01.c, psxhdrs/timer02.c, psxhdrs/timer03.c, psxhdrs/timer04.c, psxhdrs/timer05.c, psxhdrs/timer06.c, psxhdrs/timer07.c, psxmsgq01/init.c, psxmsgq01/system.h, psxsem01/system.h, psxstat/main.c, psxstat/test.c, psxtime/main.c, psxtime/test.c, psxtimer/psxtimer.c, psxtimer/system.h: URL for license changed.
* 2003-09-04 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2003-09-0482-81/+106
| | | | | | | | | | | | | | | | | | | | | | | | | * mp01/init.c, mp01/system.h, mp01/task1.c, mp01/node1/mp01.doc, mp01/node2/mp01.doc, mp02/init.c, mp02/system.h, mp02/task1.c, mp02/node1/mp02.doc, mp02/node2/mp02.doc, mp03/delay.c, mp03/init.c, mp03/system.h, mp03/task1.c, mp03/node1/mp03.doc, mp03/node2/mp03.doc, mp04/init.c, mp04/system.h, mp04/task1.c, mp04/node1/mp04.doc, mp04/node2/mp04.doc, mp05/asr.c, mp05/init.c, mp05/system.h, mp05/task1.c, mp05/node1/mp05.doc, mp05/node2/mp05.doc, mp06/init.c, mp06/system.h, mp06/task1.c, mp06/node1/mp06.doc, mp06/node2/mp06.doc, mp07/init.c, mp07/system.h, mp07/task1.c, mp07/node1/mp07.doc, mp07/node2/mp07.doc, mp08/init.c, mp08/system.h, mp08/task1.c, mp08/node1/mp08.doc, mp08/node2/mp08.doc, mp09/init.c, mp09/recvmsg.c, mp09/sendmsg.c, mp09/system.h, mp09/task1.c, mp09/node1/mp09.doc, mp09/node2/mp09.doc, mp10/init.c, mp10/system.h, mp10/task1.c, mp10/task2.c, mp10/task3.c, mp10/node1/mp10.doc, mp10/node2/mp10.doc, mp11/init.c, mp11/system.h, mp11/node1/mp11.doc, mp11/node2/mp11.doc, mp12/init.c, mp12/system.h, mp12/node1/mp12.doc, mp12/node2/mp12.doc, mp13/init.c, mp13/system.h, mp13/task1.c, mp13/task2.c, mp13/node1/mp13.doc, mp13/node2/mp13.doc, mp14/delay.c, mp14/evtask1.c, mp14/evtmtask.c, mp14/exit.c, mp14/init.c, mp14/msgtask1.c, mp14/pttask1.c, mp14/smtask1.c, mp14/system.h, mp14/node1/mp14.doc, mp14/node2/mp14.doc: URL for license changed.
* 2003-09-04 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2003-09-0427-26/+38
| | | | | | | | | | | | * cpuuse/init.c, cpuuse/system.h, cpuuse/task1.c, cpuuse/task2.c, cpuuse/task3.c, cpuuse/tswitch.c, malloctest/init.c, malloctest/system.h, malloctest/task1.c, monitor/init.c, monitor/system.h, putenvtest/init.c, rtems++/Init.cc, rtems++/System.h, rtems++/Task1.cc, rtems++/Task2.cc, rtems++/Task3.cc, rtems++/rtems++.doc, rtmonuse/getall.c, rtmonuse/init.c, rtmonuse/system.h, rtmonuse/task1.c, stackchk/blow.c, stackchk/init.c, stackchk/system.h, stackchk/task1.c: URL for license changed.
* 2003-09-04 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2003-09-0435-34/+50
| | | | | | | | | | | | | | | | * itronhello/init.c, itronhello/itronhello.doc, itronhello/system.h, itronmbf01/init.c, itronmbf01/itronmbf01.doc, itronmbf01/system.h, itronmbox01/init.c, itronmbox01/system.h, itronsem01/init.c, itronsem01/itronsem01.doc, itronsem01/system.h, itrontask01/init.c, itrontask01/itrontask01.doc, itrontask01/system.h, itrontask01/task1.c, itrontask02/dormant.c, itrontask02/init.c, itrontask02/itrontask02.doc, itrontask02/system.h, itrontask03/init.c, itrontask03/itrontask03.doc, itrontask03/preempt.c, itrontask03/system.h, itrontask03/task1.c, itrontask03/task2.c, itrontask03/task3.c, itrontask04/init.c, itrontask04/itrontask04.doc, itrontask04/system.h, itrontask04/task1.c, itrontask04/task2.c, itrontask04/task3.c, itrontime01/init.c, itrontime01/system.h: URL for license changed.
* 2003-09-04 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2003-09-0413-12/+19
| | | | | | | * rtems/no-dpmem.c, rtems/no-event.c, rtems/no-mp.c, rtems/no-msg.c, rtems/no-part.c, rtems/no-region.c, rtems/no-rtmon.c, rtems/no-sem.c, rtems/no-signal.c, rtems/no-timer.c, sapi/no-ext.c, sapi/no-io.c: URL for license changed.
* 2003-09-04 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2003-09-0416-15/+26
| | | | | | | | | | | * include/rtems++/rtemsEvent.h, include/rtems++/rtemsInterrupt.h, include/rtems++/rtemsMessageQueue.h, include/rtems++/rtemsSemaphore.h, include/rtems++/rtemsStatusCode.h, include/rtems++/rtemsTask.h, include/rtems++/rtemsTaskMode.h, include/rtems++/rtemsTimer.h, src/rtemsEvent.cc, src/rtemsInterrupt.cc, src/rtemsMessageQueue.cc, src/rtemsSemaphore.cc, src/rtemsStatusCode.cc, src/rtemsTask.cc, src/rtemsTimer.cc: URL for license changed.
* 2003-09-04 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2003-09-0442-41/+57
| | | | | | | | | | | | | | | | * ide/ata.c, ide/ata.h, ide/ata_internal.h, ide/ide_controller.c, ide/ide_ctrl.h, ide/ide_ctrl_cfg.h, ide/ide_ctrl_io.h, network/cs8900.c, network/cs8900.c.bsp, network/cs8900.h, network/dec21140.c, network/elnk.c, network/open_eth.c, network/sonic.c, network/sonic.h, rtc/icm7170.c, rtc/icm7170.h, rtc/icm7170_reg.c, rtc/icm7170_reg2.c, rtc/icm7170_reg4.c, rtc/icm7170_reg8.c, rtc/m48t08.c, rtc/m48t08.h, rtc/m48t08_reg.c, rtc/m48t08_reg2.c, rtc/m48t08_reg4.c, rtc/m48t08_reg8.c, rtc/rtc.h, rtc/rtcprobe.c, serial/mc68681.c, serial/mc68681.h, serial/mc68681_p.h, serial/mc68681_reg.c, serial/mc68681_reg2.c, serial/mc68681_reg4.c, serial/mc68681_reg8.c, serial/serial.h, serial/z85c30.c, serial/z85c30.h, serial/z85c30_p.h, serial/z85c30_reg.c: URL for license changed.
* 2003-09-04 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2003-09-0413-12/+20
| | | | | | | | * clock/ckinit.c, include/rtems/score/iosh7750.h, include/rtems/score/ipl.h, include/rtems/score/ispsh7750.h, include/rtems/score/sh4_regs.h, include/rtems/score/sh7750_regs.h, include/sh/sh4uart.h, sci/console.c, sci/sh4uart.c, score/cpu_asm.c, score/ispsh7750.c, timer/timer.c: URL for license changed.
* 2003-09-04 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2003-09-0414-13/+21
| | | | | | | | * clock/ckinit.c, include/io_types.h, include/iosh7045.h, include/ispsh7045.h, include/sci.h, include/sci_termios.h, include/sh7_pfc.h, include/sh7_sci.h, sci/sci.c, sci/sci_termios.c, score/cpu_asm.c, score/ispsh7045.c, timer/timer.c: URL for license changed.
* 2003-09-04 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2003-09-0412-11/+18
| | | | | | | * clock/ckinit.c, delay/delay.c, include/iosh7032.h, include/ispsh7032.h, include/sci.h, include/sh7_pfc.h, include/sh7_sci.h, sci/sci.c, score/cpu_asm.c, score/ispsh7032.c, timer/timer.c: URL for license changed.
* 2003-09-04 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2003-09-0438-37/+58
| | | | | | | | | | | | | | | | | | | | | * mpc6xx/clock/c_clock.c, mpc6xx/clock/c_clock.h, mpc6xx/exceptions/raw_exception.c, mpc6xx/exceptions/raw_exception.h, mpc6xx/mmu/bat.c, mpc6xx/mmu/bat.h, mpc6xx/mmu/mmuAsm.S, mpc6xx/timer/timer.c, mpc8260/clock/clock.c, mpc8260/console-generic/console-generic.c, mpc8260/cpm/brg.c, mpc8260/exceptions/raw_exception.c, mpc8260/exceptions/raw_exception.h, mpc8260/include/cpm.h, mpc8260/include/mmu.h, mpc8260/mmu/mmu.c, mpc8260/timer/timer.c, mpc8xx/clock/clock.c, mpc8xx/console-generic/console-generic.c, mpc8xx/exceptions/raw_exception.c, mpc8xx/exceptions/raw_exception.h, mpc8xx/include/cpm.h, mpc8xx/include/mmu.h, mpc8xx/mmu/mmu.c, mpc8xx/timer/timer.c, ppc403/clock/clock.c, ppc403/console/console.c.polled, ppc403/timer/timer.c, rtems/powerpc/debugmod.h, shared/include/byteorder.h, shared/include/cpuIdent.c, shared/include/cpuIdent.h, shared/include/io.h, shared/include/mmu.h, shared/include/page.h, shared/include/pgtable.h, shared/include/spr.h: URL for license changed.
* 2003-09-04 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2003-09-043-2/+6
| | | | * clock/ckinit.c, timer/timer.c: URL for license changed.
* 2003-09-04 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2003-09-0412-11/+19
| | | | | | | | * clock/ckinit.c, mongoosev/duart/mg5uart.c, mongoosev/duart/mg5uart.h, mongoosev/duart/mg5uart_reg.c, mongoosev/include/mongoose-v.h, mongoosev/vectorisrs/maxvectors.c, mongoosev/vectorisrs/vectorisrs.c, r46xx/vectorisrs/maxvectors.c, shared/interrupts/isr_entries.S, timer/timer.c, tx39/vectorisrs/maxvectors.c: URL for license changed.
* 2003-09-04 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2003-09-049-8/+14
| | | | | | * clock/ckinit.c, console/mcfuart.c, include/mcf5206e.h, include/mcfmbus.h, include/mcfuart.h, mbus/mcfmbus.c, timer/timer.c, timer/timerisr.S: URL for license changed.
* 2003-09-04 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2003-09-048-7/+12
| | | | | * cpu.c, cpu.h, cpuModel.S, cpuModel.h, displayCpu.c, idtr.S, page.c: URL for license changed.
| | | | | * clock/clock.c, include/semaphore.h, semaphore/semaphore.c, timer/timer.c: URL for license changed.
| | | | | | | | * clock/clock.c, console/console.c, include/bsp.h, shmsupp/addrconv.c, shmsupp/cause_intr.c, shmsupp/getcfg.c, shmsupp/lock.c, shmsupp/mpisr.c, startup/bspclean.c, startup/bspstart.c, startup/exit.c, startup/setvec.c, timer/timer.c: URL for license changed.
