which is an adaptation of a patch from Ian Lance Taylor plus a few
other changes that should significantly speed up building librtemsall.a.
<corsepiu@faw.uni-ulm.de> which converted fiels to automake.
<corsepiu@faw.uni-ulm.de>.
in the previous commits.
for RTEMS.
dependencies of "Makefile".
--enable-maintainer-mode.
via libbsp.a. Reported by Ian Lance Taylor <ian@airs.com>.
grep found debugio.o when looking for debug.o and said there was a
filename conflict incorrectly.
future.
cd <rtems-source-tree>
this week until now.
It consists of 3 parts:
1. a patch
2. a perl script (acpolish)
plural).
configure scripts etc.
added by acpolish.
To apply this:
./rtems-polish.sh
Later:
cvs add contrib
cvs add contrib/acpolish
cvs commit
portion is now in the libchip tree and the dmv177 configuration is in
the dmv177 bsp. The performance impact of libchip'ing this driver
was minimal.
Hello,
host :
- one for RTEMS it self,
- one for GDB-4.17.
1/ RTEMS patch
This patch adds 2 libraries :
- the Remote Debugger library
--enable-rdbg
rtems_rdbg_initialize ();
2/ GDB-4.17 patch
To connect to a target, use :
And... Debug ;)
with libchip.
<raguet@crf.canon.fr> to make their patches work together.
of theses targets...
all the targets:
breaking CXX support.
handling.
after minor changes.)
insecure about.
external packages.
may be broken).
disturb now.
--enable-* flags).
--enable-gcc28 are given.
mvme162.cfg-bug.
subdirectory Makefiles.
used.
individual Makefile.
problem (reported by Eric)
just in this directory.
was done based on the 3.6.0 release and had to be autoconf'ed locally.
It is turned on is the bsp enables it and it is not explicitly disabled
via the configure option --disable-tcpip. As many warnings as possible
were removed locally after the code was merged. Only the gen68360
and mvme136 bsps were compiled this way.
The ka9q port and network driver were submitted by Eric Norum
(eric@skatter.USask.Ca).
The network demo programs are not included in the tree at this point.
be resolved.
