* automake/compile.am, automake/force-preinstall.am,
automake/host.am, automake/lib.am, automake/local.am,
automake/subdirs.am: New (copied from ../../automake).
* sp02/task1.c: Added ID to name lookup service and changed name of
id/name translation status code. This propagated to multiple
functions. The user API service added was rtems_object_id_to_name()
PR 408/filesystem
* psx13/test.c: Added very rudimentary test of sync() service.
* runtest.in: Add fileio to list of interactive tests.
* tools/runtest: Add fileio to list of interactive tests.
* runtest: Add fileio to list of interactive tests.
* fileio/.cvsignore: New file.
PR 451/bsps
* pppd/system.h: Depend on TTY driver being in BSPs not simply i386.
PR 451/bsps
* startup/Makefile.am: Include shared i386 TTY driver in these BSPs.
* Makefile.am: Add bsp.pc.in
* bsp.pc.in: New (pkgconfig support).
PR 453/make_build
* startup/linkcmds: Added .eh_frame
* startup/Makefile.am: Remove USE_INIT_FINI.
* bsp_specs: Remove -D__USE_INIT_FINI__.
Remove *.cpp (Now unused).
PR 369/filesystem
* runtest: Add sample application to show the use of the
DOSFS functions
* fileio/Makefile.am: Remove references to *.scn (Doesn't exist).
* pppd/Makefile.am: Remove references to DOC* (Don't exist).
* Makefile.am: Preinstall $(PROJECT_INCLUDE)/rtems/score.
* include/rdbg/Makefile.am: Add DIST_SUBDIRS = $(RTEMS_CPU).
* src/Makefile.am: Add DIST_SUBDIRS = $(RTEMS_CPU).
* lib/Makefile.am: New (Required by 'make dist').
* lib/ChangeLog: Remove.
* lib/.cvsignore: Cleanup.
* configure.ac: Reflect having added lib/Makefile.am.
* configure.ac: Merge-in lib/libcpu/configure.ac.
Merge-in lib/libbsp/configure.ac.
* shmdr/Makefile.am: Reflect having merged configure.ac into
../../configure.ac.
* include/Makefile.am: Remove (merged into Makefile.am).
* gdbstub/Makefile.am: Remove (merged into Makefile.am).
Reflect having merged ../configure.ac into ../../../configure.ac.
* configure.ac: Remove (Merged into ../../configure.ac).
* Makefile.am: Reflect having merged configure.ac into
../../configure.ac.
* wrapup/Makefile.am (FAMILY_OBJS): Remove *exception_processing.
PR 369/filesystem
* Makefile.am, configure.ac: sample application to show the use of the
DOSFS functions
* fileio/Makefile.am, fileio/fileio.doc, fileio/init.c,
fileio/system.h: New files.
* bsp_specs: Remove -D__embedded__ -Asystem(embedded)
-DUSE_ENHANCED_INTR_API from cpp.
* configure.ac: Add -DUSE_ENHANCED_INTR_API to bspopts.h.
* bsp_specs: Remove -DUSE_ENHANCED_INTR_API.
PR 437/bsps
* irq/irc.c: calls to bspIo/printk must not use '%i' format which is
apparently not supported
* pci/pci.c: calls to bspIo/printk must not use '%i' format which is
* configure.ac: Use relative dir to make/${RTEMS_BSP}.cache.
* configure.ac: Merge-in librdbg/configure.ac.
* configure.ac: Remove (Merged into ../configure.ac).
* Makefile.am, include/Makefile.am, include/rdbg/Makefile.am,
include/rdbg/i386/Makefile.am, include/rdbg/m68k/Makefile.am,
include/rdbg/powerpc/Makefile.am, src/Makefile.am,
src/i386/Makefile.am, src/i386/any/Makefile.am,
src/m68k/Makefile.am, src/m68k/any/Makefile.am,
src/powerpc/Makefile.am,
src/powerpc/new_exception_processing/Makefile.am:
* ide/Makefile.am, network/Makefile.am, rtc/Makefile.am,
serial/Makefile.am: Add conditional LIBCHIP.
Conditionally build include-dirs.
* network/if_fxp.c: Replace deprecated b* funcs by mem* funcs.
* network/if_hdlcsubr.c: Use memcopy instead of bcmp,
Use memcmp instead of bcmp.
* configure.ac: Merge-in libnetworking/configure.ac.
Merge-in parts of librdbg/configure.ac.
* .cvsignore, Makefile.am, pppd/Makefile.am,
rtems_servers/Makefile.am, rtems_telnetd/Makefile.am,
rtems_webserver/Makefile.am, wrapup/Makefile.am:
PR 288/rtems
* support/new_exception_processing/cpu.c: _ISR_Nest_level is now
properly maintained and does not reside in SPRG0.
PR 288/rtems
* irq/irq_asm.S, startup/bspstart.c: _ISR_Nest_level is now properly
maintained and any BSP which does not do so will trip a panic in the
shared code.
PR 288/rtems
* startup/bspstart.c: _ISR_Nest_level is now properly maintained.
PR 288/rtems
maintained.
PR 415/bsps
* pci/detect_raven_bridge.c, startup/bspstart.c:
This patch reverts enabling MCP interrupts for the motorola_powerpc
BSPs. REASON: pci config space scanning (as e.g. done by the DEC
Ethernet driver) would raise machine check exceptions.
PR 428/bsps
PR 432/bsps
* bootloader/pci.c: Re-instated code that prevents remapping small
IO regions, which if remapped would cause i8259 registers to move
out from under the #define'd base addresses.
* startup/bspstart.c: Reduced BAT2 PCI memory allocation to 256
megs, I incorrectly had extended it which would cause problems with
PCI devices that defined prefetchable memory.
PR 428/bsps
PR 432/bsps
* pci/pcibios.c, pci/pcibios.h: Added BSP_pci_Find_Device() which
is copied from motorola_shared.
PR 429/bsps
PR 432/bsps
* network/elnk.c: Due to a bug in the driver, if multiple packets
are queued onto an elnk board, the ISR will deadlock the device with
a tx complete interrupt. Lighter tx loads are not affected as they
end up submitting single packets to the device.
* src/rdbg.c: Use memset instead of bzero (deprecated).
* src/servtsp.c: Ditto.
