path: root/c/src/wrapup (follow)
* Removed CONFIG_DIR and PROJECT_HOME directories.Joel Sherrill1998-01-201-12/+12
* Pass in PROJECT_HOME so rtems-glom can run if the make is invokedJoel Sherrill1997-12-161-2/+4
| | | | just in this directory.
* Added missing dependency for libmisc.a based on a bug report by Phil Wilshire.Joel Sherrill1997-12-071-0/+1
* added ka9q stackJoel Sherrill1997-05-271-0/+1
* KA9Q stack removed prior to testing for 4.0.0 public release.Joel Sherrill1997-05-231-1/+0
* Added ka9q tcpip stack and network driver for the gen68360. This effortJoel Sherrill1997-04-091-0/+1
| | | | | | | | | | | | | was done based on the 3.6.0 release and had to be autoconf'ed locally. It is turned on is the bsp enables it and it is not explicitly disabled via the configure option --disable-tcpip. As many warnings as possible were removed locally after the code was merged. Only the gen68360 and mvme136 bsps were compiled this way. The ka9q port and network driver were submitted by Eric Norum (eric@skatter.USask.Ca). The network demo programs are not included in the tree at this point.
* This set of changes is the build of what was required to convert toJoel Sherrill1997-04-011-0/+34
