path: root/c/src/libnetworking/pppd (follow)
* 2002-09-07 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-09-071-0/+1
| | | | | * pppd/ipcp.c, rtems_servers/ftpd.c: Add include files to resolve warnings.
* 2002-08-14 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-08-141-0/+2
| | | | | | | * rtems_servers/ftpd.c: Remove unused variable buf. * pppd/md5.c: #include <string.h> to make gcc31 happy. * rtems_telnetd/telnetd.c: #include <string.h> to make gcc31 happy. * rtems_webserver/webmain.c: Remove unused variable dir, cp.
* 2002-08-12 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-08-121-1/+1
| | | | * pppd/utils.c: Include i960 in varargs conditional to avoid error.
* 2002-08-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-08-111-1/+1
| | | | | | | | * pppd/Makefile.am: Use .$(OBJEXT) instead of .o. * rtems_servers/Makefile.am: Use .$(OBJEXT) instead of .o. * rtems_telnetd/Makefile.am: Use .$(OBJEXT) instead of .o. * rtems_webserver/Makefile.am: Use .$(OBJEXT) instead of .o. * wrapup/Makefile.am: Use .$(OBJEXT) instead of .o.
* 2002-07-25 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-07-254-5/+5
| | | | | * pppd/chap.c, pppd/fsm.c, pppd/fsm.h, pppd/upap.c: Per PR255 fix prototype mismatches.
* 2002-04-18 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-04-181-2/+2
| | | | * pppd/utils.c: Adapt to gcc-3.x.
| | | | | | | | | | | | | | | | | | | | | | | * configure.ac: AC_INIT(package,_RTEMS_VERSION,_RTEMS_BUGS). AM_INIT_AUTOMAKE([no-define foreign 1.6]). * arpa/Makefile.am: Remove AUTOMAKE_OPTIONS. * kern/Makefile.am: Remove AUTOMAKE_OPTIONS. * Makefile.am: Remove AUTOMAKE_OPTIONS. * lib/Makefile.am: Remove AUTOMAKE_OPTIONS. * libc/Makefile.am: Remove AUTOMAKE_OPTIONS. * machine/Makefile.am: Remove AUTOMAKE_OPTIONS. * net/Makefile.am: Remove AUTOMAKE_OPTIONS. * netinet/Makefile.am: Remove AUTOMAKE_OPTIONS. * nfs/Makefile.am: Remove AUTOMAKE_OPTIONS. * pppd/Makefile.am: Remove AUTOMAKE_OPTIONS. * rtems/Makefile.am: Remove AUTOMAKE_OPTIONS. * rtems_servers/Makefile.am: Remove AUTOMAKE_OPTIONS. * rtems_telnetd/Makefile.am: Remove AUTOMAKE_OPTIONS. * rtems_webserver/Makefile.am: Remove AUTOMAKE_OPTIONS. * sys/Makefile.am: Remove AUTOMAKE_OPTIONS. * vm/Makefile.am: Remove AUTOMAKE_OPTIONS. * wrapup/Makefile.am: Remove AUTOMAKE_OPTIONS.
* 2002-02-27 Ilya Alexeev <ilya@continuum.ru>Joel Sherrill2002-02-274-6/+31
| | | | | | * net/if_ppp.c, pppd/auth.c, pppd/chat.c, pppd/pppd.h, pppd/sys-rtems.c: Add server with pap-authorization capabilities as well as eliminate some warnings.
* 2001-02-01 Mike Siers <mikes@poliac.com>Joel Sherrill2002-02-011-1/+8
| | | | | | * pppd/rtemspppd.c (rtems_pppd_disconnect): Modified to avoid bringing the link down too fast. NOTE: Mike reports successfully running at 56K baud on a direct link.
* 2001-01-31 Mike Siers <mikes@poliac.com>Joel Sherrill2002-02-011-0/+24
| | | | * pppd/rtemsdialer.h: New file missed in previous commit.
* 2001-01-31 Mike Siers <mikes@poliac.com>Joel Sherrill2002-01-3116-121/+171
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | * Nice Update of PPPD support which eliminates the requiremetn that drivers be in the termios TASK_DRIVEN mode. Mike did significant testing and reports that it seems to be more stable and handle larger packets better. This patch replaces the termios tasks with more general pppd network driver tasks. The functions pppinput() and pppstart() get called from the interrupt service routine. * Makefile.am, configure.ac, net/Makefile.am, net/bpf.h, net/ethernet.h, net/if.c, net/if.h, net/if_arp.h, net/if_dl.h, net/if_ethersubr.c, net/if_llc.h, net/if_loop.c, net/if_ppp.h, net/if_pppvar.h, net/if_types.h, net/netisr.h, net/ppp-comp.h, net/ppp_defs.h, net/pppcompress.h, net/radix.c, net/radix.h, net/raw_cb.c, net/raw_cb.h, net/raw_usrreq.c, net/route.c, net/route.h, net/rtsock.c, pppd/Makefile.am, pppd/README, pppd/STATUS, pppd/auth.c, pppd/cbcp.c, pppd/ccp.c, pppd/ccp.h, pppd/chap.c, pppd/chap.h, pppd/chap_ms.c, pppd/chap_ms.h, pppd/chat.c, pppd/demand.c, pppd/fsm.c, pppd/fsm.h, pppd/ipcp.c, pppd/ipcp.h, pppd/ipxcp.c, pppd/ipxcp.h, pppd/lcp.c, pppd/lcp.h, pppd/magic.c, pppd/magic.h, pppd/options.c, pppd/patchlevel.h, pppd/pathnames.h, pppd/pppd.8, pppd/pppd.h, pppd/rtemsmain.c, pppd/rtemspppd.c, pppd/rtemspppd.h, pppd/sys-rtems.c, pppd/upap.c, pppd/upap.h, pppd/utils.c, pppd/example/README, pppd/example/netconfig.h, wrapup/Makefile.am: Modified. * net/bsd-comp.c, net/if_ppp.c, net/ppp-deflate.c, net/ppp.h, net/ppp_tty.c, net/pppcompress.c, net/zlib.c, net/zlib.h: New file. * modem/, modem/.cvsignore, modem/Makefile.am, modem/ppp.c, modem/ppp.h, modem/ppp_tty.c, modem/pppcompress.c: Subdirectory removed.
* 2002-02-05 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-01-061-1/+0
| | | | | * pppd/sys-rtems.c: Remove unused variable status from dodefaultroute.
* 2001-10-12 Mike Siers <mikes@poliac.com>Joel Sherrill2001-10-1216-4012/+683
| | | | | | | | | | | * Update to stable working state. Congratulations Mike! :) * modem_example: Directory removed. * modem_example/16550.h, modem_example/README, modem_example/modem.c, modem_example/modem.h, modem_example/ppp.c, modem_example/ppp.h, modem_example/pppcompress.c: Files removed. * pppd/example/pppd.options: New file. * pppd/README, pppd/STATUS, pppd/cbcp.c, pppd/cbcp.h, pppd/chat.c, pppd/pppd.h, pppd/rtemsmain.c: Updated.
* 2001-09-23 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-09-271-1/+1
| | | | | | | | | | | | | | | * machine/Makefile.am: Use 'PREINSTALL_FILES ='. * net/Makefile.am: Use 'PREINSTALL_FILES ='. * netinet/Makefile.am: Use 'PREINSTALL_FILES ='. * vm/Makefile.am: Use 'PREINSTALL_FILES ='. * pppd/Makefile.am: Use 'PREINSTALL_FILES ='. * sys/Makefile.am: Use 'PREINSTALL_FILES ='. * rtems_servers/Makefile.am: Use 'PREINSTALL_FILES ='. * arpa/Makefile.am: Use 'PREINSTALL_FILES ='. * nfs/Makefile.am: Use 'PREINSTALL_FILES ='. * rtems_webserver/Makefile.am: Use 'PREINSTALL_FILES ='. * rtems/Makefile.am: Use 'PREINSTALL_FILES ='. * rtems_telnetd/Makefile.am: Use 'PREINSTALL_FILES ='.
* 2001-08-16 Mike Siers <mikes@poliac.com>Joel Sherrill2001-08-173-2/+36
| | | | | | * pppd/STATUS: Updated by Joel based upon email from Mike. * pppd/cbcp.c, pppd/cbcp.h: Readded files. These support callback functionality that has not even been compiled under RTEMS yet.
* 2001-08-16 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2001-08-162-1/+3
| | | | | | * pppd/example/Makefile: Removed. * pppd/example/Makefile-user: Added was Makefile. Renamed to avoid bootstrap -c clobbering it.
* 2001-08-16 Mike Siers <mikes@poliac.com>Joel Sherrill2001-08-1644-6036/+7402
| | | | | | | | | | | | | | | | | | | | | | | | | | * Update of PPPD to 2.3.11 from 2.3.5 and addition of an example application. Mike's notes on the modifications: - renamed error() function because of namespace problems - removed calls to the exit() funciton - removed extra files from the pppd source directory - defined pppd task constant values in rtemspppd.h - modifyied example code to get actual tick per second value - placed the pppd 2.3.11 man page file (pppd.8) into the pppd directory * pppd/cbcp.c, pppd/cbcp.h, pppd/main.c, pppd/ppp_tty.c, pppd/pppmain.c, pppd/rtems-ppp.c, pppd/rtems-ppp.c: Deleted. * pppd/pppd.8, pppd/rtemsmain.c, pppd/rtemspppd.c, pppd/rtemspppd.h, pppd/sys-rtems.c, pppd/utils.c, pppd/example/Makefile, pppd/example/README, pppd/example/init.c, pppd/example/netconfig.h, pppd/example/ppp.conf, pppd/example/pppdapp.c, pppd/example/system.h: New files. * modem/ppp_tty.c, net/if_ppp.h, pppd/Makefile.am, pppd/README, pppd/STATUS, pppd/auth.c, pppd/ccp.c, pppd/ccp.h, pppd/chap.c, pppd/chap.h, pppd/chap_ms.c, pppd/chap_ms.h, pppd/chat.c, pppd/demand.c, pppd/fsm.c, pppd/fsm.h, pppd/ipcp.c, pppd/ipcp.h, pppd/ipxcp.c, pppd/ipxcp.h, pppd/lcp.c, pppd/lcp.h, pppd/magic.c, pppd/magic.h, pppd/options.c, pppd/patchlevel.h, pppd/pathnames.h, pppd/pppd.h, pppd/upap.c, pppd/upap.h: Modified.
* 2001-04-20 Radzislaw Galler <rgaller@et.put.poznan.pl>Joel Sherrill2001-04-206-35/+36
| | | | | | | * modem/ppp.c, pppd/main.c, pppd/pppmain.c, pppd/rtems-ppp.c, pppd/modem_example/modem.c, pppd/modem_example/ppp.c: Translated Polish comments and other strings into English * pppd/STATUS: Updated to reflect the changes
* 2000-12-08 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2000-12-081-9/+19
| | | | | | | | | | * libc/linkaddr.c: Initialized variable to remove warning. * modem/ppp.c, modem/ppp_tty.c: Made numerous variable declarations conditional on PPP_COMPRESS and PPP_FILTER. Commented out variables that were not used because the code using them was commented out. Removed totally unused variables. * modem/pppcompress.c: Added parentheses to avoid warnings. * pppd/pppmain.c: Removed numerous warnings.
* 2000-11-25 Antti P Miettinen <antti.p.miettinen@nokia.com>Joel Sherrill2000-11-251-0/+1304
| | | | | | | | | | | | * wrapup/Makefile.am: Added modem subdir. * configure.in, Makefile.am: Added modem subdir. * net/Makefile.am: Added if_pppvar.h, pppcompress.h. * pppd/Makefile.am: Added pppmain.c (which needs work). * pppd/chat.c, pppd/fsm.c, pppd/fsm.h, pppd/ipxcp.c, pppd/main.c, pppd/ppp_tty.c, pppd/upap.c: Changes from Thomas Doerfler <Thomas.Doerfler@imd-systems.de> and cosmetic changes by me. Actually main.c and ppp_tty.c should be scratched. The modem subdir has the real ppp_tty.c and the real pppd main is in pppmain.c.
* 2000-11-25 Antti P Miettinen <antti.p.miettinen@nokia.com>Joel Sherrill2000-11-255-9/+14
* 2000-10-18 Chris Johns <ccj@acm.org>Joel Sherrill2000-10-181-1/+1
| | | | * pppd/ipxcp.c: Fixed a typo.
* 2000-09-22 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2000-09-221-0/+1
| | | | | | | | | | * machine/types.h, pppd/pppd.h, rtems/rtems_bsdnet_internal.h, rtems_webserver/webmain.c: machine/types.h should not have included rtems.h. It is now including precisely the least amount of low level, yet portable .h files to get the basic RTEMS types defined. This rippled into other files since rtems_bsdnet_internal.h used machine/types.h to include rtems.h.
* 2000-09-04 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-09-051-0/+1
| | | | | | | * kern/Makefile.am, lib/Makefile.am, libc/Makefile.am, net/Makefile.am, netinet/Makefile.am, nfs/Makefile.am, pppd/Makefile.am, rtems/Makefile.am, rtems_servers/Makefile.am, rtems_webserver/Makefile.am, wrapup/Makefile.am: Include compile.am
* Port of RTEMS to the Texas Instruments C3x/C4x DSP families includingJoel Sherrill2000-07-263-3/+3
| | | | | | | | | | | a BSP (c4xsim) supporting the simulator included with gdb. This port was done by Joel Sherrill and Jennifer Averett of OAR Corporation. Also included with this port is a space/time optimization to eliminate FP context switch management on CPUs without hardware or software FP. An issue with this port was that sizeof(unsigned32) = sizeof(unsigned8) on this CPU. This required addressing alignment checks and assumptions as well as fixing code that assumed sizeof(unsigned32) == 4.
* Merge lossage. Apparently the DOS/UNIX CRLF issue got lost.Joel Sherrill2000-06-121-1438/+1438
* Merged from 4.5.0-beta3aJoel Sherrill2000-06-124-9/+9
* Patch rtems-rc-4.5.0-13-cvs.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>.Joel Sherrill2000-04-131-0/+2
| | | | adds .cvsignore.
* Patches rtems-rc-20000118-7.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-02-032-60/+44
| | | | | | | | | | | | | | | | | that contains the automake files for libnetworking plus a couple of minor fixes. [Now only one unused/unsupported Makefile.in remains (./c/src/lib/libbsp/hppa1.1/pxfl/Makefile.in).] To apply: patch -p1 < rtems-rc-20000118-7.diff /bin/sh rtems-rc-20000118-7.rm /bin/sh rtems-rc-20000118-7.add ./bootstrap Notes: * I have tested this one by building all BSPs for m68k, powerpc, sh and unix with toolchains built since last weekend. * I did not touch libnetworking's directory layout.
* Comments added and some messages translated from Polish.Joel Sherrill2000-01-032-5/+51
* Made prototype of ChapReceiveSuccess and ChapReceiveFailure match.Joel Sherrill1999-12-211-2/+2
* New file.Joel Sherrill1999-12-031-0/+7
* Modem example driver for ppp by Tomasz Domin <dot@comarch.pl> of ComArch SA.Joel Sherrill1999-12-036-0/+3697
| | | | This was used on a mpc823 based system.
* Added port of ppp-2.3.5 from Tomasz Domin <dot@comarch.pl> of ComArch SA.Joel Sherrill1999-11-3037-0/+17567
Tomasz only tested this on the mpc823. The official site for the original source for this PPP implementation is: ftp://cs.anu.edu.au/pub/software/ppp NOTE: As of 11/30/1999, the current version of this source is 2.3.10.
