The single write to memory or ioport output are mostly
atomic operations already. The proper memory synchronization barrier
should be used around them to guarantee ordering (sync or eieio
on PowerPC for example) but because I have not found settable
portable primitive only compiler barrier is used.
It should be enough on x86 because the externally visible order
should be/is guaranteed to be preserved on x86 architecture.
Tested to work with QEMU provided Intel i82557b network controller emulation.
qemu-system-x86_64 -enable-kvm -kernel $APP_BINARY \
-vga cirrus \
-append "--console=/dev/com1" \
-serial stdio \
-net nic,vlan=1,macaddr=be:be:be:10:00:01,model=i82557b \
-net tap,ifname=tap1,vlan=1,script=no,downscript=no
more available on i386.
This change is required to build RTEMS with classic "--enable-networking"
and link applications/tests which reference RTEMS_BSP_NETWORK_DRIVER_ATTACH.
The network interface driver for this module is located in the new
network stack (libbsd), see file "if_dwc.c".
GCC 6.0 previews give the following warning on sonic.c:
../../../../../rtems/c/src/libchip/network/sonic.c:837:11: warning:
statement is indented as if it were guarded by... [-Wmisleading-indentation]
This was discussed here:
https://lists.rtems.org/pipermail/devel/2016-March/014004.html
and we concluded it would be better to rewrite the entire snippet.
This first step eliminates the following as public APIs for the pc386
BSP:
+ pcib_conf_read8
+ pcib_conf_read16
+ pcib_conf_read32
+ pcib_conf_write8
+ pcib_conf_write16
+ pcib_conf_write32
The if_fxp.c driver uses these enough where I provided local macros
to allow the code to be mostly unmodified. On other architectures
these names have been used privately. It will take multiple patches
to completely eliminate these symbols from the RTEMS source tree.
The focus of the first effort is just to eliminate these as a public
pc386 API so support can be added for systems without legacy PCI BIOS.
This patch allows the user to configure the PHY address for the DWMAC
driver by giving a pointer to a dwmac_user_cfg structure to network
stack via rtems_bsdnet_ifconfig::drv_ctrl.
The GRETH doesn't support IP fragments.
By fault an rtems_status_code has been expected instead of an errno error number.
Reduce number of packet transmitted interrupts by using the interrupt mechanism only
if we run out of DMA descriptors.
Under normal conditions regaining DMA descriptors, mbufs and clusters is handled
via a counter.
Reset the corresponding DMA status bit
Also signal to compiler that the start variable in lan91cxx_recv is only used when debugging.
TOD_MILLISECONDS_TO_TICKS().
Add reserved system events RTEMS_EVENT_SYSTEM_NETWORK_SBWAIT and
RTEMS_EVENT_SYSTEM_NETWORK_SOSLEEP.
Add and use rtems_bsdnet_event_send().
- A typo prevents if_smc.c from being built when configured;
- The argument passed to the interrupt handler was incorrect and the
addition of support for RTEMS_INTERRUPT_SHARED exposed it;
- A "#ifdef DEBUG" is supposed to be "#if DEBUG" since 0 is supposed to
make it quiet.
+ libbsp/sparc/shared/include/pci.h was largely a copy of
an older version of the cpukit pci.h. Removed much of the
contents and included <rtems/pci.h>.
+ sparc/*/pci*.c - Move to <rtems/pci.h> required updating
to use uint32_t for dword accesses.
+ Rename PCI_MULTI_FUNCTION to PCI_HEADER_TYPE_MULTI_FUNCTION
+ Define PCI_HEADER_TYPE_MULTI_FUNCTION in cpukit pci.h and remove
PCI_MULTI_FUNCTION definitions in C files.
+ Move PCI_INVALID_VENDORDEVICEID definitions from various C files
to cpukit pci.h
These modifications were required by hand after running the script.
In some cases, the file names did not match patterns. In others,
the format of the file did not match any common patterns.
The ISR code is updated to use argument instead of global greth
structure, now that the greth private is available in the ISR.
The shared-irq routines will unmask the IRQ, so the forced LEON3
BSP unmask/clear IRQ is removed.
Signed-off-by: Daniel Hellstrom <daniel@gaisler.com>
