PR 614/bsps
* Makefile.am: Remove C_FILES (Unused).
* start/start.S: DWARF on the m68k requires that all objects me a
multiple of a 16-bit word in length.
* configure.ac: Add RTEMS_ROOT (HACK: This is the last file c/src
which still uses RTEMS_ROOT).
* include/bsp.h: Include <rtems/motorola/mc68230.h> instead of <motorola/mc68230.h>.
* include/bsp.h: Include <rtems/motorola/mc68681.h> instead of <motorola/mc68681.h>.
* acinclude.m4: Regenerate to include ss555.
* mpc5xx/clock/clock.c, mpc5xx/irq/irq_asm.S, mpc5xx/vectors/vectors.S:
Reflect new locations of cpukit headers.
* include/bsp.h, startup/start.S: Reflect new locations of cpukit headers.
* flashentry/flashentry.S: Include <rtems/score/powerpc.h> instead of
<rtems/score/ppc.h>.
* mpc505/ictrl/ictrl.c, mpc505/vectors/vectors.S,
mpc6xx/exceptions/raw_exception.c,
mpc8260/exceptions/raw_exception.c,
mpc8xx/exceptions/raw_exception.c, rtems/powerpc/cache.h,
mpc5xx/ictrl/ictrl.c, mpc5xx/exceptions/raw_exception.c: Include
<rtems/score/powerpc.h> instead of <rtems/score/ppc.h>.
* rtems/score/powerpc.h: New (Copied and renamed from rtems/score/ppc.h)
for consistency with other ports.
* rtems/score/ppc.h: Deprecation wrapper to rtems/score/powerpc.h.
* rtems/score/cpu.h: Include rtems/score/powerpc.h instead of
rtems/score/ppc.h.
* README, configure.ac, mpc5xx/Makefile.am,
mpc5xx/exceptions/raw_exception.c, mpc5xx/exceptions/raw_exception.h,
mpc5xx/timer/timer.c, shared/include/cpuIdent.h: addition of a
significant amount of MPC5xx support as part of the addition of the
SS555 BSP.
* mpc5xx/README, mpc5xx/clock/clock.c,
mpc5xx/console-generic/console-generic.c, mpc5xx/include/console.h,
mpc5xx/include/mpc5xx.h, mpc5xx/irq/irq.c, mpc5xx/irq/irq.h,
mpc5xx/irq/irq_asm.S, mpc5xx/irq/irq_init.c,
mpc5xx/vectors/vectors.S, mpc5xx/vectors/vectors.h,
mpc5xx/vectors/vectors_init.c: New files.
* mpc5xx/exceptions/asm_utils.S: Removed.
* .cvsignore, ChangeLog, Makefile.am, README, bsp_specs, configure.ac,
times, clock/p_clock.c, console/console.c, include/.cvsignore,
include/bsp.h, include/coverhd.h, irq/irq.h, startup/bspstart.c,
startup/iss555.c, startup/linkcmds, startup/start.S,
wrapup/.cvsignore, wrapup/Makefile.am: New files.
* start/rxgen_romld.S: Include <rtems/asm.h> instead of <asm.h>.
* irq/irq_asm.S: Include <rtems/asm.h> instead of <asm.h>.
* timer/timer.c: Include <rtems/rtems/motorola/mc68230.h> instead of
* Makefile.am: Build main.o for !HAS_CXX.
Set EXEEXT = <empty> (Workaround to a bug in automake).
<zilog/z8536.h>.
* mvme147/console/console.c: Include <rtems/zilog/z8530.h> instead
of <zilog/z8530.h>.
* dmv152/include/bsp.h: Include <rtems/zilog/z8536.h> instead of
<zilog/z8536.h>.
* dmv152/include/bsp.h: Include <rtems/zilog/z8530.h> instead of
<zilog/z8530.h>.
* mvme162/startup/bspclean.c: Include <rtems/m68k/zilog/z8036.h>
instead of <zilog/z8036.h>.
* mvme136/clock/ckinit.c, mvme136/startup/bspclean.c,
mvme136/startup/bspstart.c, mvme136/timer/timer.c: Include
<rtems/m68k/zilog/z8036.h> instead of <zilog/z8036.h>.
* c/src/lib/libbsp/m68k/ods68302/clock/ckinit.c,
c/src/lib/libbsp/m68k/ods68302/include/bsp.h,
c/src/lib/libbsp/m68k/ods68302/startup/cpuboot.c,
c/src/lib/libbsp/m68k/ods68302/startup/crc.c,
c/src/lib/libbsp/m68k/ods68302/startup/gdb-hooks.c,
c/src/lib/libbsp/m68k/ods68302/startup/m68302scc.c,
c/src/lib/libbsp/m68k/ods68302/timer/timer.c: Include
<rtems/m68k/m68302.h> instead of <m68302.h>.
* c/src/lib/libbsp/m68k/mrm332/include/bsp.h,
c/src/lib/libbsp/m68k/mrm332/start/start.S,
c/src/lib/libbsp/m68k/mrm332/startup/start_c.c: Include
<rtems/m68k/sim.h> instead of <sim.h>.
* c/src/lib/libbsp/m68k/mrm332/include/bsp.h: Include
<rtems/m68k/qsm.h> instead of <qsm.h>.
* c/src/lib/libbsp/m68k/gen68360/clock/clock.c,
c/src/lib/libbsp/m68k/gen68360/console/console.c,
c/src/lib/libbsp/m68k/gen68360/console/consolereserveresources.c,
c/src/lib/libbsp/m68k/gen68360/network/network.c,
c/src/lib/libbsp/m68k/gen68360/startup/alloc360.c,
c/src/lib/libbsp/m68k/gen68360/startup/init68360.c,
c/src/lib/libbsp/m68k/gen68360/timer/timer.c: Include
<rtems/m68k/m68360.h> instead of <m68360.h>.
* c/src/lib/libbsp/m68k/gen68302/clock/ckinit.c,
c/src/lib/libbsp/m68k/gen68302/console/console.c,
c/src/lib/libbsp/m68k/gen68302/network/network.c,
c/src/lib/libbsp/m68k/gen68302/timer/timer.c: Include
* clock/clock.S, mongoosev/vectorisrs/vectorisrs.c,
shared/interrupts/isr_entries.S,
shared/interrupts/vectorexceptions.c, timer/gettime.S: Include
<rtems/mips/iregdef.h> instead of <iregdef.h>.
shared/interrupts/installisrentries.c,
<rtems/mips/idtcpu.h> instead of <idtcpu.h>.
* console/led.S, liblnk/lnklib.S, start/start.S, startup/idtmem.S,
startup/idttlb.S: Include <rtems/mips/iregdef.h> instead of
<iregdef.h>.
startup/idttlb.S, startup/inittlb.c: Include <rtems/mips/idtcpu.h>
* clock/clock.c, include/bsp.h, timer/timer.c: Include
<rtems/c4x/c4xio.h> instead of <c4xio.h>.
* vectors/vectors.S: Include <rtems/asm.h> instead of <asm.h>.
* flashentry/flashentry.S: Include <rtems/asm.h> instead of <asm.h>.
* start/startfor340only.S: Include <rtems/asm.h> instead of <asm.h>.
* timer/timerisr.S: Include <rtems/asm.h> instead of <asm.h>.
