* sh7032/clock/ckinit.c, sh7045/clock/ckinit.c, sh7750/clock/ckinit.c:
The Shared Memory Driver no longer requires the special IOCTL in
Clock_control. This was a hack which has existed since before the
Classic API Timer Manager was implemented. All implementations of and
references to Clock_control were removed.
* mpc5xx/clock/clock.c, mpc6xx/clock/c_clock.c, mpc8260/clock/clock.c,
mpc8xx/clock/clock.c, ppc403/clock/clock.c, ppc403/clock/clock_4xx.c:
* clock/ckinit.c: The Shared Memory Driver no longer requires the
special IOCTL in Clock_control. This was a hack which has existed
since before the Classic API Timer Manager was implemented. All
implementations of and references to Clock_control were removed.
* mcf5206/clock/ckinit.c, mcf5272/clock/ckinit.c: The Shared Memory
Driver no longer requires the special IOCTL in Clock_control. This
was a hack which has existed since before the Classic API Timer
Manager was implemented. All implementations of and references to
* clock/clock.c: The Shared Memory Driver no longer requires the
* interrupt/interrupt.c, network/ethernet.c: Eliminate "boolean".
* mpc6xx/clock/c_clock.c: CLOCK_DRIVER_USE_FAST_IDLE must be checked to
be equal to 1 -- not just defined.
* mpc83xx/network/tsec.c, new-exceptions/raw_exception.c:
Convert to "bool".
* mpc505/timer/timer.c, mpc5xx/timer/timer.c, mpc6xx/timer/timer.c,
mpc8260/timer/timer.c, mpc8xx/timer/timer.c, ppc403/timer/timer.c:
Convert to "bool".
* sh7032/timer/timer.c, sh7045/timer/timer.c, sh7750/timer/timer.c:
Convert to "bool".
* timer/timer.c: Convert to "bool".
* mcf5206/timer/timer.c, mcf5272/timer/timer.c: Convert to "bool".
* network/ethernet.c, serial/twi.c, timer/timer.c: Convert to "bool".
* at91rm9200/timer/timer.c, lpc22xx/timer/timer.c,
mc9328mxl/timer/timer.c, s3c2400/timer/timer.c,
s3c24xx/timer/timer.c: Convert to "bool".
* sh7750/sci/sh4uart.c: Misc. bool cleanup.
* mpc83xx/i2c/mpc83xx_i2cdrv.c, mpc8xx/clock/clock.c,
ppc403/clock/clock.c, ppc403/console/console.c.polled:
Eliminate rtems_boolean.
* mcf5206/console/mcfuart.c, mcf5206/include/mcfuart.h:
* sh7045/include/sci.h, sh7045/sci/sci.c, sh7750/include/sh/sh4uart.h:
Convert to using bool.
* arm/at91rm9200/timer/timer.c, arm/lpc22xx/timer/timer.c,
arm/mc9328mxl/timer/timer.c, arm/s3c2400/timer/timer.c,
arm/s3c24xx/timer/timer.c, bfin/timer/timer.c,
m68k/mcf5206/timer/timer.c, m68k/mcf5272/timer/timer.c: Rename timer
driver methods to follow RTEMS programming conventions.
Rename timer driver methods to follow RTEMS programming conventions.
* timer/timer.c: Rename timer driver methods to follow RTEMS
* mcf5206/timer/timer.c, mcf5206/timer/timerisr.S,
mcf5272/timer/timer.c, mcf5272/timer/timerisr.S: Rename timer driver
s3c24xx/timer/timer.c: Rename timer driver methods to follow RTEMS
* lpc22xx/timer/timer.c: Remove broken bool implementation.
Remove unused vars.
Remove unused vars.
RCS file: /usr1/CVS/rtems/c/src/lib/libcpu/powerpc/ChangeLog,v
retrieving revision 1.309
diff -u -r1.309 ChangeLog
--- ChangeLog 20 Aug 2008 17:29:18 -0000 1.309
+++ ChangeLog 22 Aug 2008 13:35:03 -0000
@@ -1,3 +1,8 @@
+2008-08-22 Sebastian Huber <sebastian.huber@embedded-brains.de>
+ * shared/include/powerpc-utility.h: Fixed parameter evaluation in
+ special purpose register macros.
2008-08-20 Sebastian Huber <sebastian.huber@embedded-brains.de>
* mpc55xx/fec/fec.c: Added copyright information.
* mpc55xx/dspi/dspi.c, mpc55xx/edma/edma.c, mpc55xx/esci/esci.c:
Fixed nexted extern declarations. Fixed integer conversion warnings.
* shared/include/cpuIdent.c: Added missing initializers.
* at91rm9200/irq/bsp_irq_init.c, lpc22xx/irq/bsp_irq_init.c,
mc9328mxl/irq/bsp_irq_init.c, s3c24xx/irq/bsp_irq_init.c:
Add missing prototypes.
* mpc8260/clock/clock.c, mpc8260/console-generic/console-generic.c:
* mpc8xx/clock/clock.c, mpc8xx/console-generic/console-generic.c,
ppc403/timer/timer.c, shared/src/cache.c: Add missing prototypes.
* m68040/fpsp/rtems_fpsp.c: Move extern outside of braces.
* mpc6xx/mmu/pte121.c, mpc6xx/mmu/pte121.h, mpc6xx/timer/timer.c,
new-exceptions/e500_raw_exc_init.c,
new-exceptions/bspsupport/ppc_exc_bspsupp.h,
new-exceptions/bspsupport/vectors_init.c: Fix warnings.
* serial/twi.c: Remove unused var.
