* include/rpc/Makefile.am: Apply include_*HEADERS instead of
H_FILES.
effects in RTEMS source code.
* src/rpc/Makefile.am, src/rpc/auth_time.c, src/rpc/clnt_simple.c,
src/rpc/clnt_tcp.c, src/rpc/clnt_udp.c, src/rpc/clnt_unix.c,
src/rpc/get_myaddress.c, src/rpc/pmap_clnt.c, src/rpc/pmap_getmaps.c,
src/rpc/pmap_getport.c, src/rpc/pmap_rmt.c, src/rpc/rtime.c,
src/rpc/svc_tcp.c, src/rpc/svc_udp.c, src/rpc/svc_unix.c:
Use of _read, _write, and _close as macros conflicted with
newlib's use of these as routine names. They were renamed to
include "_RPC_" prefix.
* src/xdr/xdr_float.c: Added A29K support.
* src/rpc/Makefile.am, src/xdr/Makefile.am: Include compile.am
That BSP now has a stub clock driver so the tests can link even
if they won't execute. A handful of Makefiles had to be updated
and we had to account for printk.c being a shared file now.
generated assembly from it.
that contains:
* Removes MKLIB
handling)
converted to automake.
that contains:
regarded as bugs).
now works).
* removes libbsp/bare/wrapup
* Further cleanups
<corsepiu@faw.uni-ulm.de> which converted fiels to automake.
<corsepiu@faw.uni-ulm.de>.
in the previous commits.
*.cfg files.
dependencies
automake and RTEMS make rules
convention)
performs automatically.
WARNING:
Makefile.ams.
mkdir c/src/librpc
mkdir c/src/librpc/src
mkdir c/src/librpc/include
rm -rf c/src/lib/librpc
rm -rf c/src/lib/include/rpc
in the required order .
# make[5]: Entering directory
# mips64orion-rtems-gcc -v
# mips64orion-rtems-ld -v
mkdir c/src/librpc
dependencies of "Makefile".
--enable-maintainer-mode.
future.
cd <rtems-source-tree>
this week until now.
It consists of 3 parts:
1. a patch
2. a perl script (acpolish)
plural).
configure scripts etc.
added by acpolish.
To apply this:
./rtems-polish.sh
Later:
cvs add contrib
cvs add contrib/acpolish
cvs commit
Hello,
host :
- one for RTEMS it self,
- one for GDB-4.17.
1/ RTEMS patch
This patch adds 2 libraries :
- the Remote Debugger library
--enable-rdbg
rtems_rdbg_initialize ();
2/ GDB-4.17 patch
To connect to a target, use :
And... Debug ;)
